Adding a second disk while creating a lxd machine disappears after creating it.
Any idea?
@sysnasri, i moved your post to the “Users” forum where more people will see it, including our engineer on duty this week.
@sysnasri could you please provide the maas version you’re using, and the output for lxc config show fit-beagle?
maas version : 3.0.0
lxc config show fit-beagle --project maas
architecture: x86_64
config:
limits.cpu: "1"
limits.memory: "2147483648"
limits.memory.hugepages: "false"
security.secureboot: "false"
volatile.eth0.hwaddr: 00:16:3e:bd:37:da
volatile.last_state.power: STOPPED
volatile.uuid: 04926959-b29d-4d1a-9987-e65246fcdc35
volatile.vsock_id: "13"
devices:
disk1:
path: ""
pool: default
source: maas-d2bd76a5-83a7-41e5-b8f5-5418e4f14628
type: disk
eth0:
boot.priority: "1"
nictype: bridged
parent: br-eno4
type: nic
root:
boot.priority: "0"
path: /
pool: default
type: disk
ephemeral: false
profiles: []
stateful: false
description: ""
Could you also include maas $profile machine read $machine_id?
maas modir machine read hwwaqb
"storage_test_status": 2,
"physicalblockdevice_set": [
"firmware_version": "2.5+",
"partitions": [
"uuid": "88113409-1794-4dc3-94fc-8829631b943e",
"size": 536870912,
"bootable": true,
"tags": [],
"id": 91,
"used_for": "fat32 formatted filesystem mounted at /boot/efi",
"path": "/dev/disk/by-dname/sda-part1",
"device_id": 71,
"system_id": "hwwaqb",
"filesystem": {
"fstype": "fat32",
"label": "efi",
"uuid": "461ad7dd-a399-4786-a7ac-d52245770af4",
"mount_point": "/boot/efi",
"mount_options": null
"type": "partition",
"resource_uri": "/MAAS/api/2.0/nodes/hwwaqb/blockdevices/71/partition/91"
"uuid": "46e54a1d-3bac-4ebb-b196-0fab4da87400",
"size": 7457472512,
"bootable": false,
"tags": [],
"id": 92,
"path": "/dev/disk/by-dname/sda-part2",
"device_id": 71,
"filesystem": {
"fstype": "ext4",
"label": "root",
"uuid": "7619f5ef-0c54-4fa3-a904-00ad4639d783",
"mount_point": "/",
"resource_uri": "/MAAS/api/2.0/nodes/hwwaqb/blockdevices/71/partition/92"
"model": "QEMU HARDDISK",
"partition_table_type": "GPT",
"tags": [
"ssd"
"uuid": null,
"storage_pool": "default",
"used_for": "GPT partitioned with 2 partitions",
"size": 8000004096,
"available_size": 0,
"serial": "lxd_root",
"filesystem": null,
"id_path": "/dev/disk/by-id/scsi-0QEMU_QEMU_HARDDISK_lxd_root",
"id": 71,
"numa_node": 0,
"type": "physical",
"block_size": 512,
"name": "sda",
"used_size": 7999586304,
"resource_uri": "/MAAS/api/2.0/nodes/hwwaqb/blockdevices/71/"
"raids": [],
"fqdn": "fit-beagle.maas",
"node_type": 0,
"node_type_name": "Machine",
"commissioning_status": 2,
"current_testing_result_id": 119,
"bios_boot_method": "uefi",
"pod": {
"id": 15,
"name": "guided-koala",
"resource_uri": "/MAAS/api/2.0/pods/15/"
"workload_annotations": {},
"owner_data": {},
"netboot": true,
"boot_disk": {
"partitions": [
"size": 536870912,
"bootable": true,
"tags": [],
"id": 91,
"device_id": 71,
"filesystem": {
"fstype": "fat32",
"label": "efi",
"size": 7457472512,
"bootable": false,
"tags": [],
"id": 92,
"device_id": 71,
"filesystem": {
"fstype": "ext4",
"label": "root",
"mount_point": "/",
"tags": [
"ssd"
"uuid": null,
"size": 8000004096,
"filesystem": null,
"id": 71,
"numa_node": 0,
"type": "physical",
"block_size": 512,
"name": "sda",
"network_test_status": -1,
"cpu_count": 1,
"status_message": "Ready",
"distro_series": "",
"zone": {
"name": "default",
"description": "",
"id": 1,
"storage": 8000.004096,
"volume_groups": [],
"hardware_info": {
"system_vendor": "QEMU",
"system_product": "Standard PC (Q35 + ICH9, 2009)",
"system_family": "Unknown",
"system_version": "pc-q35-5.2",
"system_sku": "Unknown",
"system_serial": "Unknown",
"cpu_model": "Intel(R) Xeon(R) CPU E5-2650 v2",
"mainboard_vendor": "Canonical Ltd.",
"mainboard_product": "LXD",
"mainboard_version": "pc-q35-5.2",
"mainboard_firmware_vendor": "EFI Development Kit II / OVMF",
"mainboard_firmware_date": "02/06/2015",
"mainboard_firmware_version": "0.0.0",
"chassis_vendor": "QEMU",
"chassis_type": "Other",
"chassis_serial": "Unknown",
"chassis_version": "pc-q35-5.2"
"bcaches": [],
"memory": 2048,
"disable_ipv4": false,
"ip_addresses": [],
"address_ttl": null,
"locked": false,
"tag_names": [
"pod-console-logging",
"virtual"
"description": "",
"boot_interface": {
"link_speed": 0,
"effective_mtu": 1500,
"vendor": "Red Hat, Inc.",
"firmware_version": null,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"external_dhcp": null,
"relay_vlan": null,
"fabric_id": 0,
"id": 5001,
"secondary_rack": null,
"fabric": "fabric-0",
"space": "cloud",
"primary_rack": "wytqwh",
"name": "untagged",
"resource_uri": "/MAAS/api/2.0/vlans/5001/"
"tags": [],
"discovered": [],
"parents": [],
"params": "",
"mac_address": "00:16:3e:bd:37:da",
"enabled": true,
"children": [],
"product": null,
"interface_speed": 0,
"link_connected": true,
"sriov_max_vf": 0,
"links": [
"id": 319,
"mode": "auto",
"subnet": {
"name": "Internal",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"id": 5001,
"space": "cloud",
"name": "untagged",
"cidr": "10.10.0.0/16",
"rdns_mode": 2,
"gateway_ip": "10.10.0.1",
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": true,
"managed": true,
"disabled_boot_architectures": [],
"id": 1,
"space": "cloud",
"resource_uri": "/MAAS/api/2.0/subnets/1/"
"id": 148,
"numa_node": 0,
"type": "physical",
"name": "enp5s0",
"resource_uri": "/MAAS/api/2.0/nodes/hwwaqb/interfaces/148/"
"owner": null,
"hardware_uuid": "04926959-b29d-4d1a-9987-e65246fcdc35",
"interface_set": [
"link_speed": 0,
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"id": 5001,
"space": "cloud",
"name": "untagged",
"tags": [],
"discovered": [],
"parents": [],
"params": "",
"enabled": true,
"children": [],
"product": null,
"sriov_max_vf": 0,
"links": [
"id": 319,
"mode": "auto",
"subnet": {
"name": "Internal",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"fabric_id": 0,
"id": 5001,
"space": "cloud",
"name": "untagged",
"rdns_mode": 2,
"dns_servers": [],
"allow_dns": true,
"managed": true,
"id": 1,
"space": "cloud",
"id": 148,
"numa_node": 0,
"type": "physical",
"name": "enp5s0",
"power_type": "lxd",
"power_state": "off",
"default_gateways": {
"ipv4": {
"link_id": null
"ipv6": {
"gateway_ip": null,
"link_id": null
"cpu_test_status": -1,
"status": 4,
"testing_status": 2,
"other_test_status": -1,
"status_name": "Ready",
"interface_test_status": -1,
"cpu_speed": 2600,
"domain": {
"authoritative": true,
"ttl": null,
"id": 0,
"is_default": true,
"name": "maas",
"resource_record_count": 10,
"hostname": "fit-beagle",
"blockdevice_set": [
"size": 8000004096,
"block_size": 512,
"tags": [
"ssd"
"partitions": [
"size": 536870912,
"bootable": true,
"tags": [],
"id": 91,
"device_id": 71,
"filesystem": {
"fstype": "fat32",
"label": "efi",
"size": 7457472512,
"bootable": false,
"tags": [],
"id": 92,
"device_id": 71,
"filesystem": {
"fstype": "ext4",
"label": "root",
"mount_point": "/",
"uuid": null,
"filesystem": null,
"id": 71,
"numa_node": 0,
"type": "physical",
"name": "sda",
"memory_test_status": -1,
"numanode_set": [
"index": 0,
"memory": 2048,
"cores": [
0
"hugepages_set": []
"virtualmachine_id": 22,
"status_action": "",
"hwe_kernel": null,
"current_commissioning_result_id": 118,
"pool": {
"name": "default",
"id": 0,
"virtualblockdevice_set": [],
"min_hwe_kernel": "",
"swap_size": null,
"osystem": "",
"cache_sets": [],
"special_filesystems": [],
"resource_uri": "/MAAS/api/2.0/machines/hwwaqb/"
Thanks, could you also please paste the output for the 50-maas-01-commissioning commissioning script for that machine?
