- What are managed subnets?
- What are unmanaged subnets?
- What is IP address tracking?
- How do I control subnet management
Managed subnets
- Lease addresses for DHCP from a reserved dynamic IP range
- Assign static addresses not included in a reserved IP range, typically via ‘Auto assign’ IP allocation mode for a node.
Unmanaged subnets
Controlling subnet management
To disable (or re-enable) subnet management navigate to the ‘Subnets’ page and select the subnet. Press the ‘Edit’ button to allow changes. The ‘Managed allocation’ field will become a slide switch. Click the label (or the switch icon itself) to toggle between enabled (dark blue) and disabled (grey) and click ‘Save summary’.
See MAAS CLI for how to do this with the CLI.
IP address tracking
