- How do I set up PostgreSQL for the region?
- How do I add a new region host?
- How can I improve region controller performance?
On the primary database host, edit file /etc/postgresql/9.5/main/pg_hba.conf
to allow the eventual secondary API server to contact the primary PostgreSQL database. Include the below line, replacing
$SECONDARY_API_SERVER_IP
with the IP address of the host that will contain the secondary API server:
Add a new region host
On a secondary host, add the new region controller by installing maas-region-api
You will need the /etc/maas/regiond.conf
file from the primary API server. Below, we assume it can be copied (scp) from the ‘ubuntu’ account home directory using password authentication (adjust otherwise). The local_config_set
command will edit that file by pointing to the host that contains the primary PostgreSQL database. Do not worry: MAAS will rationalise the DNS (bind9
) configuration options so that they match those used within MAAS:
sudo systemctl restart bind9
/var/log/maas/regiond.log
/var/log/maas/maas.log
/var/log/syslog
Increasing the number of workers will also increase the number of required database connections by 11 per extra worker. This may required PostgreSQL to have an increased number of allowed connections; please see PostgreSQL High Availability section for more information to increase the connections.
To increase the number of workers, simply edit regiond.conf (/etc/maas/regiond.conf)
and set num_workers
. For example:
num_workers: 8
