As of MAAS 3.0 Beta1, this page has been deprecated and the content moved to the CLI sections of other, relevant MAAS documents. The contents may or may not diverge from the latest information over time.
The following document provides a list of interface management tasks which can be performed by the MAAS CLI.
Nine questions you may have:
- How do I use the MAAS CLI?
 - What might I need to know about networking?
 - How do I commission machines?
 - How do I discover interface identifiers?
 - How do I create a bond interface?
 - How do I create a bridge interface?
 - How do I delete an interface?
 - How do I create a VLAN interface?
 - How do I delete a VLAN interface?
Interface identifiers
"id": 15,
"name": "ens9",
Create a Bond interface
A bond interface is used to aggregate two or more more physical interfaces into a single logical interface. A bond can be created with the following command:
Use the ‘parents’ parameters to define which interfaces form the aggregate interface.
The ‘bond_updelay’ and ‘bond_downdelay’ parameters specify the number of milliseconds to wait before either enabling or disabling a slave after a failure has been detected.
The following is an example of ‘create-bond’ in action:
See Bond interfaces for details on supported bond modes and their actions.
Create a Bridge interface
parent=$IFACE_ID
Use ‘parent’ to define the primary interface used for the bridge:
Delete an interface
The ‘delete’ command can be used to delete a bridge interface, a bond interface or a physical interface:
For example:
There is no machine-readable output after the successful execution of the delete command.
Create a VLAN interface
    "vid": 100,
    "mtu": 1500,
    "dhcp_on": false,
    "external_dhcp": null,
    "relay_vlan": null,
    "name": "Storage network",
    "space": "undefined",
    "fabric": "fabric-0",
    "id": 5004,
    "primary_rack": null,
    "fabric_id": 0,
    "secondary_rack": null,
parent=$IFACE_ID
    "tags": [],
    "type": "vlan",
    "enabled": true,
    "system_id": "4efwb4",
    "id": 21,
    "children": [],
    "params": {},
    "vlan": {
        "vid": 100,
        "mtu": 1500,
        "dhcp_on": false,
        "relay_vlan": null,
        "id": 5004,
        "fabric_id": 0,
    "parents": [
        "ens3"
    "effective_mtu": 1500,
    "links": [
            "id": 55,
            "mode": "link_up"
    "discovered": null,
    "name": "ens3.100",
Delete a VLAN interface
maas admin vlan delete 0 100
