Four questions you may have:
- How do I configure a machine’s power type?
- Show me a catalogue of power parameters, by type.
- Can you give me an example of the virsh power type?
- Which BMC drivers are supported?
HP Moonshot - iLO4 (IPMI)
Form field | Description | Required |
Power address | IP address of unit | Required |
Power user | Username to login | Optional |
Power password | Password to access unit | Optional |
Power hardware address | Hardware address of unit | Required |
HP Moonshot - iLO Chassis Manager
IP for MSCM CLI API | IP address of unit | Required |
MSCM CLI API user | Username to login | Optional |
MSCM CLI API password | Password to access unit | Optional |
Node ID | cXnY | Required |
- where | X = cartridge number | |
Y = node number |
Microsoft OCS - Chassis Manager
Power port | Port where unit is attached | Optional |
Blade ID | Blade ID (usu. 1-24) | Required |
OpenStack Nova
Host UUID | Host UUID | Required |
Tenant name | Tenant name | Required |
Username | Username to login | Required |
Password | Password to access unit | Required |
Auth URL | URL to access unit | Required |
OpenBMC Power Driver
OpenBMC address | IP address of unit | Required |
OpenBMC user | Username to login | Required |
OpenBMC password | Password to access unit | Required |
Christmann RECS-Box Power Driver
Node ID | Node ID | Required |
Redfish
Redfish address | IP address of unit | Required |
Redfish user | Username to login | Required |
Redfish password | Password to access unit | Required |
Node ID | Node ID | Optional |
SeaMicro 15000
Form field | Description | Choices | Required |
Power control type | Password to access unit | IPMI | Required |
REST API v0.9 | |||
REST API v2.0 |
Cisco UCS Manager
Server UUID | Server UUID | Required |
URL for XML API | XML API URL | Required |
API user | API user | Optional |
API password | API password | Optional |
virsh - libvirt KVM
Address | URL of VM | Required |
Password | API password | Optional |
Virsh VM ID | libvirt VM UUID | Required |
VMware
VM Name | VM name (if UUID unknown) | Optional |
VM UUID | VM UUID (if known) | Optional |
VMware IP | IP address of VM | Required |
VMware username | Username to access VM | Required |
VMware password | Password to access VM | Required |
VMware API port | VMware API port number | Optional |
VMware API protocol | VMware API protocol | Optional |
Facebook’s Wedge
IP address | IP address of unit | Required |
Power user | Username to access unit | Optional |
Configure a machine’s power type
To (re)configure a machine’s power type, first find the machine’s $SYSTEM_ID with the following recipe:
maas admin machines read | jq -r '(["HOSTNAME","SIS'S"] | (., map(length*"-"))),
Next, use the MAAS CLI command maas machines...
to (re)set the machine’s power type, like this:
maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
where $POWER_TYPE can have the following values:
CLI power_type code | Description |
amt | Intel AMT |
apc | American Power Conversion (APC) PDU |
dli | Digital Loggers, Inc. PDU |
eaton | Eaton PDU |
hmc | IBM Hardware Management Console (HMC) |
lxd | LXD VM |
ipmi | IPMI |
manual | Manual power configuration |
moonshot | HP Moonshot - iLO4 (IPMI) |
mscm | HP Moonshot - iLO Chassis Manager |
msftocs | Microsoft OCS - Chassis Manager |
nova | OpenStack Nova |
openbmc | OpenBMC Power Driver |
recs_box | Christmann RECS-Box Power Driver |
redfish | Redfish |
sm15k | SeaMicro 15000 |
ucsm | Cisco UCS Manager |
virsh | libvirt KVM |
vmware | VMware |
wedge | Facebook’s Wedge |
Note the required and optional parameters associated with each power type.
Once you’ve successfully processed the command (as indicated by a stream of JSON, headed by “Success!”), MAAS performs a power check on the machine. A successful power check is a good indication that MAAS can properly communicate with the machine, that is, it should quickly result in a power status of “Power off”. A failed attempt will return errors that should guide you to fix your power_parameters.
