In order to deploy a VM host in your MAAS network, you first need to set up a bridge to connect between your VM host and MAAS itself. This article explains:
- How to set up a VM host bridge with the MAAS CLI/API
- How to set up a VM host bridge with netplan
- How to set up a VM host bridge with libvirt
- How to set up SSH for use by libvirt
- How to make LXD available for hosting
LXD sets up a bridge as part of the initialisation process; note that you will have to perform a couple of additional steps to prevent LXD from offering DHCP, which will interfere with the normal operation of MAAS. Everything you need to know is described at the initialisation link.
How to use the MAAS API to configure a bridge
INTERFACE_ID=$(maas $PROFILE machine read $SYSTEM_ID | jq .boot_interface.id) -
Create the bridge:
BRIDGE_ID=$(maas $PROFILE interfaces create-bridge $SYSTEM_ID name=br0 parent=$INTERFACE_ID | jq .id) -
SUBNET_ID=$(maas $PROFILE subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24" and .managed == true).id') -
How to use netplan to configure a bridge
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
How to use libvirt to configure a bridge
- Disable DHCP on libvirt’s
defaultnetwork, or - Create a new libvirt network
maaswith DHCP disabled.
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
How to set up SSH
How to set up SSH (libvirt only)
sudo ssh-keygen -f id_rsa
Finally, you’ll need to add id_rsa.pub to the authorized_keys file in /home/<vm-host-user-homedir-name>/.ssh/, where <vm-host-user-homedir-name> is the name of your VM host user.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
R\How to refresh LXD on 20.04
$ sudo snap refresh
All snaps up to date.
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: no- MAAS does not currently support LXD clusters. -
Name of the storage back-end to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir- testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk. -
Would you like to connect to a MAAS server? (yes/no) [default=no]: no- When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing thus far. -
Would you like to configure LXD to use an existing bridge or host interface? (yes/no) [default=no]: yes- The bridge LXD creates is isolated and not managed by MAAS. If this bridge is used, you would be able to add the LXD VM host and compose virtual machines, but commissioning, deploying, and any other MAAS action which uses the network will fail – soyesis the correct answer here. -
Name of the existing bridge or host interface: br0- br0 is the name of the bridge the user configured (see sections above) which is connected to a MAAS-managed network. -
Trust password for new clients:- This is the password the user will enter when connecting with MAAS.
Again:
lxc network show lxdbr0
config:
dns.mode: managed
ipv4.address: 10.146.214.1/24
ipv4.dhcp: "true"
ipv4.nat: "true"
ipv6.dhcp: "true"
ipv6.nat: "true"
description: ""
type: bridge
used_by:
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
$ lxc network show lxdbr0
config:
dns.mode: none
ipv4.dhcp: "false"
ipv4.nat: "true"
ipv6.dhcp: "false"
ipv6.nat: "true"
description: ""
type: bridge
used_by:
managed: true
status: Created
locations:
- none