--2021-08-19 15:08:22-- http://10.10.0.2:5248/machine-resources/amd64
Connecting to 10.10.0.2:5248... connected.
Length: 8228936 (7.8M) [application/octet-stream]
Saving to: ‘/tmp/user_data.sh.kRxOtK/scripts/downloads/50-maas-01-commissioning/machine-resources’
0K .......... .......... .......... .......... .......... 0% 6.09M 1s
50K .......... .......... .......... .......... .......... 1% 5.39M 1s
100K .......... .......... .......... .......... .......... 1% 5.26M 1s
150K .......... .......... .......... .......... .......... 2% 5.15M 1s
200K .......... .......... .......... .......... .......... 3% 5.59M 1s
250K .......... .......... .......... .......... .......... 3% 7.97M 1s
300K .......... .......... .......... .......... .......... 4% 6.58M 1s
350K .......... .......... .......... .......... .......... 4% 5.79M 1s
400K .......... .......... .......... .......... .......... 5% 4.72M 1s
450K .......... .......... .......... .......... .......... 6% 5.02M 1s
500K .......... .......... .......... .......... .......... 6% 4.89M 1s
550K .......... .......... .......... .......... .......... 7% 5.78M 1s
600K .......... .......... .......... .......... .......... 8% 5.59M 1s
650K .......... .......... .......... .......... .......... 8% 6.31M 1s
700K .......... .......... .......... .......... .......... 9% 5.79M 1s
750K .......... .......... .......... .......... .......... 9% 5.52M 1s
800K .......... .......... .......... .......... .......... 10% 4.93M 1s
850K .......... .......... .......... .......... .......... 11% 5.65M 1s
900K .......... .......... .......... .......... .......... 11% 5.56M 1s
950K .......... .......... .......... .......... .......... 12% 5.67M 1s
1000K .......... .......... .......... .......... .......... 13% 4.86M 1s
1050K .......... .......... .......... .......... .......... 13% 5.56M 1s
1100K .......... .......... .......... .......... .......... 14% 5.65M 1s
1150K .......... .......... .......... .......... .......... 14% 5.69M 1s
1200K .......... .......... .......... .......... .......... 15% 4.89M 1s
1250K .......... .......... .......... .......... .......... 16% 7.25M 1s
1300K .......... .......... .......... .......... .......... 16% 10.7M 1s
1350K .......... .......... .......... .......... .......... 17% 10.8M 1s
1400K .......... .......... .......... .......... .......... 18% 9.38M 1s
1450K .......... .......... .......... .......... .......... 18% 10.7M 1s
1500K .......... .......... .......... .......... .......... 19% 10.7M 1s
1550K .......... .......... .......... .......... .......... 19% 10.7M 1s
1600K .......... .......... .......... .......... .......... 20% 9.55M 1s
1650K .......... .......... .......... .......... .......... 21% 10.8M 1s
1700K .......... .......... .......... .......... .......... 21% 10.7M 1s
1750K .......... .......... .......... .......... .......... 22% 10.7M 1s
1800K .......... .......... .......... .......... .......... 23% 9.33M 1s
1850K .......... .......... .......... .......... .......... 23% 10.9M 1s
1900K .......... .......... .......... .......... .......... 24% 10.8M 1s
1950K .......... .......... .......... .......... .......... 24% 11.0M 1s
2000K .......... .......... .......... .......... .......... 25% 9.44M 1s
2050K .......... .......... .......... .......... .......... 26% 10.8M 1s
2100K .......... .......... .......... .......... .......... 26% 10.8M 1s
2150K .......... .......... .......... .......... .......... 27% 10.7M 1s
2200K .......... .......... .......... .......... .......... 27% 9.46M 1s
2250K .......... .......... .......... .......... .......... 28% 10.7M 1s
2300K .......... .......... .......... .......... .......... 29% 10.8M 1s
2350K .......... .......... .......... .......... .......... 29% 10.6M 1s
2400K .......... .......... .......... .......... .......... 30% 9.32M 1s
2450K .......... .......... .......... .......... .......... 31% 10.8M 1s
2500K .......... .......... .......... .......... .......... 31% 10.8M 1s
2550K .......... .......... .......... .......... .......... 32% 10.8M 1s
2600K .......... .......... .......... .......... .......... 32% 8.74M 1s
2650K .......... .......... .......... .......... .......... 33% 10.7M 1s
2700K .......... .......... .......... .......... .......... 34% 10.7M 1s
2750K .......... .......... .......... .......... .......... 34% 10.8M 1s
2800K .......... .......... .......... .......... .......... 35% 9.34M 1s
2850K .......... .......... .......... .......... .......... 36% 10.9M 1s
2900K .......... .......... .......... .......... .......... 36% 10.5M 1s
2950K .......... .......... .......... .......... .......... 37% 10.6M 1s
3000K .......... .......... .......... .......... .......... 37% 9.40M 1s
3050K .......... .......... .......... .......... .......... 38% 10.6M 1s
3100K .......... .......... .......... .......... .......... 39% 10.7M 1s
3150K .......... .......... .......... .......... .......... 39% 10.5M 1s
3200K .......... .......... .......... .......... .......... 40% 9.37M 1s
3250K .......... .......... .......... .......... .......... 41% 10.6M 1s
3300K .......... .......... .......... .......... .......... 41% 10.3M 1s
3350K .......... .......... .......... .......... .......... 42% 10.6M 1s
3400K .......... .......... .......... .......... .......... 42% 9.39M 1s
3450K .......... .......... .......... .......... .......... 43% 10.6M 1s
3500K .......... .......... .......... .......... .......... 44% 10.7M 1s
3550K .......... .......... .......... .......... .......... 44% 10.8M 1s
3600K .......... .......... .......... .......... .......... 45% 9.54M 1s
3650K .......... .......... .......... .......... .......... 46% 10.6M 1s
3700K .......... .......... .......... .......... .......... 46% 10.8M 1s
3750K .......... .......... .......... .......... .......... 47% 10.6M 1s
3800K .......... .......... .......... .......... .......... 47% 9.52M 1s
3850K .......... .......... .......... .......... .......... 48% 10.9M 1s
3900K .......... .......... .......... .......... .......... 49% 9.86M 0s
3950K .......... .......... .......... .......... .......... 49% 10.7M 0s
4000K .......... .......... .......... .......... .......... 50% 9.43M 0s
4050K .......... .......... .......... .......... .......... 51% 10.8M 0s
4100K .......... .......... .......... .......... .......... 51% 10.8M 0s
4150K .......... .......... .......... .......... .......... 52% 10.7M 0s
4200K .......... .......... .......... .......... .......... 52% 9.40M 0s
4250K .......... .......... .......... .......... .......... 53% 10.7M 0s
4300K .......... .......... .......... .......... .......... 54% 10.7M 0s
4350K .......... .......... .......... .......... .......... 54% 10.9M 0s
4400K .......... .......... .......... .......... .......... 55% 9.57M 0s
4450K .......... .......... .......... .......... .......... 55% 10.7M 0s
4500K .......... .......... .......... .......... .......... 56% 10.8M 0s
4550K .......... .......... .......... .......... .......... 57% 10.7M 0s
4600K .......... .......... .......... .......... .......... 57% 9.38M 0s
4650K .......... .......... .......... .......... .......... 58% 10.7M 0s
4700K .......... .......... .......... .......... .......... 59% 10.8M 0s
4750K .......... .......... .......... .......... .......... 59% 10.8M 0s
4800K .......... .......... .......... .......... .......... 60% 9.47M 0s
4850K .......... .......... .......... .......... .......... 60% 10.7M 0s
4900K .......... .......... .......... .......... .......... 61% 10.8M 0s
4950K .......... .......... .......... .......... .......... 62% 10.7M 0s
5000K .......... .......... .......... .......... .......... 62% 9.46M 0s
5050K .......... .......... .......... .......... .......... 63% 10.6M 0s
5100K .......... .......... .......... .......... .......... 64% 10.8M 0s
5150K .......... .......... .......... .......... .......... 64% 10.5M 0s
5200K .......... .......... .......... .......... .......... 65% 8.58M 0s
5250K .......... .......... .......... .......... .......... 65% 10.8M 0s
5300K .......... .......... .......... .......... .......... 66% 10.8M 0s
5350K .......... .......... .......... .......... .......... 67% 10.9M 0s
5400K .......... .......... .......... .......... .......... 67% 9.28M 0s
5450K .......... .......... .......... .......... .......... 68% 10.8M 0s
5500K .......... .......... .......... .......... .......... 69% 10.8M 0s
5550K .......... .......... .......... .......... .......... 69% 10.5M 0s
5600K .......... .......... .......... .......... .......... 70% 9.47M 0s
5650K .......... .......... .......... .......... .......... 70% 10.6M 0s
5700K .......... .......... .......... .......... .......... 71% 10.7M 0s
5750K .......... .......... .......... .......... .......... 72% 10.8M 0s
5800K .......... .......... .......... .......... .......... 72% 9.56M 0s
5850K .......... .......... .......... .......... .......... 73% 10.5M 0s
5900K .......... .......... .......... .......... .......... 74% 10.7M 0s
5950K .......... .......... .......... .......... .......... 74% 8.56M 0s
6000K .......... .......... .......... .......... .......... 75% 9.46M 0s
6050K .......... .......... .......... .......... .......... 75% 10.9M 0s
6100K .......... .......... .......... .......... .......... 76% 10.8M 0s
6150K .......... .......... .......... .......... .......... 77% 10.7M 0s
6200K .......... .......... .......... .......... .......... 77% 9.37M 0s
6250K .......... .......... .......... .......... .......... 78% 10.9M 0s
6300K .......... .......... .......... .......... .......... 79% 10.7M 0s
6350K .......... .......... .......... .......... .......... 79% 10.7M 0s
6400K .......... .......... .......... .......... .......... 80% 9.34M 0s
6450K .......... .......... .......... .......... .......... 80% 10.8M 0s
6500K .......... .......... .......... .......... .......... 81% 10.8M 0s
6550K .......... .......... .......... .......... .......... 82% 9.94M 0s
6600K .......... .......... .......... .......... .......... 82% 9.43M 0s
6650K .......... .......... .......... .......... .......... 83% 10.8M 0s
6700K .......... .......... .......... .......... .......... 83% 10.6M 0s
6750K .......... .......... .......... .......... .......... 84% 10.7M 0s
6800K .......... .......... .......... .......... .......... 85% 9.45M 0s
6850K .......... .......... .......... .......... .......... 85% 10.8M 0s
6900K .......... .......... .......... .......... .......... 86% 10.9M 0s
6950K .......... .......... .......... .......... .......... 87% 10.7M 0s
7000K .......... .......... .......... .......... .......... 87% 9.20M 0s
7050K .......... .......... .......... .......... .......... 88% 10.7M 0s
7100K .......... .......... .......... .......... .......... 88% 10.6M 0s
7150K .......... .......... .......... .......... .......... 89% 10.8M 0s
7200K .......... .......... .......... .......... .......... 90% 9.56M 0s
7250K .......... .......... .......... .......... .......... 90% 10.7M 0s
7300K .......... .......... .......... .......... .......... 91% 10.7M 0s
7350K .......... .......... .......... .......... .......... 92% 10.8M 0s
7400K .......... .......... .......... .......... .......... 92% 9.53M 0s
7450K .......... .......... .......... .......... .......... 93% 10.7M 0s
7500K .......... .......... .......... .......... .......... 93% 10.7M 0s
7550K .......... .......... .......... .......... .......... 94% 10.7M 0s
7600K .......... .......... .......... .......... .......... 95% 9.41M 0s
7650K .......... .......... .......... .......... .......... 95% 10.6M 0s
7700K .......... .......... .......... .......... .......... 96% 10.8M 0s
7750K .......... .......... .......... .......... .......... 97% 10.8M 0s
7800K .......... .......... .......... .......... .......... 97% 9.46M 0s
7850K .......... .......... .......... .......... .......... 98% 9.88M 0s
7900K .......... .......... .......... .......... .......... 98% 11.9M 0s
7950K .......... .......... .......... .......... .......... 99% 12.0M 0s
8000K .......... .......... .......... ...... 100% 9.94M=0.9s
2021-08-19 15:08:23 (9.08 MB/s) - ‘/tmp/user_data.sh.kRxOtK/scripts/downloads/50-maas-01-commissioning/machine-resources’ saved [8228936/8228936]
"api_extensions": [
"resources",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"resources_v2",
"resources_disk_sata",
"resources_network_firmware",
"resources_disk_id",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"resources_system",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address"
"api_version": "1.0",
"environment": {
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_version": "5.4.0-77-generic",
"os_name": "ubuntu",
"os_version": "20.04",
"server": "maas-machine-resources",
"server_name": "fit-beagle",
"server_version": "4.12"
"resources": {
"cpu": {
"architecture": "x86_64",
"sockets": [
"name": "Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz",
"vendor": "GenuineIntel",
"socket": 0,
"cache": [
"level": 1,
"type": "Data",
"size": 32768
"level": 1,
"type": "Instruction",
"size": 32768
"level": 2,
"type": "Unified",
"size": 4194304
"level": 3,
"type": "Unified",
"size": 16777216
"cores": [
"core": 0,
"die": 0,
"threads": [
"id": 0,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"total": 1
"memory": {
"nodes": [
"numa_node": 0,
"hugepages_used": 0,
"hugepages_total": 0,
"used": 1381220352,
"total": 2147483648
"hugepages_size": 2097152,
"used": 297635840,
"total": 2147483648
"gpu": {
"cards": [
"driver": "virtio-pci",
"driver_version": "1",
"numa_node": 0,
"pci_address": "0000:04:00.0",
"vendor_id": "1af4",
"product": "Virtio GPU",
"product_id": "1050"
"total": 1
"network": {
"cards": [
"driver": "virtio_net",
"driver_version": "5.4.0-77-generic",
"ports": [
"id": "enp5s0",
"address": "00:16:3e:bd:37:da",
"port": 0,
"protocol": "ethernet",
"port_type": "other",
"auto_negotiation": false,
"link_detected": true
"numa_node": 0,
"pci_address": "0000:05:00.0",
"product_id": "0001"
"total": 1
"storage": {
"disks": [
"id": "sda",
"device": "8:0",
"type": "scsi",
"read_only": false,
"size": 8000004096,
"removable": false,
"numa_node": 0,
"device_path": "pci-0000:02:00.0-scsi-0:0:2:1",
"block_size": 512,
"rpm": 0,
"device_id": "scsi-0QEMU_QEMU_HARDDISK_lxd_root",
"partitions": []
"total": 1
"usb": {
"devices": [],
"total": 0
"pci": {
"devices": [
"driver": "",
"driver_version": "",
"numa_node": 0,
"pci_address": "0000:00:00.0",
"vendor": "Intel Corporation",
"vendor_id": "8086",
"product": "82G33/G31/P35/P31 Express DRAM Controller",
"product_id": "29c0",
"iommu_group": 0
"driver": "pcieport",
"numa_node": 0,
"pci_address": "0000:00:01.0",
"vendor_id": "1b36",
"product": "QEMU PCIe Root port",
"product_id": "000c",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.1",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.2",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.3",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.4",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.5",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.6",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:00:01.7",
"iommu_group": 0
"numa_node": 0,
"iommu_group": 0
"driver": "lpc_ich",
"numa_node": 0,
"pci_address": "0000:00:1f.0",
"product": "82801IB (ICH9) LPC Interface Controller",
"product_id": "2918",
"iommu_group": 0
"driver": "ahci",
"driver_version": "3.0",
"numa_node": 0,
"pci_address": "0000:00:1f.2",
"product": "82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode]",
"product_id": "2922",
"iommu_group": 0
"driver": "i801_smbus",
"numa_node": 0,
"pci_address": "0000:00:1f.3",
"product": "82801I (ICH9 Family) SMBus Controller",
"product_id": "2930",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.0",
"product": "Virtio memory balloon",
"product_id": "1045",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.1",
"product": "Virtio RNG",
"product_id": "1044",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.2",
"product": "Virtio input",
"product_id": "1052",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.3",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.4",
"product": "",
"product_id": "1053",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:01:00.5",
"product": "Virtio console",
"product_id": "1043",
"iommu_group": 0
"driver": "xhci_hcd",
"numa_node": 0,
"pci_address": "0000:01:00.6",
"product": "QEMU XHCI Host Controller",
"product_id": "000d",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:02:00.0",
"product": "Virtio SCSI",
"product_id": "1048",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:03:00.0",
"product": "Virtio filesystem",
"product_id": "1049",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:03:00.1",
"product": "",
"product_id": "105a",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:03:00.2",
"product": "",
"iommu_group": 0
"numa_node": 0,
"pci_address": "0000:03:00.3",
"iommu_group": 0
"numa_node": 0,
"product_id": "1050",
"iommu_group": 0
"numa_node": 0,
"product": "Virtio network device",
"product_id": "1041",
"iommu_group": 0
"total": 27
"system": {
"uuid": "04926959-b29d-4d1a-9987-e65246fcdc35",
"vendor": "QEMU",
"product": "Standard PC (Q35 + ICH9, 2009)",
"family": "",
"version": "pc-q35-5.2",
"sku": "",
"serial": "",
"type": "virtual-machine",
"firmware": {
"vendor": "EFI Development Kit II / OVMF",
"date": "02/06/2015",
"version": "0.0.0"
"chassis": {
"vendor": "QEMU",
"type": "Other",
"serial": "",
"motherboard": {
"vendor": "Canonical Ltd.",
"product": "LXD",
"serial": "",
"networks": {
"enp5s0": {
"addresses": [
"family": "inet",
"address": "10.10.191.29",
"netmask": "16",
"scope": "global"
"family": "inet6",
"address": "fe80::216:3eff:febd:37da",
"netmask": "64",
"scope": "link"
"counters": {
"bytes_received": 418560740,
"bytes_sent": 4020008,
"packets_received": 68877,
"packets_sent": 56980
"hwaddr": "00:16:3e:bd:37:da",
"mtu": 1500,
"state": "up",
"type": "broadcast",
"bond": null,
"bridge": null,
"vlan": null
"lo": {
"addresses": [
"family": "inet",
"address": "127.0.0.1",
"netmask": "8",
"scope": "local"
"family": "inet6",
"address": "::1",
"netmask": "128",
"scope": "local"
"counters": {
"bytes_received": 55390,
"bytes_sent": 55390,
"packets_received": 638,
"packets_sent": 638
"hwaddr": "",
"mtu": 65536,
"state": "up",
"type": "loopback",
"bond": null,
"bridge": null,
"vlan": null
Odd. It seems that maas is only seeing one disk during commissioning whereas the LXD config has 2.
Could you try recommissioning the machine, see if that fixes the issue?
Also does it happen consistently if you compose another machine with the same config?
yes it happens again, I have tested on different vms on different hosts but the hosts have zfsroot filesystem and that is the only similarity on the hosts.
what should I do with this?
Could you please also attach the output of maas-lshw ?
Are you able to deploy one of those VMs? If so, could you also check what shows under /dev/disk?