Power catalogue
Intel AMT
All parameters are entered as key=value
, e.g., power_type=amt
. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
Parameter | Description | Required |
power_type |
amt |
Required |
power_address |
power_pass |
, e.g., power_type=apc
power_type |
apc |
Required |
power_address |
node_outlet |
PDU node outlet number | Required |
power_on_delay |
outlet power ON delay | Optional, default=5 |
, e.g., power_type=dli
power_type |
dli |
Required |
outlet_id |
outlet ID | Required |
power_address |
power_user |
power_pass |
Eaton PDU
, e.g., power_type=eaton
power_type |
eaton |
Required |
power_address |
node_outlet |
power_on_delay |
, e.g., power_type=hmc
power_type |
hmc |
Required |
power_address |
server_name |
HMC managed server name | Required |
lpar |
HMC logical partition of unit | Required |
power_user |
power_pass |
LXD VMs
, e.g., power_type=lxd
power_type |
lxd |
Required |
power_address |
instance_name |
LXD container instance name | Required |
power_pass |
IPMI
, e.g., power_type=ipmi
Parameter | Description | Choices | Required |
power_type |
ipmi |
Required | |
power_driver |
Power driver | LAN [IPMI 1.5] |
Required |
LAN_2_0 [IPMI 2.0] |
power_boot_type |
Boot type | Automatic |
Required |
Legacy boot |
EFI boot |
Manual power configuration means exactly that – manually configured at the unit. The only MAAS CLI parameter is power_type=amt
, e.g., power_type=moonshot
power_type | moonshot` |
Required | |
power_address |
power_hwaddress |
power_user |
power_pass |
, e.g., power_type=mscm
power_type | mscm` |
Required | |
power_address |
node_id |
cXnY | Required |
Y = node number | ||
power_user |
power_pass |
, e.g., power_type=msftocs
power_type | msftocs` |
Required | |
power_address |
blade_id |
power_port |
power_user |
power_pass |
OpenStack Nova
, e.g., power_type=nova
power_type | nova` |
Required | |
nova_id |
os_tenantname |
os_username |
os_password |
os_authurl |
, e.g., power_type=openbmc
power_type |
openbmc |
Required |
power_address |
power_user |
power_pass |
, e.g., power_type=recs_box
power_type | recs_box` |
Required | |
node_id |
power_address |
power_port |
power_user |
power_pass |
Redfish
, e.g., power_type=redfish
power_type | redfish` |
Required | |
power_address |
power_user |
power_pass |
node_id |
SeaMicro 15000
, e.g., power_type=sm15k
power_type |
sm15k |
Required | |
power_control |
Password to access unit | ipmi | Required |
restapi | |||
restapi2 |
Cisco UCS Manager
, e.g., power_type=ucsm
power_type |
ucsm |
Required |
uuid |
power_address |
URL for XML API | Required |
power_user |
power_pass |
virsh - libvirt KVM
, e.g., power_type=virsh
power_type |
virsh |
Required |
power_id |
power_address |
power_pass |
VMware
, e.g., power_type=vmware
power_type |
vmware |
Required |
power_vm_name |
power_uuid |
power_address |
power_user |
power_pass |
power_port |
power_protocol |
Facebook’s Wedge
power_type |
wedge |
Required |
power_address |
power_user |
power_pass |
Consider a machine backed by a KVM, accessed via virsh
. You can create a corresponding MAAS machine and set its power parameters with a command like this one:
maas admin machines create \
architecture=amd64 \
power_type=virsh \
power_parameters_power_id=f677a842-571c-4e65-adc9-11e2cf92d363 \
If successful, this will return:
Machine-readable output follows this announcement. The JSON generated by this command is shown in the detail block.
