About Ubuntu kernels
- General availability kernels
- Hardware enablement kernels
- Hardware enablement kernels (pre-release)
- Low latency kernels
ga-<version>
: The GA kernel reflects the major kernel version of the shipped Ubuntu release. For example, ‘ga-16.04’ is based on the ‘generic’ 4.4 Ubuntu kernel. As per Ubuntu policy, a GA kernel will never have its major version upgraded until the underlying release is upgraded.
Before MAAS 2.1 on Xenial, HWE kernels are referred to by the notation hwe-<release letter>
. So, to install the Yakkety HWE kernel on Xenial, the hwe-y
kernel is used. By default, when using the web UI, MAAS imports all available HWE kernels along with its generic boot images. So if you are importing Trusty images, then the following HWE kernels are included: hwe-u
, hwe-v
, hwe-w
, hwe-x
(presuming the Xenial HWE kernel is available).
In MAAS 2.1, starting with Xenial kernels, the notation has changed. The following is used to refer to the latest HWE kernel available for Xenial: hwe-16.04
MAAS denotes the edge kernel like this: hwe-<version>-edge
About low latency kernels
hwe-x-lowlatency
: the Xenial low latency HWE kernel for Trusty -
ga-16.04-lowlatency
: the low latency GA kernel for Xenial -
hwe-16.04-lowlatency
: the low latency HWE kernel for Xenial
About choosing a kernel
- globally (default minimum enlistment and commissioning kernel)
- per machine (minimum deploy kernel)
- per machine during deployment (specific deploy kernel)
To set the default minimum enlistment and commissioning kernel (based on Ubuntu release: GA kernel) for all machines visit the ‘General’ tab of the ‘Settings’ page and select a kernel in the ‘Default Minimum Kernel Version’ field of the Commissioning section. Don’t forget to click ‘Save’.
To set the minimum deploy kernel on a machine basis, click on a machine from the ‘Machines’ page of the web UI and switch to its ‘Configuration’ page. Click ‘Edit’ in the ‘Machine configuration’ section, select a kernel in the ‘Minimum Kernel’ field followed by ‘Save changes’.
To set a specific kernel during deployment, select a machine from the ‘Machines’ page and choose ‘Deploy’ under ‘Take action’. Then choose a kernel from the (third) kernel field. Hit ‘Deploy machine’ to initiate the deployment.
MAAS verifies that the specified kernel is available for the given Ubuntu release (series) before deploying the machine.
