MAAS and DPUs
With MAAS 3.3, we’ve made it possible to deploy workloads to DPUs. A DPU is a Data Processing Unit, which consists of its own set of ARM cores that can be used to offload data processing from the main host. We’ve tested it with a NVIDIA Bluefield-2 DPU, and here you will find instructions for how to get started deploying workloads to such a DPU.
Initial setup
This guide assumes that the DPU host machine is not yet enlisted into MAAS. Before we enlist it, we’re going to do a one-time setup to make things easier.
This guide assumes that you have a maas CLI profile called admin. If you don’t, create one with:
$ sudo snap install maas
$ maas login admin $maas_url $api_token
Tags
To make it easier to see which machines are DPUs and which are DPU hosts, we’re going to set up a couple of automatic tags:
$ maas admin tags create name=dpu \
      definition='//node[@class="system"]//configuration/setting/@value="BlueField"'
$ maas admin tags create name=dpu-host \
      definition='//node[@class="generic"]/product = "MT42822 BlueField-2 SoC Management Interface"'
This makes sure that any machine in MAAS that is a Bluefield-2 DPU has the dpu tag, and any machine that contains a Bluefield-2 DPU has the dpu-host tag.
Commissioning image
In order for all the hardware to be detected properly, we need to use Ubuntu 22.04 as the commissioning image. Ensure that’s the case with this command:
$ maas admin maas set-config name=name=commissioning_distro_series value=jammy
Deploy image
The Bluefield-2 DPU needs a special kernel and drivers for the network interfaces to work. We’ll build a custom Ubuntu image with the necessary kernel and drivers, which we can use when deploying workloads to the DPU. We’ll include a subset of what’s in the image that NVIDIA provides.
Please follow the setup instructions for packer-maas. Next we’ll create a script that installs the bluefield related kernel and runtime packages:
$ cat <<EOF > setup-bluefield.sh
#!/bin/bash
export DEBIAN_FRONTEND=noninteractive
wget -qO - https://linux.mellanox.com/public/repo/doca/1.3.0/ubuntu20.04/aarch64/GPG-KEY-Mellanox.pub | apt-key add -
echo "deb [trusted=yes] https://linux.mellanox.com/public/repo/doca/1.3.0/ubuntu20.04/\$(ARCH) ./" | tee /etc/apt/sources.list.d/doca.list
apt-get update
apt-get install -y -f \
	linux-bluefield=5.4.0.1035.36 \
	linux-bluefield-headers-5.4.0-1035=5.4.0-1035.38 \
	linux-bluefield-tools-5.4.0-1035=5.4.0-1035.38 \
	linux-headers-5.4.0-1035-bluefield=5.4.0-1035.38 \
	linux-headers-bluefield=5.4.0.1035.36 \
	linux-image-5.4.0-1035-bluefield=5.4.0-1035.38 \
	linux-image-bluefield=5.4.0.1035.36 \
	linux-modules-5.4.0-1035-bluefield=5.4.0-1035.38 \
	linux-tools-5.4.0-1035-bluefield=5.4.0-1035.38 \
	linux-tools-bluefield=5.4.0.1035.36 \
	linux-libc-dev:arm64 \
	linux-tools-common \
	mlnx-ofed-kernel-modules \
	doca-libs \
	doca-runtime
apt-mark hold linux-tools-bluefield linux-image-bluefield linux-bluefield \
	linux-headers-bluefield linux-image-bluefield linux-libc-dev \
	linux-tools-common mlnx-ofed-kernel-modules doca-libs doca-runtime
mkdir -p /curtin
echo -n "linux-bluefield=5.4.0.1035.36" > /curtin/CUSTOM_KERNEL
EOF
Now we can build the package and upload it to MAAS:
$ sudo packer build -var customize_script=setup-bluefield.sh \
      -var ubuntu_series=focal -var architecture=arm64 \
      -only 'cloudimg.*'
$ maas admin boot-resources create name="custom/ubuntu-bluefield" \
      title="Ubuntu 20.04 LTS (bluefield 5.4.0.1035.36)" \
      architecture=arm64/generic filetype=tgz content@=custom-cloudimg.tar.gz
Enlist host and DPU
Now when everything is set up, it’s time to enlist both the host and DPU into MAAS. We assume here that the host is connected to a VLAN where MAAS is providing DHCP.
Now, use your favourite IPMI tool to set PXE for the next boot and turn on the host. For example:
$ ipmitool -H $bmc_ip -I lanplus -U $bmc_user -P $bmc_pass chassis bootdev pxe
$ ipmitool -H $bmc_ip -I lanplus -U $bmc_user -P $bmc_pass chassis power on
There should now be a new machine enlisted in MAAS as NEW. Let’s rename it to dpu-host to keep track of it.
