I’ve installed Ubuntu 18.04 manually on a bare metal server, then, I created a KVM Guest for running MaaS.
So, my question is:
Is it okay to add the underlying KVM Host, to the MaaS itself, as that Pod thing, In a way that MaaS will be able to create/manage more VMs side-by-side to itself (using libvirt connection)?
So I can start creating other VMs using MaaS, instead of “virt-manager” (that I used to create first VM for MaaS)?
Hi, what I’d recommend is to run maas inside a LXD container (well, technically it’s a lxc container) and then register your KVM host as a pod in maas. This way your maas instance will not be KVM dependent and yes, maas will then be able to create/manage VMs on your host.
This would require to plan your virtual networking a bit (several bridges probably) and what I’d also recommend would be to create a specific LXD profile for maas with several networking interfaces.
You should be able to do this however MAAS will detect and manage the VM it is running on. This would make it possible for a MAAS administrator to power off and even delete the VM MAAS is running on. The suggestions both idobs and jsseidel mention will both isolate the MAAS VM/container from MAAS itself.
