MAAS can be installed in either of two configurations: test or production. The test configuration uses a small PostgreSQL database (in a separate snap), designed for use with MAAS. The full-up production configuration uses a separate PostgreSQL database for performance and scalability. This article will walk you through both install methods.
- How do I install (but not initialize) the MAAS snap?
- How do I upgrade my 2.7 snap to version 2.8?
- What are MAAS initialisation modes?
- How do I initialise MAAS for a test or proof-of-concept configuration?
- How do I initialise MAAS for a production configuration?
- How do I migrate an existing snap install?
- What if I want to manually export the MAAS database to an existing PostgreSQL server?
- How can I check the service status of my MAAS configuration?
- How do I re-initialise MAAS, if I want to?
- How can I discover additional init options?
- Give me an example of initialising MAAS
- Tell me about the MAAS URL
- Tell me about the shared secret
Installing MAAS from the snap
After entering your password, the snap will download and install from the 2.8 channel – though MAAS needs initialising before it’s ready to go.
Upgrading MAAS from 2.7
If you want to upgrade from a 2.7 snap to 2.8, and you are using a region+rack configuration, use this command:
$ sudo snap refresh --channel=2.8 maas
After entering your password, the snap will refresh from the 2.8 channel. You will not need to re-initialize MAAS.
| Mode | Region | Rack | Database | Description |
all* |
X | X | X | Deprecated (see warning below) |
region |
X | Region API server only | ||
rack |
X | Rack controller only | ||
region+rack |
X | X | Region API server and rack controller | |
none |
Deinitializes MAAS and stops services |
all mode being deprecated: The MAAS initialisation mode “all” is deprecated in MAAS version 2.8.0 and will be removed in MAAS version 2.9.0.
Initialising MAAS as a test configuration
$ sudo maas init --help
optional arguments:
run modes:
region+rack Both region and rack controllers
region Region controller only
rack Rack controller only
$ maas-test-db.psql
psql (10.6)
Type "help" for help.
postgres=# \l
This will produce a list of databases, one of which will be maasdb, owned by maas. Note that this database is still empty because MAAS is not yet initialized and, hence, is not yet using the database. Once this is done, you can run the maas init command:
MAAS has been set up.
sudo maas configauth
sudo maas createadmin
$ sudo maas createadmin
Username: admin
Password: ******
Again: ******
Email: admin@example.com
Configuration verification
After a snap installation of MAAS, you can verify the currently-running configuration with:
sudo maas config
You will need to install PostgreSQL on the machine where you want to keep the database. This can be the same machine as the MAAS region/rack controllers or a totally separate machine. If PostgreSQL (version 10 or better) is already running on your target machine, you can skip this step. To install PostgreSQL, run these commands:
sudo apt update -y sudo apt install -y postgresql -
You want to make sure you have a suitable PostgreSQL user, which can be accomplished with the following command, where
$MAAS_DBUSERis your desired database username, and$MAAS_DBPASSis the intended password for that username. Note that if you’re executing this step in a LXD container (as root, which is the default), you may get a minor error, but the operation will still complete correctly.sudo -u postgres psql -c "CREATE USER \"$MAAS_DBUSER\" WITH ENCRYPTED PASSWORD '$MAAS_DBPASS'" -
Create the MAAS database with the following command, where
$MAAS_DBNAMEis your desired name for the MAAS database (typically known asmaas). Again, if you’re executing this step in a LXD container as root, you can ignore the minor error that results.sudo -u postgres createdb -O "$MAAS_DBUSER" "$MAAS_DBNAME" -
Edit
/etc/postgresql/10/main/pg_hba.confand add a line for the newly created database, replacing the variables with actual names. You can limit access to a specific network by using a different CIDR than0/0.host $MAAS_DBNAME $MAAS_DBUSER 0/0 md5 -
You can then initialise MAAS via the following command:
Checking MAAS service status
sudo maas status
bind9 RUNNING pid 7999, uptime 0:09:17
dhcpd STOPPED Not started
dhcpd6 STOPPED Not started
ntp RUNNING pid 8598, uptime 0:05:42
postgresql RUNNING pid 8001, uptime 0:09:17
proxy STOPPED Not started
rackd RUNNING pid 8000, uptime 0:09:17
regiond:regiond-0 RUNNING pid 8003, uptime 0:09:17
regiond:regiond-1 RUNNING pid 8008, uptime 0:09:17
regiond:regiond-2 RUNNING pid 8005, uptime 0:09:17
regiond:regiond-3 RUNNING pid 8015, uptime 0:09:17
tgt RUNNING pid 8040, uptime 0:09:15
Create first admin account:
Username: admin
Password: ******
Again: ******
MAAS URL
region: Used to create a new region controller. -
rack: Used to locate the region controller.
Shared secret
Reinitialising MAAS
Additional `init` options
