In order to deploy a VM host in your MAAS network, you first need to set up a bridge to connect between your VM host and MAAS itself. This article explains:
- How to set up a VM host bridge with the MAAS CLI/API
- How to set up a VM host bridge with netplan
- How to set up a VM host bridge with libvirt
- How to set up SSH for use by libvirt
- How to make LXD available for hosting
LXD sets up a bridge as part of the initialisation process; note that you will have to perform a couple of additional steps to prevent LXD from offering DHCP, which will interfere with the normal operation of MAAS. Everything you need to know is described at the initialisation link.
How to use the MAAS API to configure a bridge
Create the bridge:
How to use netplan to configure a bridge
, netplan.yaml
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
How to use libvirt to configure a bridge
By default, libvirt creates a virtual bridge, virbr0
, through which VMs communicate with each other and the Internet. DHCP, supplied by libvirt, automatically assigns an IP address to each VM. However, to enable network booting in MAAS, you’ll need to provide DHCP in MAAS and either:
- Disable DHCP on libvirt’s
default
network, or - Create a new libvirt network
maas
with DHCP disabled.
You can set up such a maas
network like this:
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
How to set up SSH
Here, $USER
is a user on your VM host who is a member of the libvirtd
Unix group on the VM host, and $VM_HOST_IP
is the IP of your VM host. Note that insufficient permissions for $USER
may cause the virsh
command to fail with an error such as failed to connect to the hypervisor
. Check the $USER
group membership to make sure $USER
group.
How to set up SSH (libvirt only)
The maas
user on your rack controllers will issue all libvirt commands. Therefore, you’ll need to set up SSH public keys on every rack controller for user maas
. First create SSH keys on all rack controllers:
$ sudo -i
Next, add the contents of ~maas/.ssh/id_rsa.pub
to the VM host user’s ~$USER/.ssh/authorized_keys
. To accomplish this, log into your VM host node, via SSH, from a host for which MAAS has a matching public SSH key.
Reading package lists... Done
Building dependency tree
$ sudo apt-get autoremove -y
$ sudo snap install lxd
R\How to refresh LXD on 20.04
$ sudo snap refresh
All snaps up to date.
Once LXD is installed it needs to be configured with lxd init
before first use:
$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: no
- MAAS does not currently support LXD clusters. -
Name of the storage back-end to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: dir
- testing has primarily been with dir; other options should work, but less testing has been done, so use at your own risk. -
Would you like to connect to a MAAS server? (yes/no) [default=no]: no
- When LXD is connected to MAAS containers or virtual machines created by LXD will be automatically added to MAAS as devices. This feature should work, but has limited testing thus far. -
- The bridge LXD creates is isolated and not managed by MAAS. If this bridge is used, you would be able to add the LXD VM host and compose virtual machines, but commissioning, deploying, and any other MAAS action which uses the network will fail – soyes
is the correct answer here. -
- br0 is the name of the bridge the user configured (see sections above) which is connected to a MAAS-managed network. -
Trust password for new clients:
- This is the password the user will enter when connecting with MAAS.
Again:
lxc network show lxdbr0
config:
dns.mode: managed
ipv4.address: 10.146.214.1/24
ipv4.dhcp: "true"
ipv4.nat: "true"
ipv6.dhcp: "true"
ipv6.nat: "true"
description: ""
type: bridge
used_by:
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
You can check your work by repeating the show
command:
$ lxc network show lxdbr0
config:
dns.mode: none
ipv4.dhcp: "false"
ipv4.nat: "true"
ipv6.dhcp: "false"
ipv6.nat: "true"
description: ""
type: bridge
used_by:
managed: true
status: Created
locations:
- none
