2.7 | 2.8 | 2.9 | 3.0 | |
http://${API_HOST}:5240/MAAS
Configuration
Your main concerns for this experiment are the DNS forwarder, the Ubuntu image import section, and the SSH public key, though you might want to set the region name to something memorable, since this text will appear at the bottom of every MAAS screen in this install domain. Set the DNS forwarder to something obvious, e.g., 8.8.8.8
, Google’s DNS server. Set this to your own internal DNS server if you know the IP address.
lp:<username>
gh:<username>
If you want to use your existing public key from your home directory, you can select “Upload”and then copy your entire public key from .ssh/id_rsa.pub
(or wherever you may have stored the key):
Enabling DHCP
Networking
Network discovery can be disabled at any time from the button on the Dashboard view. Also note that you can get back to the dashboard at any time by clicking the MAAS logo.
- subnet has the traditional meaning: a range of IP addresses covering a subset of IP addresses. Generally speaking , a subnet is a collection of IP addresses which includes at least two addresses.
- a space is a collection of subnets that you can create with MAAS, understanding that each subnet can belong to only one space. Spaces allow multiple subnets to communicate without requiring a direct network path between them.
- a zone is also an ad-hoc collection, but one which groups individual nodes, rather than subnets. MAAS allows you to create and edit zones at will.
- a fabric is essentially a collection of trunked switches, allowing you to access a group of VLANs.
Be aware that these network settings are spread across several web UI configuration pages. The Zones page, for example, enables you to see how many machines, devices and controllers are using a zone, and allows you to add and edit zones. The Subnets page, shown below, provides access to fabric, VLAN, subnet and spaces configuration.
Deployment
MAAS-managed machines are listed – and operated on – from the Machines page, making it one of the most important screens in the MAAS web UI:
If you are testing MAAS using virtual machines, the machines appear here as soon as they boot. New machines are added automatically when they first connect to your network. Alternatively, the ‘Add hardware’ menu lets you add machines manually, via their MAC address.
After you configure power and interfaces, MAAS must commission machines to retrieve CPU, memory and storage information. From this point, you can command MAAS to acquire, test, deploy and release these machines as you work with your MAAS cloud.
While you are testing MAAS, be sure to check out filters, which can narrow your view based on both tags and hardware characteristics. You can select and manage machines in either filtered or full views.
Images
When it comes to running applications, MAAS can easily deploy any supported variant of Ubuntu, including LTS and non-LTR versions for x86, ARM, PPC and s390x systems. You can also deploy several other operating systems to your machines, including CentOS 7, CentOS 6, Windows, RHEL, and ESXi images, via Ubuntu Advantage^.
VM hosts
It’s easy to add a virsh VM host: click the “Add KVM” button on the “KVM” page of the web UI, give the VM host a name, and select as the VM host type. You will also need to enter the address for the KVM host; this address will look something like 'qemu+ssh://@10.249.0.2/system, where the paasword will be the same password
` uses to log into the host.
After you create a VM host, you compose hardware by selecting the VM host, and then selecting “Compose” from the Action menu. You can configure composed hardware as desired, including the number of cores, CPU speed, RAM and combined storage. Then just click “Compose machine”, and MAAS will combine resources to create a new, single entity that can be used just like any other machine. VM hosts abstract multiple resources:
into pools of composable hardware:
