What would you like to do?
- Migrate an existing snap installation to use a local PostgreSQL server
- Manually export the MAAS database
- Network boot an IBM Power server
- Eliminate MAAS and LXD DNS & DHCP conflicts
- Try jq recipes using the CLI
sudo snap stop maas
sudo -u postgres \
host maasdb maas 0/0 md5
- update the database config in
/var/snap/maas/current/regiond.confwith the properdatabase_hostanddatabase_pass - change the content of
/var/snap/maas/common/snap_modefromalltoregion+rack
If you get into a situation where MAAS and LXD are both managing DNS on your MAAS network, there’s a simple fix. You can turn off LXD’s DNS management with the following command:
Basic machine list
#!/bin/bash
#!/bin/bash
