CLI interface management (snap/2.7/CLI)
The following document provides a list of interface management tasks which can be performed by the MAAS CLI.
Interface identifiers
"id": 15,
"name": "ens9",
Create a Bond interface
A bond interface is used to aggregate two or more more physical interfaces into a single logical interface. A bond can be created with the following command:
Use the ‘parents’ parameters to define which interfaces form the aggregate interface.
The ‘bond_updelay’ and ‘bond_downdelay’ parameters specify the number of milliseconds to wait before either enabling or disabling a slave after a failure has been detected.
The following is an example of ‘create-bond’ in action:
See Bond interfaces for details on supported bond modes and their actions.
Create a Bridge interface
parent=$IFACE_ID
Use ‘parent’ to define the primary interface used for the bridge:
Delete an interface
The ‘delete’ command can be used to delete a bridge interface, a bond interface or a physical interface:
For example:
There is no machine-readable output after the successful execution of the delete command.
Create a VLAN interface
    "vid": 100,
    "mtu": 1500,
    "dhcp_on": false,
    "external_dhcp": null,
    "relay_vlan": null,
    "name": "Storage network",
    "space": "undefined",
    "fabric": "fabric-0",
    "id": 5004,
    "primary_rack": null,
    "fabric_id": 0,
    "secondary_rack": null,
parent=$IFACE_ID
    "tags": [],
    "type": "vlan",
    "enabled": true,
    "system_id": "4efwb4",
    "id": 21,
    "children": [],
    "params": {},
    "vlan": {
        "vid": 100,
        "mtu": 1500,
        "dhcp_on": false,
        "relay_vlan": null,
        "id": 5004,
        "fabric_id": 0,
    "parents": [
        "ens3"
    "effective_mtu": 1500,
    "links": [
            "id": 55,
            "mode": "link_up"
    "discovered": null,
    "name": "ens3.100",
Delete a VLAN interface
maas admin vlan delete 0 100