<?xml version="1.0" standalone="yes" ?>
<!-- generated by lshw- -->
<!-- GCC 9.3.0 -->
<!-- Linux 5.4.0-77-generic #86-Ubuntu SMP Thu Jun 17 02:35:03 UTC 2021 x86_64 -->
<!-- GNU libc 2 (glibc 2.31) -->
<list>
<node id="fit-beagle" claimed="true" class="system" handle="DMI:0100">
<description>Computer</description>
<product>Standard PC (Q35 + ICH9, 2009)</product>
<vendor>QEMU</vendor>
<version>pc-q35-5.2</version>
<width units="bits">64</width>
<configuration>
<setting id="boot" value="normal" />
<setting id="uuid" value="59699204-9DB2-1A4D-9987-E65246FCDC35" />
</configuration>
<capabilities>
<capability id="smbios-2.8" >SMBIOS version 2.8</capability>
<capability id="dmi-2.8" >DMI version 2.8</capability>
<capability id="vsyscall32" >32-bit processes</capability>
</capabilities>
<node id="core" claimed="true" class="bus" handle="DMI:0200">
<description>Motherboard</description>
<product>LXD</product>
<vendor>Canonical Ltd.</vendor>
<physid>0</physid>
<hints>
<hint name="icon" value="motherboard" />
</hints>
<node id="cpu" claimed="true" class="processor" handle="DMI:0400">
<description>CPU</description>
<product>Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz</product>
<vendor>Intel Corp.</vendor>
<physid>400</physid>
<businfo>cpu@0</businfo>
<slot>CPU 0</slot>
<size units="Hz">2000000000</size>
<capacity units="Hz">2000000000</capacity>
<configuration>
<setting id="cores" value="1" />
<setting id="enabledcores" value="1" />
<setting id="threads" value="1" />
</configuration>
<capabilities>
<capability id="fpu" >mathematical co-processor</capability>
<capability id="fpu_exception" >FPU exceptions reporting</capability>
<capability id="wp" />
<capability id="vme" >virtual mode extensions</capability>
<capability id="de" >debugging extensions</capability>
<capability id="pse" >page size extensions</capability>
<capability id="tsc" >time stamp counter</capability>
<capability id="msr" >model-specific registers</capability>
<capability id="pae" >4GB+ memory addressing (Physical Address Extension)</capability>
<capability id="mce" >machine check exceptions</capability>
<capability id="cx8" >compare and exchange 8-byte</capability>
<capability id="apic" >on-chip advanced programmable interrupt controller (APIC)</capability>
<capability id="sep" >fast system calls</capability>
<capability id="mtrr" >memory type range registers</capability>
<capability id="pge" >page global enable</capability>
<capability id="mca" >machine check architecture</capability>
<capability id="cmov" >conditional move instruction</capability>
<capability id="pat" >page attribute table</capability>
<capability id="pse36" >36-bit page size extensions</capability>
<capability id="clflush" />
<capability id="mmx" >multimedia extensions (MMX)</capability>
<capability id="fxsr" >fast floating point save/restore</capability>
<capability id="sse" >streaming SIMD extensions (SSE)</capability>
<capability id="sse2" >streaming SIMD extensions (SSE2)</capability>
<capability id="ss" >self-snoop</capability>
<capability id="syscall" >fast system calls</capability>
<capability id="nx" >no-execute bit (NX)</capability>
<capability id="pdpe1gb" />
<capability id="rdtscp" />
<capability id="x86-64" >64bits extensions (x86-64)</capability>
<capability id="constant_tsc" />
<capability id="arch_perfmon" />
<capability id="rep_good" />
<capability id="nopl" />
<capability id="xtopology" />
<capability id="cpuid" />
<capability id="tsc_known_freq" />
<capability id="pni" />
<capability id="pclmulqdq" />
<capability id="vmx" />
<capability id="ssse3" />
<capability id="cx16" />
<capability id="pcid" />
<capability id="sse4_1" />
<capability id="sse4_2" />
<capability id="x2apic" />
<capability id="popcnt" />
<capability id="tsc_deadline_timer" />
<capability id="aes" />
<capability id="xsave" />
<capability id="avx" />
<capability id="f16c" />
<capability id="rdrand" />
<capability id="hypervisor" />
<capability id="lahf_lm" />
<capability id="cpuid_fault" />
<capability id="pti" />
<capability id="ssbd" />
<capability id="ibrs" />
<capability id="ibpb" />
<capability id="stibp" />
<capability id="tpr_shadow" />
<capability id="vnmi" />
<capability id="flexpriority" />
<capability id="ept" />
<capability id="vpid" />
<capability id="fsgsbase" />
<capability id="tsc_adjust" />
<capability id="smep" />
<capability id="erms" />
<capability id="xsaveopt" />
<capability id="arat" />
<capability id="umip" />
<capability id="md_clear" />
<capability id="arch_capabilities" />
</capabilities>
<hints>
<hint name="icon" value="cpu" />
</hints>
</node>
<node id="memory" claimed="true" class="memory" handle="DMI:1000">
<description>System Memory</description>
<physid>1000</physid>
<size units="bytes">2147483648</size>
<capacity units="bytes">2147483648</capacity>
<configuration>
<setting id="errordetection" value="multi-bit-ecc" />
</configuration>
<capabilities>
<capability id="ecc" >Multi-bit error-correcting code (ECC)</capability>
</capabilities>
<hints>
<hint name="icon" value="memory" />
</hints>
<node id="bank" claimed="true" class="memory" handle="DMI:1100">
<description>DIMM RAM</description>
<physid>0</physid>
<slot>DIMM 0</slot>
<hints>
</hints>
</node>
</node>
<node id="firmware" claimed="true" class="memory">
<description>BIOS</description>
<vendor>EFI Development Kit II / OVMF</vendor>
<physid>0</physid>
<version>0.0.0</version>
<date>02/06/2015</date>
<size units="bytes">98304</size>
<capabilities>
<capability id="uefi" >UEFI specification is supported</capability>
<capability id="virtualmachine" >This machine is a virtual machine</capability>
</capabilities>
<hints>
<hint name="icon" value="chip" />
</hints>
</node>
<node id="pci" claimed="true" class="bridge" handle="PCIBUS:0000:00" modalias="pci:v00008086d000029C0sv00001AF4sd00001100bc06sc00i00">
<description>Host bridge</description>
<product>82G33/G31/P35/P31 Express DRAM Controller</product>
<vendor>Intel Corporation</vendor>
<physid>100</physid>
<subproduct>Red Hat, Inc.</subproduct>
<subvendor>Red Hat, Inc.</subvendor>
<businfo>pci@0000:00:00.0</businfo>
<version>00</version>
<width units="bits">32</width>
<clock units="Hz">33000000</clock>
<hints>
<hint name="pci.class" value="0x600" />
<hint name="pci.device" value="0x29C0" />
<hint name="pci.subdevice" value="0x1100" />
<hint name="pci.subvendor" value="0x1AF4" />
<hint name="pci.vendor" value="0x8086" />
</hints>
<node id="pci:0" claimed="true" class="bridge" handle="PCIBUS:0000:01" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<description>PCI bridge</description>
<product>QEMU PCIe Root port</product>
<vendor>Red Hat, Inc.</vendor>
<physid>1</physid>
<businfo>pci@0000:00:01.0</businfo>
<configuration>
<setting id="driver" value="pcieport" />
</configuration>
<capabilities>
<capability id="pci" />
<capability id="pciexpress" >PCI Express</capability>
<capability id="msix" >MSI-X</capability>
<capability id="normal_decode" />
<capability id="bus_master" >bus mastering</capability>
<capability id="cap_list" >PCI capabilities listing</capability>
</capabilities>
<resources>
<resource type="irq" value="21" />
<resource type="memory" value="c1a49000-c1a49fff" />
<resource type="ioport" value="e000(size=4096)" />
<resource type="memory" value="c1800000-c19fffff" />
<resource type="ioport" value="800000000(size=1048576)" />
</resources>
<hints>
<hint name="pci.class" value="0x604" />
<hint name="pci.device" value="0xC" />
<hint name="pci.vendor" value="0x1B36" />
</hints>
<node id="generic:0" claimed="true" class="generic" handle="PCI:0000:01:00.0" modalias="pci:v00001AF4d00001045sv00001AF4sd00001100bc00scFFi00">
<description>Unclassified device</description>
<product>Virtio memory balloon</product>
<physid>0</physid>
<businfo>pci@0000:01:00.0</businfo>
<version>01</version>
<configuration>
<setting id="driver" value="virtio-pci" />
<setting id="latency" value="0" />
</configuration>
<capabilities>
<capability id="pm" >Power Management</capability>
</capabilities>
<resources>
<resource type="iomemory" value="80-7f" />
<resource type="memory" value="800014000-800017fff" />
</resources>
<hints>
<hint name="pci.class" value="0xFF" />
<hint name="pci.device" value="0x1045" />
<hint name="pci.vendor" value="0x1AF4" />
</hints>
<node id="virtio0" class="generic">
<description>Virtual I/O device</description>
<physid>0</physid>
<businfo>virtio@0</businfo>
<configuration>
<setting id="driver" value="virtio_balloon" />
</configuration>
</node>
</node>
<node id="generic:1" claimed="true" class="generic" handle="PCI:0000:01:00.1" modalias="pci:v00001AF4d00001044sv00001AF4sd00001100bc00scFFi00">
<product>Virtio RNG</product>
<physid>0.1</physid>
<businfo>pci@0000:01:00.1</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="800010000-800013fff" />
</resources>
<hints>
<hint name="pci.device" value="0x1044" />
</hints>
<node id="virtio1" class="generic">
<physid>0</physid>
<businfo>virtio@1</businfo>
</node>
</node>
<node id="input:0" claimed="true" class="input" handle="PCI:0000:01:00.2" modalias="pci:v00001AF4d00001052sv00001AF4sd00001100bc09sc00i00">
<description>Keyboard controller</description>
<product>Virtio input</product>
<physid>0.2</physid>
<businfo>pci@0000:01:00.2</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1807000-c1807fff" />
<resource type="memory" value="80000c000-80000ffff" />
</resources>
<hints>
<hint name="pci.class" value="0x900" />
<hint name="pci.device" value="0x1052" />
</hints>
<node id="virtio2" class="generic">
<physid>0</physid>
<businfo>virtio@2</businfo>
</node>
</node>
<node id="input:1" claimed="true" class="input" handle="PCI:0000:01:00.3" modalias="pci:v00001AF4d00001052sv00001AF4sd00001100bc09sc80i00">
<description>Input device controller</description>
<physid>0.3</physid>
<businfo>pci@0000:01:00.3</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1806000-c1806fff" />
<resource type="memory" value="800008000-80000bfff" />
</resources>
<hints>
<hint name="pci.class" value="0x980" />
</hints>
<node id="virtio3" class="generic">
<physid>0</physid>
<businfo>virtio@3</businfo>
</node>
</node>
<node id="communication:0" claimed="true" class="communication" handle="PCI:0000:01:00.4" modalias="pci:v00001AF4d00001053sv00001AF4sd00001100bc07sc80i00">
<description>Communication controller</description>
<product>Red Hat, Inc.</product>
<physid>0.4</physid>
<businfo>pci@0000:01:00.4</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1805000-c1805fff" />
<resource type="memory" value="800004000-800007fff" />
</resources>
<hints>
<hint name="pci.class" value="0x780" />
<hint name="pci.device" value="0x1053" />
</hints>
<node id="virtio4" class="generic">
<physid>0</physid>
<businfo>virtio@4</businfo>
</node>
</node>
<node id="communication:1" claimed="true" class="communication" handle="PCI:0000:01:00.5" modalias="pci:v00001AF4d00001043sv00001AF4sd00001100bc07sc80i00">
<product>Virtio console</product>
<physid>0.5</physid>
<businfo>pci@0000:01:00.5</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1804000-c1804fff" />
<resource type="memory" value="800000000-800003fff" />
</resources>
<hints>
<hint name="pci.device" value="0x1043" />
</hints>
<node id="virtio5" class="generic">
<physid>0</physid>
<businfo>virtio@5</businfo>
<configuration>
<setting id="driver" value="virtio_console" />
</configuration>
</node>
</node>
<node id="usb" claimed="true" class="bus" handle="PCI:0000:01:00.6" modalias="pci:v00001B36d0000000Dsv00001AF4sd00001100bc0Csc03i30">
<description>USB controller</description>
<product>QEMU XHCI Host Controller</product>
<physid>0.6</physid>
<businfo>pci@0000:01:00.6</businfo>
<configuration>
<setting id="driver" value="xhci_hcd" />
</configuration>
<capabilities>
<capability id="xhci" />
</capabilities>
<resources>
<resource type="memory" value="c1800000-c1803fff" />
</resources>
<hints>
<hint name="icon" value="usb" />
<hint name="pci.class" value="0xC03" />
<hint name="pci.device" value="0xD" />
</hints>
<node id="usbhost:0" claimed="true" class="bus" handle="USB:1:1">
<product>xHCI Host Controller</product>
<vendor>Linux 5.4.0-77-generic xhci-hcd</vendor>
<physid>0</physid>
<businfo>usb@1</businfo>
<logicalname>usb1</logicalname>
<version>5.04</version>
<configuration>
<setting id="driver" value="hub" />
<setting id="slots" value="4" />
<setting id="speed" value="480Mbit/s" />
</configuration>
<capabilities>
<capability id="usb-2.00" >USB 2.0</capability>
</capabilities>
<hints>
<hint name="bus.icon" value="usb" />
<hint name="usb.bDeviceClass" value="0x9" />
<hint name="usb.bDeviceProtocol" value="0x1" />
<hint name="usb.bDeviceSubClass" value="0x0" />
<hint name="usb.idProduct" value="0x2" />
<hint name="usb.idVendor" value="0x1D6B" />
</hints>
</node>
<node id="usbhost:1" claimed="true" class="bus" handle="USB:2:1">
<physid>1</physid>
<businfo>usb@2</businfo>
<logicalname>usb2</logicalname>
<configuration>
<setting id="speed" value="5000Mbit/s" />
</configuration>
<capabilities>
<capability id="usb-3.00" />
</capabilities>
<hints>
<hint name="usb.bDeviceProtocol" value="0x3" />
<hint name="usb.idProduct" value="0x3" />
</hints>
</node>
</node>
</node>
<node id="pci:1" claimed="true" class="bridge" handle="PCIBUS:0000:02" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.1</physid>
<businfo>pci@0000:00:01.1</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a48000-c1a48fff" />
<resource type="ioport" value="d000(size=4096)" />
<resource type="memory" value="c1600000-c17fffff" />
<resource type="ioport" value="800100000(size=1048576)" />
</resources>
<hints>
</hints>
<node id="scsi" claimed="true" class="storage" handle="PCI:0000:02:00.0" modalias="pci:v00001AF4d00001048sv00001AF4sd00001100bc01sc00i00">
<description>SCSI storage controller</description>
<product>Virtio SCSI</product>
<physid>0</physid>
<businfo>pci@0000:02:00.0</businfo>
<configuration>
</configuration>
<capabilities>
<capability id="scsi" />
</capabilities>
<resources>
<resource type="memory" value="c1600000-c1600fff" />
<resource type="memory" value="800100000-800103fff" />
</resources>
<hints>
<hint name="icon" value="scsi" />
<hint name="pci.class" value="0x100" />
<hint name="pci.device" value="0x1048" />
</hints>
<node id="virtio6" class="generic">
<physid>0</physid>
<businfo>virtio@6</businfo>
<configuration>
<setting id="driver" value="virtio_scsi" />
</configuration>
</node>
</node>
</node>
<node id="pci:2" claimed="true" class="bridge" handle="PCIBUS:0000:03" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.2</physid>
<businfo>pci@0000:00:01.2</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a47000-c1a47fff" />
<resource type="ioport" value="c000(size=4096)" />
<resource type="memory" value="c1400000-c15fffff" />
<resource type="ioport" value="800200000(size=1048576)" />
</resources>
<hints>
</hints>
<node id="generic:0" claimed="true" class="generic" handle="PCI:0000:03:00.0" modalias="pci:v00001AF4d00001049sv00001AF4sd00001100bc00sc02i00">
<product>Virtio filesystem</product>
