- How do I set up a VM host bridge with the MAAS UI?
- How do I set up a VM host bridge with the MAAS CLI/API?
- How do I set up a VM host bridge with netplan?
- How do I set up a VM host bridge with libvirt?
- What else must I do to use LXD VM hosts?
Set up VM host bridge with MAAS UI
- Select the machine you want to use as a VM host.
- Switch to the “Network” tab.
- Select the network where you want to create the bridge and click “Create bridge:”
- Configure the bridge on a subnet MAAS controls. You may use any IP mode for the bridge:
- Deploy Ubuntu
Create the bridge:
Open your netplan configuration file. This should be in
/etc/netplan
. It could be called50-cloud-init.yaml
,netplan.yaml
, or something else. -
Modify the file to add a bridge, using the example below to guide you.
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
- Apply the configuration with
netplan apply
By default, libvirt creates a virtual bridge, virbr0
, through which VMs communicate with each other and the Internet. DHCP, supplied by libvirt, automatically assigns an IP address to each VM. However, to enable network booting in MAAS, you’ll need to provide DHCP in MAAS and either:
- Disable DHCP on libvirt’s
default
network, or - Create a new libvirt network
maas
with DHCP disabled.
You can set up such a maas
network like this:
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
Make LXD available for VM hosting (Beta)
Assuming that you want to use LXD VM hosts --currently a Beta feature – then once a bridge is set up, you need to install the correct version of LXD. Prior to the release of Ubuntu 20.04 LXD was installed using Debian packages. The Debian packaged version of LXD is too old to use with MAAS. If this is the case, you’ll need to remove the LXD Debian packages and install the Snap version. Note that you cannot install both Debian and snap versions, as this creates a conflict.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
Refreshing LXD on 20.04
$ sudo snap refresh
All snaps up to date.
Initialize LXD prior to use
Once LXD is installed it needs to be configured with lxd init
before first use:
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: no
- MAAS does not support LXD clusters in this Beta version. -
Name of the storage backend to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir
- Beta testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk. -
Would you like to connect to a MAAS server? (yes/no) [default=no]: no
- When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing in this Beta version. -
- The bridge LXD creates is isolated and not managed by MAAS. If this bridge is used, you would be able to add the LXD VM host and compose virutal machines, but commissioning, deploying, and any other MAAS action which uses the network will fail – soyes
is the correct answer here. -
- br0 is the name of the bridge the user configured (see sections above) which is connected to a MAAS-managed network. -
Trust password for new clients:
- This is the password the user will enter when connecting with MAAS.
Again:
The host is now ready to be added to MAAS as an LXD VM host. Upon adding the VM host, its own commissioning information will be refreshed.
Set up SSH
Here, $USER
is a user on your VM host who is a member of the libvirtd
Unix group on the VM host, and $VM_HOST_IP
is the IP of your VM host. Note that insufficient permissions for $USER
may cause the virsh
command to fail with an error such as failed to connect to the hypervisor
. Check the $USER
group membership to make sure $USER
group.
There are two different methods for setting up SSH, depending whether you installed MAAS via package or snap.
Set up SSH (libvirt only) using the package
The maas
user on your rack controllers will issue all libvirt commands. Therefore, you’ll need to set up SSH public keys on every rack controller for user maas
. First create SSH keys on all rack controllers:
sudo chsh -s /bin/bash maas
sudo su - maas
ssh-keygen -t rsa -N ''
Next, add the contents of ~maas/.ssh/id_rsa.pub
to the VM host user’s ~$USER/.ssh/authorized_keys
. To accomplish this, log into your VM host node, via SSH, from a host for which MAAS has a matching public SSH key.
Set up SSH (libvirt only) with the snap
sudo ssh-keygen -f id_rsa
Finally, you’ll need to add id_rsa.pub
to the authorized_keys
file in /home/<vm-host-user-homedir-name>/.ssh/
, where <vm-host-user-homedir-name>
is the name of your VM host user.