MAAS command JSON response
``` { "storage": 0.0, "tag_names": [], "special_filesystems": [], "memory": 0, "boot_disk": null, "virtualblockdevice_set": [], "hardware_info": { "system_vendor": "Unknown", "system_product": "Unknown", "system_family": "Unknown", "system_version": "Unknown", "system_sku": "Unknown", "system_serial": "Unknown", "cpu_model": "Unknown", "mainboard_vendor": "Unknown", "mainboard_product": "Unknown", "mainboard_serial": "Unknown", "mainboard_version": "Unknown", "mainboard_firmware_vendor": "Unknown", "mainboard_firmware_date": "Unknown", "mainboard_firmware_version": "Unknown", "chassis_vendor": "Unknown", "chassis_type": "Unknown", "chassis_serial": "Unknown", "chassis_version": "Unknown" }, "address_ttl": null, "memory_test_status": -1, "other_test_status_name": "Unknown", "osystem": "", "status_message": "Commissioning", "netboot": true, "physicalblockdevice_set": [], "node_type": 0, "cpu_test_status": -1, "memory_test_status_name": "Unknown", "bcaches": [], "storage_test_status": 0, "system_id": "bhxws3", "status": 1, "commissioning_status": 0, "power_type": "virsh", "locked": false, "numanode_set": [ { "index": 0, "memory": 0, "cores": [] } ], "bios_boot_method": null, "fqdn": "ace-swan.maas", "node_type_name": "Machine", "hostname": "ace-swan", "volume_groups": [], "testing_status": 0, "network_test_status": -1, "other_test_status": -1, "interface_test_status": -1, "hwe_kernel": null, "blockdevice_set": [], "testing_status_name": "Pending", "power_state": "unknown", "min_hwe_kernel": "", "owner": "admin", "distro_series": "", "storage_test_status_name": "Pending", "cpu_speed": 0, "swap_size": null, "cpu_test_status_name": "Unknown", "hardware_uuid": null, "architecture": "amd64/generic", "pool": { "name": "default", "description": "Default pool", "id": 0, "resource_uri": "/MAAS/api/2.0/resourcepool/0/" }, "cache_sets": [], "pod": null, "iscsiblockdevice_set": [], "disable_ipv4": false, "status_action": "", "boot_interface": { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" }, "cpu_count": 0, "domain": { "authoritative": true, "ttl": null, "resource_record_count": 0, "name": "maas", "is_default": true, "id": 0, "resource_uri": "/MAAS/api/2.0/domains/0/" }, "current_testing_result_id": 7, "default_gateways": { "ipv4": { "gateway_ip": null, "link_id": null }, "ipv6": { "gateway_ip": null, "link_id": null } }, "interface_set": [ { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" } ], "status_name": "Commissioning", "commissioning_status_name": "Pending", "owner_data": {}, "ip_addresses": [], "raids": [], "network_test_status_name": "Unknown", "description": "", "current_commissioning_result_id": 6, "interface_test_status_name": "Unknown", "current_installation_result_id": null, "zone": { "name": "default", "description": "", "id": 1, "resource_uri": "/MAAS/api/2.0/zones/default/" }, "resource_uri": "/MAAS/api/2.0/machines/bhxws3/" } ```Which BMC drivers are supported
Tell me about BMC
Power Driver (X=supported) | PXE Next Boot | Power Querying | Chassis/Pod Configuration | Enhanced UI Error Reporting | BMC Enlistment |
American Power Conversion (APC) - PDU | |||||
Cisco UCS Manager | X | X | X | ||
Digital Loggers, Inc. - PDU | |||||
Facebook's Wedge *
HP Moonshot - iLO Chassis Manager | X | X | X | ||
HP Moonshot - iLO4 (IPMI) | X | X | X | ||
IBM Hardware Management Console (HMC) | X | X | |||
IPMI | X | X | X | X | |
Intel AMT | X | X | X | ||
Manual | |||||
Microsoft OCS - Chassis Manager | X | X | X | ||
OpenStack Nova | X | ||||
Rack Scale Design | X | X | X | ||
SeaMicro 15000 | X | X | X | ||
Sentry Switch CDU - PDU | |||||
VMWare | X | X | X | ||
Virsh (virtual systems) | X | X | X |
The ‘Facebook’s Wedge’ OpenBMC power driver is considered experimental at this time.
