Four questions you may have:
- How do I configure a machine’s power type?
- Show me a catalogue of power parameters, by type.
- Can you give me an example of the virsh power type?
- Which BMC drivers are supported?
| CLI power_type code |
Description |
| amt |
Intel AMT |
| apc |
American Power Conversion (APC) PDU |
| dli |
Digital Loggers, Inc. PDU |
| hmc |
IBM Hardware Management Console (HMC) |
| lxd |
LXD VM |
| ipmi |
IPMI |
| manual |
Manual power configuration |
| moonshot |
HP Moonshot - iLO4 (IPMI) |
| mscm |
HP Moonshot - iLO Chassis Manager |
| msftocs |
Microsoft OCS - Chassis Manager |
| nova |
OpenStack Nova |
| openbmc |
OpenBMC Power Driver |
| recs_box |
Christmann RECS-Box Power Driver |
| redfish |
Redfish |
| sm15k |
SeaMicro 15000 |
| ucsm |
Cisco UCS Manager |
| virsh |
libvirt KVM |
| vmware |
VMware |
| wedge |
Facebook’s Wedge |
| Form field |
Description |
Required |
| Power password |
Password to access unit |
Optional |
| Power address |
IP address of unit |
Required |
| Form field |
Description |
Required |
| IP for APC PDU |
Required |
| APU PDU node outlet number (1-16) |
PDU node outlet number |
Required |
| Power ON outlet delay (seconds) |
outlet power ON delay |
Optional, default=5 |
| Form field |
Description |
Required |
| Outlet ID |
outlet ID |
Required |
| Power address |
Required |
| Power user |
Username to login |
Optional |
| Power password |
Optional |
| Form field |
Description |
Required |
| IP for HMC |
Required |
| HMC username |
Username to login |
Optional |
| HMC password |
Optional |
| HMC Managed System server name |
HMC managed server name |
Required |
| HMC logical partition |
HMC logical partition of unit |
Required |
| Form field |
Description |
Required |
| LXD address |
Required |
| Instance name |
LXD container instance name |
Required |
| LXD password |
Optional |
| Form field |
Description |
Choices |
Required |
| Power driver |
Power driver |
LAN [IPMI 1.5] |
Required |
LAN_2_0 [IPMI 2.0] |
| Power boot type |
Boot type |
Automatic |
Required |
Legacy boot |
EFI boot |
| Form field |
Description |
Required |
| Power address |
Required |
| Power user |
Username to login |
Optional |
| Power password |
Optional |
| Power hardware address |
Hardware address of unit |
Required |
| Form field |
Description |
Required |
| IP for MSCM CLI API |
Required |
| MSCM CLI API user |
Username to login |
Optional |
| MSCM CLI API password |
Optional |
| Node ID |
cXnY |
Required |
| - where |
X = cartridge number |
Y = node number |
| Form field |
Description |
Required |
| Power address |
Required |
| Power port |
Port where unit is attached |
Optional |
| Power user |
Username to login |
Optional |
| Power password |
Optional |
| Blade ID |
Blade ID (usu. 1-24) |
Required |
| Form field |
Description |
Required |
| Host UUID |
Host UUID |
Required |
| Tenant name |
Tenant name |
Required |
| Username |
Username to login |
Required |
| Password |
Required |
| Auth URL |
URL to access unit |
Required |
| Form field |
Description |
Required |
| OpenBMC address |
Required |
| OpenBMC user |
Username to login |
Required |
| OpenBMC password |
Required |
| Form field |
Description |
Required |
| Node ID |
Node ID |
Required |
| Power address |
Required |
| Power port |
Optional |
| Power user |
Username to login |
Optional |
| Power password |
Optional |
| Form field |
Description |
Required |
| Redfish address |
Required |
| Redfish user |
Username to login |
Required |
| Redfish password |
Required |
| Node ID |
Node ID |
Optional |
| Form field |
Description |
Choices |
Required |
| Power control type |
IPMI |
Required |
REST API v0.9 |
REST API v2.0 |
| Form field |
Description |
Required |
| Server UUID |
Server UUID |
Required |
| URL for XML API |
XML API URL |
Required |
| API user |
API user |
Optional |
| API password |
API password |
Optional |
| Form field |
Description |
Required |
| Address |
URL of VM |
Required |
| Password |
API password |
Optional |
| Virsh VM ID |
libvirt VM UUID |
Required |
| Form field |
Description |
Required |
| VM Name |
VM name (if UUID unknown) |
Optional |
| VM UUID |
VM UUID (if known) |
Optional |
| VMware IP |
IP address of VM |
Required |
| VMware username |
Username to access VM |
Required |
| VMware password |
Password to access VM |
Required |
| VMware API port |
VMware API port number |
Optional |
| VMware API protocol |
Optional |
| Form field |
Description |
Required |
| IP address |
Required |
| Power user |
Username to access unit |
Optional |
| Power password |
Optional |
The machine’s hostname – according to MAAS – is a randomly chosen string (here dear.ant). You should change this hostname to something descriptive, that helps you remember why this machine is in your MAAS network.
Tell me about BMC
| Power Driver (X=supported) |
PXE Next Boot |
Power Querying |
Chassis/Pod Configuration |
Enhanced UI Error Reporting |
BMC Enlistment |
| American Power Conversion (APC) - PDU |
| Cisco UCS Manager |
X |
X |
X |
| Digital Loggers, Inc. - PDU |
Facebook's Wedge *
X |
X |
X |
X |
X |
X |
X |
X |
| IPMI |
X |
X |
X |
X |
| Intel AMT |
X |
X |
X |
| Manual |
X |
X |
X |
| OpenStack Nova |
X |
| Rack Scale Design |
X |
X |
X |
| SeaMicro 15000 |
X |
X |
X |
| Sentry Switch CDU - PDU |
| VMWare |
X |
X |
X |
| Virsh (virtual systems) |
X |
X |
X |
