2.7 | 2.8 | 2.9 | 3.0 | |
If you have already created a VM host, you will want to create and delete virtual machines (VMs); this article explains how to do so.
Eight questions you may have:
- How do I add a VM?
- How do LXD projects work?
- How do I set resources while adding a VM?
- How do I set the architecture while adding a VM?
- How do I set storage while adding a VM?
- How do I specify interfaces while adding a VM?
- How do I find a VM host ID?
- How do I delete a VM?
Adding a VM from the CLI
To compose a basic VM:
"system_id": "73yxmc",
Set resources while adding a VM
Where $RESOURCES is a space-separated list of six constraints:
- cores= requested cores
- cpu_speed= requested minimum cpu speed in MHz
- memory= requested memory in MB
- architecture= See Architecture below
- storage= See Storage below
- interfaces= See Interfaces below
Setting the architecture while adding a VM
Then, for example:
Setting storage parameters while adding a VM
For example, let’s examine how to compose a machine with the following two disks:
- 32 GB disk from storage pool
pool1
- 64 GB disk from storage pool
pool2
where we want the first disk to be a bootable root partition /
and the second to be a home directory.
First, create the VM:
Note that the labels, here mylabel
, are an ephemeral convenience that you might find useful in scripting MAAS actions.
MAAS will create a VM with 2 disks, /dev/vda
(32 GB) and /dev/vdb
(64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root, and home partition.
We’ll start by deleting the /
partition MAAS created because we want a separate /boot
partition to demonstrate how yo.
To find $DISK1_ID
and $PARTITION_ID
, use maas admin machine read $VM_HOST_ID
To find $DISK2_ID
To find the partition IDs, use maas admin partitions read $VM_HOST_ID $DISK1_ID
and maas admin partitions read $VM_HOST_ID $DISK2_ID
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID "mount_point=/boot"
Specifying interfaces while adding a VM
Using the interfaces
constraint, you can compose virtual machines with interfaces, allowing the selection of VM host NICs.
If you don’t specify an interfaces
constraint, MAAS maintains backward compatibility by checking for a maas
network, then a default
network to which to connect the virtual machine.
If you specify an interfaces
constraint, MAAS creates a bridge
or macvlan
attachment to the networks that match the given constraint. MAAS prefers bridge
interface attachments when possible since this typically results in successful communication.
interfaces=eth0:space=maas;eth1:space=storage
Assuming you deploy the VM host on a machine or controller with access to the maas
and storage
spaces, MAAS will create an eth0
interface bound to the maas
space and an eth1
interface bound to the storage
space.
MAAS automatically converts the ip
constraint to a VLAN constraint (matching the VLAN which corresponds to the subnet can be found – e.g. 172.16.99.0/24
.) and assigns the IP address to the newly-composed machine upon allocation.
See the Machines MAAS API documentation for a list of all constraint keys.
Find VM host IDs
Here’s a simple way to find a VM host’s ID by name using jq
maas $PROFILE vm-hosts read | jq '.[] | select (.name=="MyVMHost") | .name, .id'
Example output:
"MyVMHost"
1
Deleting a VM with the CLI
After you delete a machine, its resources will be available for other VMs.
