Four questions you may have:
- How do I use network link testing?
- How can I detect slow network links?
- How do I use network validation and testing scripts?
- How can I customise network testing?
| @tsv' | column -t
LINK_NAME LINK_CONNECTED? LINK_SPEED I/F_SPEED
ens3 false - 1 Gpbs
From this screen, you can see that the ens3
link is not connected (hence an unreported link speed).
| @tsv' | column -t
Administrators can change or update the link and interface speeds after manual changes
to the connection:
Network validation and testing scripts
To test individual interfaces, for example, you could issue the following command:
