Deletes a resource pool.
maas $PROFILE resource-pool delete [--help] [-d] [-k] id [data ...]
Positional arguments
- id
Command-line options
| Option | Effect |
Returns a resource pool.
maas $PROFILE resource-pool read [--help] [-d] [-k] id [data ...]
- id
| Option | Effect |
Updates a resource pool’s name or description.
maas $PROFILE resource-pool update [--help] [-d] [-k] id [data ...]
- id
Note that any other given parameters are silently ignored.
Keyword “description”
Optional String. A brief description of the resource pool.
Keyword “name”
Optional String. The resource pool’s new name.
| Option | Effect |
Creates a new resource pool.
maas $PROFILE resource-pools create [--help] [-d] [-k] [data ...]
Keyword “name” Required. The new resource pool’s name.
Type: String.
Optional String. A brief description of the new resource pool.
| Option | Effect |
Get a listing of all resource pools.
maas $PROFILE resource-pools read [--help] [-d] [-k] [data ...]
Note that there is always at least one resource pool: default.
| Option | Effect |
