my MAAS 3.6 via snap,intalled at below server
Ubuntu 24,two nic 192.168.204.16/24 public,10.10.204.16/16 for bmc
when I commissioning a server,pxe seems failed,dhcp seems ok,but I can not further locate this issue
which logs shoud check and supply?
Jun 04 08:39:31 u24maas maas-rackd[5541]: provisioningserver.rackdservices.tftp: [info] lpxelinux.0 requested by 192.168.204.173
Jun 04 08:39:31 u24maas maas-rackd[5541]: provisioningserver.rackdservices.http: [info] /images/lpxelinux.0 requested by 127.0.0.1
Jun 04 08:39:39 u24maas maas-rackd[5541]: provisioningserver.rackdservices.tftp: [info] lpxelinux.0 requested by 192.168.204.173
Jun 04 08:39:39 u24maas maas-rackd[5541]: provisioningserver.rackdservices.http: [info] /images/lpxelinux.0 requested by 127.0.0.1
Jun 04 08:40:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s3 started.
Jun 04 08:40:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s8 started.
Jun 04 08:40:15 u24maas maas-rackd[5541]: provisioningserver.utils.services: [critical] Beaconing process for enp0s8 failed.
Jun 04 08:40:15 u24maas maas-rackd[5541]: Traceback (most recent call last):
Jun 04 08:40:15 u24maas maas-rackd[5541]: Failure: twisted.internet.error.ProcessTerminated: A process has ended with a probable error condition: process ended with exit code 3.
Jun 04 08:40:15 u24maas maas-rackd[5541]: provisioningserver.utils.services: [critical] Beaconing process for enp0s3 failed.
Jun 04 08:41:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s3 started.
Jun 04 08:41:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s8 started.
Jun 04 08:41:15 u24maas maas-rackd[5541]: provisioningserver.utils.services: [critical] Beaconing process for enp0s3 failed.
Jun 04 08:41:15 u24maas maas-rackd[5541]: Traceback (most recent call last):
Jun 04 08:41:15 u24maas maas-rackd[5541]: Failure: twisted.internet.error.ProcessTerminated: A process has ended with a probable error condition: process ended with exit code 3.
Jun 04 08:41:15 u24maas maas-rackd[5541]: provisioningserver.utils.services: [critical] Beaconing process for enp0s8 failed.
Jun 04 08:42:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s3 started.
Jun 04 08:42:14 u24maas maas-rackd[5541]: provisioningserver.utils.services: [info] Beaconing process for enp0s8 started.
Jun 04 08:42:15 u24maas maas-rackd[5541]: provisioningserver.utils.services: [critical] Beaconing process for enp0s3 failed.
