Four questions you may have:
- How do I configure a machine’s power type?
- Show me a catalogue of power parameters, by type.
- Can you give me an example of the virsh power type?
- Which BMC drivers are supported?
HP Moonshot - iLO4 (IPMI)
| Form field | Description | Required |
| Power address | IP address of unit | Required |
| Power user | Username to login | Optional |
| Power password | Password to access unit | Optional |
| Power hardware address | Hardware address of unit | Required |
HP Moonshot - iLO Chassis Manager
| IP for MSCM CLI API | IP address of unit | Required |
| MSCM CLI API user | Username to login | Optional |
| MSCM CLI API password | Password to access unit | Optional |
| Node ID | cXnY | Required |
| - where | X = cartridge number | |
| Y = node number |
Microsoft OCS - Chassis Manager
| Power port | Port where unit is attached | Optional |
| Blade ID | Blade ID (usu. 1-24) | Required |
OpenStack Nova
| Host UUID | Host UUID | Required |
| Tenant name | Tenant name | Required |
| Username | Username to login | Required |
| Password | Password to access unit | Required |
| Auth URL | URL to access unit | Required |
OpenBMC Power Driver
| OpenBMC address | IP address of unit | Required |
| OpenBMC user | Username to login | Required |
| OpenBMC password | Password to access unit | Required |
Christmann RECS-Box Power Driver
| Node ID | Node ID | Required |
Redfish
| Redfish address | IP address of unit | Required |
| Redfish user | Username to login | Required |
| Redfish password | Password to access unit | Required |
| Node ID | Node ID | Optional |
SeaMicro 15000
| Form field | Description | Choices | Required |
| Power control type | Password to access unit | IPMI | Required |
| REST API v0.9 | |||
| REST API v2.0 |
Cisco UCS Manager
| Server UUID | Server UUID | Required |
| URL for XML API | XML API URL | Required |
| API user | API user | Optional |
| API password | API password | Optional |
virsh - libvirt KVM
| Address | URL of VM | Required |
| Password | API password | Optional |
| Virsh VM ID | libvirt VM UUID | Required |
VMware
| VM Name | VM name (if UUID unknown) | Optional |
| VM UUID | VM UUID (if known) | Optional |
| VMware IP | IP address of VM | Required |
| VMware username | Username to access VM | Required |
| VMware password | Password to access VM | Required |
| VMware API port | VMware API port number | Optional |
| VMware API protocol | VMware API protocol | Optional |
Facebook’s Wedge
| IP address | IP address of unit | Required |
| Power user | Username to access unit | Optional |
Configure a machine’s power type
To (re)configure a machine’s power type, first find the machine’s $SYSTEM_ID with the following recipe:
maas admin machines read | jq -r '(["HOSTNAME","SIS'S"] | (., map(length*"-"))),
Next, use the MAAS CLI command maas machines... to (re)set the machine’s power type, like this:
maas $PROFILE machine update $SYSTEM_ID power_type="$POWER_TYPE"
where $POWER_TYPE can have the following values:
| CLI power_type code | Description |
| amt | Intel AMT |
| apc | American Power Conversion (APC) PDU |
| dli | Digital Loggers, Inc. PDU |
| eaton | Eaton PDU |
| hmc | IBM Hardware Management Console (HMC) |
| ipmi | IPMI |
| manual | Manual power configuration |
| moonshot | HP Moonshot - iLO4 (IPMI) |
| mscm | HP Moonshot - iLO Chassis Manager |
| msftocs | Microsoft OCS - Chassis Manager |
| nova | OpenStack Nova |
| openbmc | OpenBMC Power Driver |
| recs_box | Christmann RECS-Box Power Driver |
| redfish | Redfish |
| sm15k | SeaMicro 15000 |
| ucsm | Cisco UCS Manager |
| virsh | libvirt KVM |
| vmware | VMware |
| wedge | Facebook’s Wedge |
Note the required and optional parameters associated with each power type.
Once you’ve successfully processed the command (as indicated by a stream of JSON, headed by “Success!”), MAAS performs a power check on the machine. A successful power check is a good indication that MAAS can properly communicate with the machine, that is, it should quickly result in a power status of “Power off”. A failed attempt will return errors that should guide you to fix your power_parameters.
Power catalogue
Intel AMT
All parameters are entered as key=value, e.g., power_type=amt. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
| Parameter | Description | Required |
power_type |
amt |
Required |
power_address |
power_pass |
All parameters are entered as key=value, e.g., power_type=apc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
apc |
Required |
power_address |
node_outlet |
PDU node outlet number | Required |
power_on_delay |
outlet power ON delay | Optional, default=5 |
All parameters are entered as key=value, e.g., power_type=dli. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
dli |
Required |
outlet_id |
outlet ID | Required |
power_address |
power_user |
power_pass |
Eaton PDU
All parameters are entered as key=value, e.g., power_type=eaton. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
eaton |
Required |
power_address |
node_outlet |
power_on_delay |
All parameters are entered as key=value, e.g., power_type=hmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
hmc |
Required |
power_address |
server_name |
HMC managed server name | Required |
lpar |
HMC logical partition of unit | Required |
power_user |
power_pass |
IPMI
All parameters are entered as key=value, e.g., power_type=ipmi. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
| Parameter | Description | Choices | Required |
power_type |
ipmi |
Required | |
power_driver |
Power driver | LAN [IPMI 1.5] |
Required |
LAN_2_0 [IPMI 2.0] |
power_boot_type |
Boot type | Automatic |
Required |
Legacy boot |
EFI boot |
Manual power configuration means exactly that – manually configured at the unit. The only MAAS CLI parameter is power_type=amt.
All parameters are entered as key=value, e.g., power_type=moonshot. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | moonshot` |
Required | |
power_address |
power_hwaddress |
power_user |
power_pass |
All parameters are entered as key=value, e.g., power_type=mscm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | mscm` |
Required | |
power_address |
node_id |
cXnY | Required |
| Y = node number | ||
power_user |
power_pass |
All parameters are entered as key=value, e.g., power_type=msftocs. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | msftocs` |
Required | |
power_address |
blade_id |
power_port |
power_user |
power_pass |
OpenStack Nova
All parameters are entered as key=value, e.g., power_type=nova. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | nova` |
Required | |
nova_id |
os_tenantname |
os_username |
os_password |
os_authurl |
All parameters are entered as key=value, e.g., power_type=openbmc. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
openbmc |
Required |
power_address |
power_user |
power_pass |
All parameters are entered as key=value, e.g., power_type=recs_box. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | recs_box` |
Required | |
node_id |
power_address |
power_port |
power_user |
power_pass |
Redfish
All parameters are entered as key=value, e.g., power_type=redfish. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type | redfish` |
Required | |
power_address |
power_user |
power_pass |
node_id |
SeaMicro 15000
All parameters are entered as key=value, e.g., power_type=sm15k. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
sm15k |
Required | |
power_control |
Password to access unit | ipmi | Required |
| restapi | |||
| restapi2 |
Cisco UCS Manager
All parameters are entered as key=value, e.g., power_type=ucsm. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
ucsm |
Required |
uuid |
power_address |
URL for XML API | Required |
power_user |
power_pass |
virsh - libvirt KVM
All parameters are entered as key=value, e.g., power_type=virsh. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
virsh |
Required |
power_id |
power_address |
power_pass |
VMware
All parameters are entered as key=value, e.g., power_type=vmware. The MAAS CLI will refuse the request with informative errors if required parameters are excluded.
power_type |
vmware |
Required |
power_vm_name |
power_uuid |
power_address |
power_user |
power_pass |
power_port |
power_protocol |
Facebook’s Wedge
power_type |
wedge |
Required |
power_address |
power_user |
power_pass |
Consider a machine backed by a KVM, accessed via virsh. You can create a corresponding MAAS machine and set its power parameters with a command like this one:
maas admin machines create \
architecture=amd64 \
power_type=virsh \
power_parameters_power_id=f677a842-571c-4e65-adc9-11e2cf92d363 \
If successful, this will return:
Machine-readable output follows this announcement. The JSON generated by this command is shown in the detail block.