<physid>0</physid>
<businfo>pci@0000:03:00.0</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1403000-c1403fff" />
<resource type="memory" value="80020c000-80020ffff" />
</resources>
<hints>
<hint name="pci.class" value="0x2" />
<hint name="pci.device" value="0x1049" />
</hints>
<node id="virtio7" class="generic">
<physid>0</physid>
<businfo>virtio@7</businfo>
</node>
</node>
<node id="storage:0" claimed="true" class="storage" handle="PCI:0000:03:00.1" modalias="pci:v00001AF4d0000105Asv00001AF4sd00001100bc01sc80i00">
<description>Mass storage controller</description>
<businfo>pci@0000:03:00.1</businfo>
<configuration>
</configuration>
<capabilities>
<capability id="storage" />
</capabilities>
<resources>
<resource type="memory" value="c1402000-c1402fff" />
<resource type="memory" value="800208000-80020bfff" />
</resources>
<hints>
<hint name="icon" value="disc" />
<hint name="pci.class" value="0x180" />
<hint name="pci.device" value="0x105A" />
</hints>
<node id="virtio8" class="generic">
<physid>0</physid>
<businfo>virtio@8</businfo>
</node>
</node>
<node id="storage:1" claimed="true" class="storage" handle="PCI:0000:03:00.2" modalias="pci:v00001AF4d0000105Asv00001AF4sd00001100bc01sc80i00">
<businfo>pci@0000:03:00.2</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1401000-c1401fff" />
<resource type="memory" value="800204000-800207fff" />
</resources>
<hints>
</hints>
<node id="virtio9" class="generic">
<physid>0</physid>
<businfo>virtio@9</businfo>
</node>
</node>
<node id="generic:1" claimed="true" class="generic" handle="PCI:0000:03:00.3" modalias="pci:v00001AF4d00001049sv00001AF4sd00001100bc00sc02i00">
<businfo>pci@0000:03:00.3</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1400000-c1400fff" />
<resource type="memory" value="800200000-800203fff" />
</resources>
<hints>
</hints>
<node id="virtio10" class="generic">
<physid>0</physid>
<businfo>virtio@10</businfo>
</node>
</node>
</node>
<node id="pci:3" claimed="true" class="bridge" handle="PCIBUS:0000:04" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.3</physid>
<businfo>pci@0000:00:01.3</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a46000-c1a46fff" />
<resource type="ioport" value="b000(size=4096)" />
<resource type="memory" value="c0000000-c08fffff" />
<resource type="ioport" value="800300000(size=1048576)" />
</resources>
<hints>
</hints>
<node id="display" claimed="true" class="display" handle="PCI:0000:04:00.0" modalias="pci:v00001AF4d00001050sv00001AF4sd00001100bc03sc00i00">
<description>VGA compatible controller</description>
<product>Virtio GPU</product>
<physid>0</physid>
<businfo>pci@0000:04:00.0</businfo>
<configuration>
</configuration>
<capabilities>
<capability id="vga_controller" />
<capability id="rom" >extension ROM</capability>
</capabilities>
<resources>
<resource type="memory" value="c0000000-c07fffff" />
<resource type="memory" value="800300000-800303fff" />
<resource type="memory" value="c0800000-c0800fff" />
<resource type="memory" value="c0000-dffff" />
</resources>
<hints>
<hint name="icon" value="display" />
<hint name="pci.class" value="0x300" />
<hint name="pci.device" value="0x1050" />
</hints>
<node id="virtio11" class="generic">
<physid>0</physid>
<businfo>virtio@11</businfo>
</node>
</node>
</node>
<node id="pci:4" claimed="true" class="bridge" handle="PCIBUS:0000:05" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.4</physid>
<businfo>pci@0000:00:01.4</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a45000-c1a45fff" />
<resource type="ioport" value="a000(size=4096)" />
<resource type="memory" value="c1200000-c13fffff" />
<resource type="ioport" value="800400000(size=1048576)" />
</resources>
<hints>
</hints>
<node id="network" claimed="true" class="network" handle="PCI:0000:05:00.0" modalias="pci:v00001AF4d00001041sv00001AF4sd00001100bc02sc00i00">
<description>Ethernet controller</description>
<product>Virtio network device</product>
<physid>0</physid>
<businfo>pci@0000:05:00.0</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1200000-c1200fff" />
<resource type="memory" value="800400000-800403fff" />
<resource type="memory" value="c1240000-c127ffff" />
</resources>
<hints>
<hint name="icon" value="network" />
<hint name="pci.class" value="0x200" />
<hint name="pci.device" value="0x1041" />
</hints>
<node id="virtio12" claimed="true" class="network">
<description>Ethernet interface</description>
<physid>0</physid>
<businfo>virtio@12</businfo>
<logicalname>enp5s0</logicalname>
<serial>00:16:3e:bd:37:da</serial>
<configuration>
<setting id="autonegotiation" value="off" />
<setting id="broadcast" value="yes" />
<setting id="driver" value="virtio_net" />
<setting id="driverversion" value="1.0.0" />
<setting id="ip" value="10.10.191.29" />
<setting id="link" value="yes" />
<setting id="multicast" value="yes" />
</configuration>
<capabilities>
<capability id="ethernet" />
<capability id="physical" >Physical interface</capability>
</capabilities>
<hints>
</hints>
</node>
</node>
</node>
<node id="pci:5" claimed="true" class="bridge" handle="PCIBUS:0000:06" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.5</physid>
<businfo>pci@0000:00:01.5</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a44000-c1a44fff" />
<resource type="ioport" value="9000(size=4096)" />
<resource type="memory" value="c1000000-c11fffff" />
<resource type="ioport" value="800500000(size=2097152)" />
</resources>
<hints>
</hints>
</node>
<node id="pci:6" claimed="true" class="bridge" handle="PCIBUS:0000:07" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.6</physid>
<businfo>pci@0000:00:01.6</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a43000-c1a43fff" />
<resource type="ioport" value="8000(size=4096)" />
<resource type="memory" value="c0e00000-c0ffffff" />
<resource type="ioport" value="800700000(size=2097152)" />
</resources>
<hints>
</hints>
</node>
<node id="pci:7" claimed="true" class="bridge" handle="PCIBUS:0000:08" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>1.7</physid>
<businfo>pci@0000:00:01.7</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="memory" value="c1a42000-c1a42fff" />
<resource type="ioport" value="7000(size=4096)" />
<resource type="memory" value="c0c00000-c0dfffff" />
<resource type="ioport" value="800900000(size=2097152)" />
</resources>
<hints>
</hints>
</node>
<node id="pci:8" claimed="true" class="bridge" handle="PCIBUS:0000:09" modalias="pci:v00001B36d0000000Csv00001B36sd00000000bc06sc04i00">
<physid>2</physid>
<businfo>pci@0000:00:02.0</businfo>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="irq" value="22" />
<resource type="memory" value="c1a41000-c1a41fff" />
<resource type="ioport" value="6000(size=4096)" />
<resource type="memory" value="c0a00000-c0bfffff" />
<resource type="ioport" value="800b00000(size=2097152)" />
</resources>
<hints>
</hints>
</node>
<node id="isa" claimed="true" class="bridge" handle="PCI:0000:00:1f.0" modalias="pci:v00008086d00002918sv00001AF4sd00001100bc06sc01i00">
<description>ISA bridge</description>
<product>82801IB (ICH9) LPC Interface Controller</product>
<physid>1f</physid>
<businfo>pci@0000:00:1f.0</businfo>
<version>02</version>
<configuration>
<setting id="driver" value="lpc_ich" />
</configuration>
<capabilities>
<capability id="isa" />
</capabilities>
<resources>
<resource type="irq" value="0" />
</resources>
<hints>
<hint name="pci.class" value="0x601" />
<hint name="pci.device" value="0x2918" />
</hints>
</node>
