Hi all,
I am following this tutorial https://www.youtube.com/watch?v=sLADei_c9Qg, to deploy Kubernetes with MAAS and juju.
Yesterday everything was working fine and I switch off the 3 maas VM and the host server. Today when restarting it I could see that Juju could not start VM 3:
So I tried to ssh to the metal-3 but I was unsuccessful, however I managed to ssh to the 2 others Vms:
❯ juju ssh ubuntu@10.10.10.22
Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.4.0-104-generic x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
System information as of Wed Mar 16 09:55:42 UTC 2022
System load: 0.01 Processes: 246
Usage of /: 45.0% of 22.30GB Users logged in: 0
Memory usage: 12% IPv4 address for br-enp5s0: 10.10.10.22
Swap usage: 0% IPv4 address for lxdbr0: 10.84.156.1
* Super-optimized for small spaces - read how we shrank the memory
footprint of MicroK8s to make it the smallest full K8s around.
https://ubuntu.com/blog/microk8s-memory-optimisation
0 updates can be applied immediately.
*** System restart required ***
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
ubuntu@metal-2:~$ exit
logout
Connection to 10.10.10.22 closed.
❯ juju ssh ubuntu@10.10.10.21
System information as of Wed Mar 16 09:55:50 UTC 2022
System load: 0.05 Processes: 259
Usage of /: 69.5% of 22.30GB Users logged in: 0
Memory usage: 15% IPv4 address for br-enp5s0: 10.10.10.21
Swap usage: 0% IPv4 address for lxdbr0: 10.184.251.1
3 updates can be applied immediately.
3 of these updates are standard security updates.
To see these additional updates run: apt list --upgradable
Last login: Wed Mar 16 09:46:09 2022 from 10.10.10.1
ubuntu@metal-1:~$ exit
logout
Connection to 10.10.10.21 closed.
❯ juju ssh ubuntu@10.10.10.23
ssh: connect to host 10.10.10.23 port 22: Connection refused
I also tried the rescue mode on 10.10.10.23 . When I do this, I manage to connect by ssh but I got a Permission denied (publickey):
juju ssh ubuntu@10.10.10.23 The authenticity of host '10.10.10.23 (10.10.10.23)' can't be established. ECDSA key fingerprint is SHA256:GrlGZtORryfRApZVxK0bSyFgy88arJ4ftQr6zfuucn8. Are you sure you want to continue connecting (yes/no/[fingerprint])? yes Warning: Permanently added '10.10.10.23' (ECDSA) to the list of known hosts. ubuntu@10.10.10.23: Permission denied (publickey).