MAAS command JSON response
``` { "storage": 0.0, "tag_names": [], "special_filesystems": [], "memory": 0, "boot_disk": null, "virtualblockdevice_set": [], "hardware_info": { "system_vendor": "Unknown", "system_product": "Unknown", "system_family": "Unknown", "system_version": "Unknown", "system_sku": "Unknown", "system_serial": "Unknown", "cpu_model": "Unknown", "mainboard_vendor": "Unknown", "mainboard_product": "Unknown", "mainboard_serial": "Unknown", "mainboard_version": "Unknown", "mainboard_firmware_vendor": "Unknown", "mainboard_firmware_date": "Unknown", "mainboard_firmware_version": "Unknown", "chassis_vendor": "Unknown", "chassis_type": "Unknown", "chassis_serial": "Unknown", "chassis_version": "Unknown" }, "address_ttl": null, "memory_test_status": -1, "other_test_status_name": "Unknown", "osystem": "", "status_message": "Commissioning", "netboot": true, "physicalblockdevice_set": [], "node_type": 0, "cpu_test_status": -1, "memory_test_status_name": "Unknown", "bcaches": [], "storage_test_status": 0, "system_id": "bhxws3", "status": 1, "commissioning_status": 0, "power_type": "virsh", "locked": false, "numanode_set": [ { "index": 0, "memory": 0, "cores": [] } ], "bios_boot_method": null, "fqdn": "ace-swan.maas", "node_type_name": "Machine", "hostname": "ace-swan", "volume_groups": [], "testing_status": 0, "network_test_status": -1, "other_test_status": -1, "interface_test_status": -1, "hwe_kernel": null, "blockdevice_set": [], "testing_status_name": "Pending", "power_state": "unknown", "min_hwe_kernel": "", "owner": "admin", "distro_series": "", "storage_test_status_name": "Pending", "cpu_speed": 0, "swap_size": null, "cpu_test_status_name": "Unknown", "hardware_uuid": null, "architecture": "amd64/generic", "pool": { "name": "default", "description": "Default pool", "id": 0, "resource_uri": "/MAAS/api/2.0/resourcepool/0/" }, "cache_sets": [], "pod": null, "iscsiblockdevice_set": [], "disable_ipv4": false, "status_action": "", "boot_interface": { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" }, "cpu_count": 0, "domain": { "authoritative": true, "ttl": null, "resource_record_count": 0, "name": "maas", "is_default": true, "id": 0, "resource_uri": "/MAAS/api/2.0/domains/0/" }, "current_testing_result_id": 7, "default_gateways": { "ipv4": { "gateway_ip": null, "link_id": null }, "ipv6": { "gateway_ip": null, "link_id": null } }, "interface_set": [ { "name": "eth0", "id": 10, "product": null, "system_id": "bhxws3", "effective_mtu": 1500, "children": [], "link_connected": true, "enabled": true, "interface_speed": 0, "numa_node": 0, "firmware_version": null, "parents": [], "discovered": null, "params": "", "links": [], "sriov_max_vf": 0, "tags": [], "type": "physical", "vlan": null, "vendor": null, "link_speed": 0, "mac_address": "52:54:00:15:36:f2", "resource_uri": "/MAAS/api/2.0/nodes/bhxws3/interfaces/10/" } ], "status_name": "Commissioning", "commissioning_status_name": "Pending", "owner_data": {}, "ip_addresses": [], "raids": [], "network_test_status_name": "Unknown", "description": "", "current_commissioning_result_id": 6, "interface_test_status_name": "Unknown", "current_installation_result_id": null, "zone": { "name": "default", "description": "", "id": 1, "resource_uri": "/MAAS/api/2.0/zones/default/" }, "resource_uri": "/MAAS/api/2.0/machines/bhxws3/" } ```Which BMC drivers are supported
Tell me about BMC
| Power Driver (X=supported) | PXE Next Boot | Power Querying | Chassis/Pod Configuration | Enhanced UI Error Reporting | BMC Enlistment |
| American Power Conversion (APC) - PDU | |||||
| Cisco UCS Manager | X | X | X | ||
| Digital Loggers, Inc. - PDU | |||||
Facebook's Wedge *
| HP Moonshot - iLO Chassis Manager | X | X | X | ||
| HP Moonshot - iLO4 (IPMI) | X | X | X | ||
| IBM Hardware Management Console (HMC) | X | X | |||
| IPMI | X | X | X | X | |
| Intel AMT | X | X | X | ||
| Manual | |||||
| Microsoft OCS - Chassis Manager | X | X | X | ||
| OpenStack Nova | X | ||||
| Rack Scale Design | X | X | X | ||
| SeaMicro 15000 | X | X | X | ||
| Sentry Switch CDU - PDU | |||||
| VMWare | X | X | X | ||
| Virsh (virtual systems) | X | X | X |
