| 2.7 | 2.8 | 2.9 | 3.0 | |
| Snap | CLI ~ UI | CLI ~ UI | CLI ~ UI | CLI ~ UI |
| Packages | CLI ~ UI | CLI ~ UI | CLI ~ UI | CLI ~ UI |
This article provides technical data relevant the MAAS installation. Note that all headings are linked for easy bookmarking.
The following technical data is available in this document:
- Minimum hardware requirements for using MAAS
- MAAS initialisation modes
- The MAAS shared secret
- MAAS re-initialisation
These sections are presented for reference, so they are not intended to be read in any particular order.
This section provides the following technical data:
- Minimum hardware requirements for a MAAS test environment
- Minimum hardware requirements for a MAAS production environment
| Memory (MB) | CPU (GHz) | Disk (GB) | |
| Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Minimum requirements for a MAAS production environment
| Mode | Region | Rack | Database | Description |
| region | X | Region API server only | ||
| rack | X | Rack controller only | ||
| region+rack | X | X | Region API server and rack controller | |
| none | Reinitialises MAAS and stops services |
MAAS initialisation options
MAAS initialisation options correspond to these choices. For example, the command:
sudo maas init --help
produces the following output:
usage: maas init [-h] {region+rack,region,rack} ...
optional arguments:
run modes:
The MAAS URL
region+rack: Used to create a new region controller as well as to tell the rack controller how to find the region controller.
region: Used to create a new region controller.
rack: Used to locate the region controller.
Shared secret
When you add a new rack or region controller, MAAS asks for a shared secret it will use to communicate with the rest of MAAS. This secret is also exposed in the web UI when you click the “Add rack controller” button on the Controllers page. MAAS automatically generates this secret when your first region controller installed, and stores the secret in a plain text file. This file is automatically protected with the correct permissions, so there is no need for any action on your part.
Re-initialising MAAS resets the MAAS URL when the configuration changes.  For example, when hosting MAAS on a system that gets its IP from DHCP, you must reinitialise when the DHCP lease gets renewed, as your base MAAS IP address will need to be updated.  Likewise, if you switch the MAAS configuration from rack to region, you’ll need to re-initialise as well.