<node id="sata" claimed="true" class="storage" handle="PCI:0000:00:1f.2" modalias="pci:v00008086d00002922sv00001AF4sd00001100bc01sc06i01">
<description>SATA controller</description>
<product>82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode]</product>
<physid>1f.2</physid>
<businfo>pci@0000:00:1f.2</businfo>
<configuration>
<setting id="driver" value="ahci" />
</configuration>
<capabilities>
<capability id="sata" />
<capability id="msi" >Message Signalled Interrupts</capability>
<capability id="ahci_1.0" />
</capabilities>
<resources>
<resource type="irq" value="46" />
<resource type="ioport" value="1040(size=32)" />
<resource type="memory" value="c1a40000-c1a40fff" />
</resources>
<hints>
<hint name="pci.class" value="0x106" />
<hint name="pci.device" value="0x2922" />
</hints>
</node>
<node id="serial" claimed="true" class="bus" handle="PCI:0000:00:1f.3" modalias="pci:v00008086d00002930sv00001AF4sd00001100bc0Csc05i00">
<description>SMBus</description>
<product>82801I (ICH9 Family) SMBus Controller</product>
<physid>1f.3</physid>
<businfo>pci@0000:00:1f.3</businfo>
<configuration>
<setting id="driver" value="i801_smbus" />
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="irq" value="16" />
<resource type="ioport" value="1000(size=64)" />
</resources>
<hints>
<hint name="pci.class" value="0xC05" />
<hint name="pci.device" value="0x2930" />
</hints>
</node>
</node>
<node id="pnp00:00" claimed="true" class="input">
<product>PnP device PNP0303</product>
<physid>1</physid>
<configuration>
<setting id="driver" value="i8042 kbd" />
</configuration>
<capabilities>
<capability id="pnp" />
</capabilities>
</node>
<node id="pnp00:01" claimed="true" class="input">
<product>PnP device PNP0f13</product>
<physid>2</physid>
<configuration>
<setting id="driver" value="i8042 aux" />
</configuration>
<capabilities>
</capabilities>
</node>
<node id="pnp00:02" claimed="true" class="communication">
<product>PnP device PNP0501</product>
<physid>3</physid>
<configuration>
<setting id="driver" value="serial" />
</configuration>
<capabilities>
</capabilities>
</node>
<node id="pnp00:03" claimed="true" class="system">
<product>PnP device PNP0b00</product>
<physid>4</physid>
<configuration>
<setting id="driver" value="rtc_cmos" />
</configuration>
<capabilities>
</capabilities>
</node>
<node id="scsi" claimed="true" class="storage">
<physid>5</physid>
<logicalname>scsi0</logicalname>
<node id="disk" claimed="true" class="disk" handle="SCSI:00:00:02:01">
<description>SCSI Disk</description>
<product>QEMU HARDDISK</product>
<physid>0.2.1</physid>
<businfo>scsi@0:0.2.1</businfo>
<logicalname>/dev/sda</logicalname>
<dev>8:0</dev>
<version>2.5+</version>
<size units="bytes">8000004096</size>
<configuration>
<setting id="ansiversion" value="5" />
<setting id="logicalsectorsize" value="512" />
<setting id="sectorsize" value="512" />
</configuration>
<capabilities>
<capability id="5400rpm" >5400 rotations per minute</capability>
</capabilities>
<hints>
<hint name="bus.icon" value="scsi" />
</hints>
</node>
</node>
</node>
</node>
</list>
This is something about lxd because I have another node which is Proxmox and it does not have this issue.
I also checked the LXD vm and it does not have second disk it seems that lxd does not attach the second disk to the vm.
It would be good to have a bit more info on your LXD setup on the host.
Could you please paste the output of the following:
lxc storage show default
and (the volume ID comes from the machine config, so please adjust if needed)
lxc storage volume show default maas-d2bd76a5-83a7-41e5-b8f5-5418e4f14628
ubuntu@ubuntu-hdd:~$ lxc storage volume show default maas-d2bd76a5-83a7-41e5-b8f5-5418e4f14628
config:
description: ""
type: custom
used_by:
- /1.0/instances/fit-beagle?project=maas
content_type: filesystem
ubuntu@ubuntu-hdd:~$ lxc storage show default
config:
source: /var/snap/lxd/common/lxd/storage-pools/default
description: ""
driver: dir
used_by:
- /1.0/instances/Directadmin?project=maas
- /1.0/instances/directadmin-ubuntu?project=maas
- /1.0/instances/kube-master2?project=maas
- /1.0/instances/maas-test?project=maas
- /1.0/instances/mighty-loon?project=maas
- /1.0/instances/owncloud?project=maas
- /1.0/instances/sv1-dolabi?project=maas
- /1.0/instances/test1?project=maas
- /1.0/instances/united-chimp?project=maas
- /1.0/profiles/default
- /1.0/storage-pools/default/volumes/custom/maas-0fd8c747-2d6f-4dd5-ba76-4939f6076b05
- /1.0/storage-pools/default/volumes/custom/maas-a6ae1d72-fdb8-4b2c-9760-a0fd110dc317
- /1.0/storage-pools/default/volumes/custom/maas-c4b6f0a3-bd4b-473f-9cd1-f490057bd28b
- /1.0/storage-pools/default/volumes/custom/maas-d2bd76a5-83a7-41e5-b8f5-5418e4f14628
- /1.0/storage-pools/default/volumes/custom/test
status: Created
locations:
- none
So, the issue there is that the volume is created with content_type: filesystem, whereas it should be created as block (which is what MAAS does).
I’m not quite sure why. Is this a snap or deb-based maas?
Depending on which, could you paste snap info maas or dpkg -l | grep maas output?
This is snap maas.
summary: Metal as a Service
publisher: Canonical✓
store-url: https://snapcraft.io/maas
contact: https://discourse.maas.io/
license: unset
description: |
**MAAS - Very fast server provisioning**
Metal as a Service -- MAAS -- lets you treat physical servers like virtual machines in the cloud.
Rather than having to manage each server individually, MAAS turns your bare metal into an elastic
cloud-like resource.
What does that mean in practice? Tell MAAS about the machines you want it to manage and it will
boot them, check the hardware's okay, and have them waiting for when you need them. You can then
pull nodes up, tear them down and redeploy them at will; just as you can with virtual
When you're ready to deploy a service, MAAS gives your tool of choice (e.g. Ansible, Chef, Puppet,
SALT, Juju) the nodes it needs to power that service. It's as simple as that: no need to manually
provision, check and, afterwards, clean-up. As your needs change, you can easily scale services up
or down. Need more power for your Hadoop cluster for a few hours? Simply tear down one of your
Nova compute nodes and redeploy it to Hadoop. When you're done, it's just as easy to give the node
back to Nova.
MAAS is ideal where you want the flexibility of the cloud, and the hassle-free power of Juju
charms, but you need to deploy to bare metal.
commands:
- maas
- maas.power
services:
maas.supervisor: simple, enabled, active
snap-id: shY22YTZ3RhJJDOj0MfmShTNZTEb1Jiq
tracking: 3.0/stable
refresh-date: 18 days ago, at 14:56 UTC
channels:
3.0/stable: 3.0.0-10029-g.986ea3e45 2021-06-22 (15003) 141MB -
3.0/candidate: ↑
3.0/beta: ↑
3.0/edge: 3.0.0-10032-g.38a5c795a 2021-06-29 (15128) 141MB -
latest/stable: –
latest/candidate: –
latest/beta: –
latest/edge: 3.1.0~alpha1-10490-g.0d65989eb 2021-08-24 (16041) 139MB -
2.9/stable: 2.9.2-9165-g.c3e7848d1 2021-04-16 (12555) 149MB -
2.9/candidate: 2.9.2-9165-g.c3e7848d1 2021-03-22 (12555) 149MB -
2.9/beta: ↑
2.9/edge: 2.9.3~beta1-9197-g.afe92bb63 2021-07-16 (15419) 143MB -
2.8/stable: 2.8.6-8602-g.07cdffcaa 2021-04-20 (13516) 135MB -
2.8/candidate: ↑
2.8/beta: ↑
2.8/edge: 2.8.6-8609-g.d77f501ee 2021-08-17 (15848) 135MB -
2.7/stable: 2.7.3-8290-g.ebe2b9884 2020-08-21 (8724) 144MB -
2.7/candidate: ↑
2.7/beta: ↑
2.7/edge: 2.7.3-8297-g.68a767295 2021-02-16 (11806) 143MB -
installed: 3.0.0-10029-g.986ea3e45 (15003) 141MB -
What’s the version of your LXD server? (from lxc version)
