Four questions you may have:
- How do I set up a VM host bridge with the MAAS CLI/API?
- How do I set up a VM host bridge with netplan?
- How do I set up a VM host bridge with libvirt?
INTERFACE_ID=$(maas $PROFILE machine read $SYSTEM_ID | jq .boot_interface.id) -
Create the bridge:
BRIDGE_ID=$(maas $PROFILE interfaces create-bridge $SYSTEM_ID name=br0 parent=$INTERFACE_ID | jq .id) -
SUBNET_ID=$(maas $PROFILE subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24" and .managed == true).id') -
network:
bridges:
br0:
addresses:
- 10.0.0.101/24
gateway4: 10.0.0.1
interfaces:
- enp1s0
macaddress: 52:54:00:39:9d:f9
mtu: 1500
nameservers:
addresses:
- 10.0.0.2
search:
- maas
parameters:
forward-delay: 15
stp: false
ethernets:
enp1s0:
match:
mtu: 1500
set-name: enp1s0
enp2s0:
match:
macaddress: 52:54:00:df:87:ac
mtu: 1500
set-name: enp2s0
enp3s0:
match:
macaddress: 52:54:00:a7:ac:46
mtu: 1500
set-name: enp3s0
version: 2
- Disable DHCP on libvirt’s
defaultnetwork, or - Create a new libvirt network
maaswith DHCP disabled.
cat << EOF > maas.xml
<network>
<name>maas</name>
<forward mode='nat'>
<nat>
</nat>
</forward>
<dns enable="no" />
<domain name='testnet'/>
</ip>
</network>
EOF
virsh net-define maas.xml
Set up SSH
Set up SSH (libvirt only)
sudo ssh-keygen -f id_rsa
Finally, you’ll need to add id_rsa.pub to the authorized_keys file in /home/<vm-host-user-homedir-name>/.ssh/, where <vm-host-user-homedir-name> is the name of your VM host user.
