Ubuntu kernels (deb/3.0/CLI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
About Ubuntu kernels
  4. Low latency kernels
About low latency kernels
About choosing a kernel
