- How do I set up a VM host bridge with the MAAS UI?
- How do I set up a VM host bridge with the MAAS CLI/API?
- How do I set up a VM host bridge with netplan?
- How do I set up a VM host bridge with libvirt?
- What else must I do to use LXD VM hosts?
Set up VM host bridge with MAAS UI
- Select the machine you want to use as a VM host.
- Switch to the “Network” tab.
- Select the network where you want to create the bridge and click “Create bridge:”
- Configure the bridge on a subnet MAAS controls. You may use any IP mode for the bridge:
- Deploy Ubuntu
INTERFACE_ID=$(maas $PROFILE machine read $SYSTEM_ID | jq .boot_interface.id) -
Create the bridge:
BRIDGE_ID=$(maas $PROFILE interfaces create-bridge $SYSTEM_ID name=br0 parent=$INTERFACE_ID | jq .id) -
SUBNET_ID=$(maas $PROFILE subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24" and .managed == true).id') -
Open your netplan configuration file. This should be in
/etc/netplan. It could be called50-cloud-init.yaml,netplan.yaml, or something else. -
Modify the file to add a bridge, using the example below to guide you.
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
- Apply the configuration with
netplan apply.
- Disable DHCP on libvirt’s
defaultnetwork, or - Create a new libvirt network
maaswith DHCP disabled.
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
Make LXD available for VM hosting (Beta)
Assuming that you want to use LXD VM hosts --currently a Beta feature – then once a bridge is set up, you need to install the correct version of LXD. Prior to the release of Ubuntu 20.04 LXD was installed using Debian packages. The Debian packaged version of LXD is too old to use with MAAS. If this is the case, you’ll need to remove the LXD Debian packages and install the Snap version. Note that you cannot install both Debian and snap versions, as this creates a conflict.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
Refreshing LXD on 20.04
$ sudo snap refresh
All snaps up to date.
Initialize LXD prior to use
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: no- MAAS does not support LXD clusters in this Beta version. -
Name of the storage backend to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir- Beta testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk. -
Would you like to connect to a MAAS server? (yes/no) [default=no]: no- When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing in this Beta version. -
Would you like to configure LXD to use an existing bridge or host interface? (yes/no) [default=no]: yes- The bridge LXD creates is isolated and not managed by MAAS. If this bridge is used, you would be able to add the LXD VM host and compose virutal machines, but commissioning, deploying, and any other MAAS action which uses the network will fail – soyesis the correct answer here. -
Name of the existing bridge or host interface: br0- br0 is the name of the bridge the user configured (see sections above) which is connected to a MAAS-managed network. -
Trust password for new clients:- This is the password the user will enter when connecting with MAAS.
Again:
The host is now ready to be added to MAAS as an LXD VM host. Upon adding the VM host, its own commissioning information will be refreshed.
Set up SSH
There are two different methods for setting up SSH, depending whether you installed MAAS via package or snap.
Set up SSH (libvirt only) using the package
sudo chsh -s /bin/bash maas
sudo su - maas
ssh-keygen -t rsa -N ''
Set up SSH (libvirt only) with the snap
$ sudo -i
Finally, you’ll need to add id_rsa.pub to the authorized_keys file in /home/<vm-host-user-homedir-name>/.ssh/, where <vm-host-user-homedir-name> is the name of your VM host user.
