Ubuntu kernels (snap/2.7/CLI)
  4. Low latency kernels
This article explains each of these kernels, and offers instructions and further references regarding their use.
Seven questions you may have:
  1. What is a general availability kernel?
  2. What is a hardware enablement kernel?
  3. What is a pre-release hardware enablement kernel?
  4. What is a low latency kernel?
  5. How do I set a minimum kernel for enlistment and commissioning?
  6. How to I set a minimum deploy kernel for a machine?
  7. How do I set a specific kernel during machine deployment?
Low latency kernels
Using kernels
Set a default minimum kernel for enlistment and commissioning
Set a minimum deploy kernel for a machine
Set a specific kernel during machine deployment
