Placeholder for MAAS installation technical reference.
MAAS snaps
Snaps are containerised software packages.
The test configuration uses a small PostgreSQL database (in a separate snap), designed for use with MAAS. The full-up production configuration uses a separate PostgreSQL database for performance and scalability.
MAAS initialisation modes
Mode | Region | Rack | Database | Description |
region |
X | Region API server only | ||
rack |
X | Rack controller only | ||
region+rack |
X | X | Region API server and rack controller | |
none |
Reinitialises MAAS and stops services |
MAAS hardware requirements
Two questions you might have about hardware requirements:
- What are the requirements for a test environment?
- What are the requirements for a production environment?
Memory (MB) | CPU (GHz) | Disk (GB) | |
Region controller (minus PostgreSQL) | 512 | 0.5 | 5 |
PostgreSQL | 512 | 0.5 | 5 |
Rack controller | 512 | 0.5 | 5 |
Ubuntu Server (including logs) | 512 | 0.5 | 5 |
Region controller (minus PostgreSQL) | 2048 | 2.0 | 5 |
PostgreSQL | 2048 | 2.0 | 20 |
Rack controller | 2048 | 2.0 | 20 |
Additional init
options
The init
command can takes optional arguments. To list them, as well as read a brief description of each, you can enter:
sudo maas init --help
MAAS URL
All run modes (except none
) prompt for a MAAS URL, interpreted differently depending on the mode:
region
: Used to create a new region controller. -
rack
: Used to locate the region controller.
Shared secret