The DPU didn’t yet get enlisted, since it’s most likely configured to boot from local disk and not from the network. We need to change the boot order. If the DPU is running Ubuntu already and you know how to access it, you can change the boot order using efibootmgr.
If not, let’s deploy the host, so that we can access the DPU through it using RSHIM:
$ HOSTID=$(maas admin machines read hostname=dpu-host | jq '.[] | .system_id' | tr -d '"')
$ maas admin machine deploy $HOSTID osystem=ubuntu distro_series=jammy
When the host has finished deploying, ssh to the host and install RSHIM:
$ HOSTIP=$(maas admin machine read $HOSTID | jq '.ip_addresses[0]' | tr -d '"')
$ ssh ubuntu@$HOSTIP
ubuntu@dpu-host $ wget https://content.mellanox.com/BlueField/RSHIM/rshim_2.0.6-9.g7267006_amd64.deb
ubuntu@dpu-host $ sudo dpkg -i ./rshim_2.0.6-9.g7267006_amd64.deb
Now RSHIM is running and you can access the console of the DPU trough /dev/rshim0/console. Before you access the console, reboot the DPU by sending SW_RESET 1 to /dev/rshim0/misc:
ubuntu@dpu-host $ sudo bash -c ‘echo "SW_RESET 1" > /dev/rshim0/misc’
ubuntu@dpu-host $ sudo screen /dev/rshim0/console
Now when the DPU is starting up, press Escape 3 times when prompted. You’re now in the boot manager menu and can select the boot order via Boot Maintenance ManagerBoot OptionsChange Boot Order
When you exit, the DPU should restart and you can see it booting off the network. After a while you should see a new machine in MAAS with the dpu tag. Let’s rename it to dpu for the sake of this guide.
You also need to set the power configuration to Manual, unless your DPU has a BMC.
Power management
When working with a DPU, especially one without a BMC, it’s important to know that the DPU’s power is tightly coupled with the host power. If the host gets turned off, so does the DPU. This works both ways: if the host turns on, so does the DPU.
We set the power type to Manual for the DPU, since our DPU doesn’t have a BMC. Instead, we’re going to make use of the host to control the DPU power. Whenever we need to turn on the DPU, we instead turn on the host.
There are two ways we can do this, depending on the state of the host. If the host is Deployed, we can power cycle the host:
$ maas admin machine power-off $HOSTID
$ maas admin machine power-on $HOSTID
Note that when power cycling the host, we need to do a hard power cycle. If you do a soft power cycle (e.g. by running reboot from within the host), the DPU won’t be power-cycled.
If the host is in a Ready state, we can instead commission the host to turn it on. Note, though, that we need to select Allow SSH access and prevent machine powering off when doing so. Otherwise, the host would turn off at the end of the commissioning process, which might occur before the DPU has finished doing its work:
$ maas admin machine commission $HOSTID enable_ssh=true
You can try it out by choosing to commission the DPU now and issue the power-off and power-on commands. You should then see the DPU being commissioned and put into a Ready state.
Deploying workloads
Now you’re ready to deploy workloads to the DPU and the host. We’re not going to tell you in what ways you can configure the DPU and interact with it from the host. Rather we’re going to go over how you deploy Ubuntu to it. It’s up to you to choose workloads that you want to run and configure.
You can easily deploy a workload to the DPU and host, in pretty much the same way you deploy a workload to a regular machine – with the caveat that you need to manually power cycle the DPU after you tell MAAS to deploy it.
Also, remember that you need the custom image for the DPU that we created and uploaded in the beginning of this guide:
$ DPUID=$(maas admin machines read hostname=dpu | jq '.[] | .system_id' | tr -d '"')
$ maas admin machine deploy $DPUID osystem=custom distro_series=ubuntu-bluefield
And now, if you power cycle the DPU, you should see it deploying.
Host and DPU dependencies
As mentioned before, the host is tightly coupled with the DPU. It’s advised that you first deploy the DPU and configure it as much as you can. After that, it might even be required to recommission the host, since it might see other network interfaces, depending on how you configured the DPU.
In general, the host should be deployed after the DPU has been deployed and configured, since the host might rely on a specific DPU configuration.
The packer build command appears to be missing the final argument, a ..
It would be useful to note that you need to be in the ubuntu subdirectory before running the packer commands (also true for the packer-maas README on github)
Since these instructions are setting the commissioning series to jammy, but we’re uploading a custom focal image, am I correct to assume that the jammy/generic kernel is expected to work sufficiently on BlueField 2 for commissioning? (It does not appear to work on BlueField 3 unfortunately - I haven’t tried 2)
Thanks Dann. I’ll look into the packer commands, I’m going to go through this document soon.
As for the commissioning series. Yes, jammy works well enough so that the hardware is detected. But IIRC, extra packages were needed to get the NIC ports to work. If BF3 doesn’t work with jammy, then it will be trickier to use it with MAAS.
