Four questions you might have:
- What is MAAS?
- What does MAAS offer me?
- Can MAAS co-locate key components to conserve resources?
- How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
- web UI (optimised for mobile devices)
- Ubuntu, CentOS, Windows, and RHEL installation support
- open-source IP address management (IPAM)
- full API/CLI support
- high availability (optional)
- IPv6 support
- inventory of components
- DHCP and DNS for other devices on the network
- DHCP relay integration
- VLAN and fabric support
- NTP for the entire infrastructure
- hardware testing
- composable hardware support
Colocation of key components
How MAAS works
