Two questions you might have:
- What are the requirements for a test environment?
- What are the requirements for a production environment?
Memory (MB) | CPU (GHz) | Disk (GB) | |
Region controller (minus PostgreSQL) | 512 | 0.5 | 5 |
PostgreSQL | 512 | 0.5 | 5 |
Rack controller | 512 | 0.5 | 5 |
Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Region controller (minus PostgreSQL) | 2048 | 2.0 | 5 |
PostgreSQL | 2048 | 2.0 | 20 |
Rack controller | 2048 | 2.0 | 20 |
- the number of connecting clients (client activity)
- how you decide to distribute services
- whether or not you use high availability/load balancing.
- the number of images that you choose to store (disk space affecting PostgreSQL and the rack controller)
