Hello. I’m a new MaaS user, and while investigating the security stance of the product, I was surprised to see that the data in transit over RPC was plaintext:
20:39:45.724030 IP 10.100.1.10.42446 > maas-poc1.mydomain.com.5252: Flags [P.], seq 827:1280, ack 95, win 501, options [nop,nop,TS val 4204001166 ecr 3529692185], length 453
0x0000: 4500 01f9 c6a4 4000 3b06 3d17 0a3c 00c0 E.....@.;.=..<..
0x0010: 0ac4 2484 a5ce 1484 4733 98c3 016b a57e ..$.....G3...k.~
0x0020: 8018 01f5 9e22 0000 0101 080a fa93 f78e ....."..........
0x0030: d262 d419 0004 5f61 736b 0002 3365 0008 .b...._ask..3e..
0x0040: 5f63 6f6d 6d61 6e64 000e 5570 6461 7465 _command..Update
0x0050: 5365 7276 6963 6573 0008 7365 7276 6963 Services..servic
0x0060: 6573 0180 0004 6e61 6d65 0004 7466 7470 es....name..tftp
0x0070: 0006 7374 6174 7573 0007 7275 6e6e 696e ..status..runnin
0x0080: 6700 0b73 7461 7475 735f 696e 666f 0000 g..status_info..
0x0090: 0000 0004 6e61 6d65 0004 6874 7470 0006 ....name..http..
0x00a0: 7374 6174 7573 0007 7275 6e6e 696e 6700 status..running.
0x00b0: 0b73 7461 7475 735f 696e 666f 0000 0000 .status_info....
0x00c0: 0004 6e61 6d65 0005 6468 6370 6400 0673 ..name..dhcpd..s
0x00d0: 7461 7475 7300 036f 6666 000b 7374 6174 tatus..off..stat
0x00e0: 7573 5f69 6e66 6f00 0000 0000 046e 616d us_info......nam
0x00f0: 6500 0664 6863 7064 3600 0673 7461 7475 e..dhcpd6..statu
0x0100: 7300 036f 6666 000b 7374 6174 7573 5f69 s..off..status_i
0x0110: 6e66 6f00 0000 0000 046e 616d 6500 086e nfo......name..n
0x0120: 7470 5f72 6163 6b00 0673 7461 7475 7300 tp_rack..status.
0x0130: 0772 756e 6e69 6e67 000b 7374 6174 7573 .running..status
0x0140: 5f69 6e66 6f00 0000 0000 046e 616d 6500 _info......name.
0x0150: 0864 6e73 5f72 6163 6b00 0673 7461 7475 .dns_rack..statu
0x0160: 7300 0772 756e 6e69 6e67 000b 7374 6174 s..running..stat
0x0170: 7573 5f69 6e66 6f00 0000 0000 046e 616d us_info......nam
0x0180: 6500 0a70 726f 7879 5f72 6163 6b00 0673 e..proxy_rack..s
0x0190: 7461 7475 7300 0772 756e 6e69 6e67 000b tatus..running..
0x01a0: 7374 6174 7573 5f69 6e66 6f00 0000 0000 status_info.....
0x01b0: 046e 616d 6500 0b73 7973 6c6f 675f 7261 .name..syslog_ra
0x01c0: 636b 0006 7374 6174 7573 0007 7275 6e6e ck..status..runn
0x01d0: 696e 6700 0b73 7461 7475 735f 696e 666f ing..status_info
0x01e0: 0000 0000 0009 7379 7374 656d 5f69 6400 ......system_id.
0x01f0: 0672 7774 7265 6100 00 .rwtrea..
The rack and the region controllers already share the secret that was used to initially join them. Is there a reason MaaS doesn’t use this to encrypt the communications?
I looked in both the Hardening guide (https://maas.io/docs/snap/2.9/ui/hardening-your-maas-installation) and the TLS guide (https://maas.io/docs/snap/2.9/ui/configuring-tls-encryption) and neither one mention securing the RPC link.
Thoughts?
