Writing guide (deb/2.7/CLI)
Update: Editing RAD/offline documentation
After 20 September 2020, many documents in the MAAS documentation set have been converted to the RAD (Reader Adapative Documentation) style, and enabled for conversion to offline documentation. Editing RAD documentation is a bit different from standard doc, so it’s worth explaining how to do it correctly.
First, some assurance: RAD is generated from a separate set of masters, published by a special tool called xpub, which prevents overwriting files that have been changed and warns the user that changes have been made. Any changes you make to the doc will be noticed, at the latest, when an update is attempted, and your changes will be evaluated and, if reasonable, very likely added to the masters. So don’t worry about losing edits; we are trying to be very careful to make sure that doesn’t happen.
That said, there is a bit of art to editing RAD pages and making sure your edits are suitable for offline doc conversion, namely, throughout RAD documents, you’ll see HTML comments like this one:
<!-- snap-2-11-cli snap-2-11-ui deb-2-11-cli deb-2-11-ui
Sometimes, they have multiple “tags” (e.g., snap-2-6-cli is a tag), and sometimes they only have one, like this:
<!-- snap-2-11-cli
The tags should generally be self-explantory. For example, the tag above refers to the snap delivery of MAAS version 2.11, specifically for someone using the CLI interface.
NOTE that is there no 2.11 version of MAAS: we’ve used an example that won’t be accidentally processed by the RAD tools, but any version from 2.7 - 3.0 and beyond can be represented.
Contribution overview
Style and language
  • Use a spell checker.
  • Resist being overly formal.
Headers
... and so on...
Bold and Italic Text
<strong>Bold Text</strong>
<em>Italic Text</em>
**strong**
Code blocks
maas command do something
  • a command line sequence,
Inline code
Admonishments
Admonishment text.
[/note]
Where:
Admonishment examples
Note Admonishment
[note status="Note"]
key.
[/note]
And it will appear as:
Warning Admonishment
[/note]
And it will appear like this:
Positive Admonishment
[/note]
Negative Admonishment
[/note]
Comments
[visible text](URL)
Images
<a href="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png" target = "_blank"><img src="https://discourse.maas.io/uploads/default/original/1X/1f2e6cf2879e391e7ae1ad537cc9ce1baa119f86.png"></a>
Tiered sections
<details>
<details>
</details>
</details>
Capitalisation
