How to deploy DPUs in MAAS
A Data Processing Unit (DPU) is a specialized network interface card that offloads networking, storage, and security tasks from the CPU. MAAS 3.7 introduced BMC-based control for NVIDIA BlueField 3 DPUs, enabling them to be managed like standard machines in the MAAS infrastructure.
This guide explains how to configure, add, commission, deploy, and release NVIDIA BlueField 3 DPUs in MAAS 3.7 and later.
Note: BlueField 2 DPUs can still be added and controlled using the manual approach described in previous documentation. This guide focuses on the BMC-enabled workflow for BlueField 3 devices.
Prerequisites
Before deploying a DPU in MAAS, ensure you have the following:
Infrastructure Requirements
  • MAAS 3.7 or later installed and configured
  • NVIDIA BlueField 3 DPU with BMC support
  • Host machine powered on (the DPU resides within this host)
  • Network infrastructure configured for PXE boot on the OOB management interface
  • Noble (24.04) ARM64 images synced in MAAS (used for commissioning)
Host Machine Setup
The host machine must have:
  • Power management accessible (host must remain powered on during DPU operations)
DPU Configuration
  • DPU MAC address noted down for registration
  • BMC IP address and credentials (administrator account required)
  • DPU operating mode set to ‘DpuMode’ (not NIC or Restricted mode)
  • PXE boot configured for initial commissioning via OOB interface
Additional Requirements
  • SSH keys configured in MAAS for remote access
  • Understanding of DPU-host relationship constraints (see “Important Considerations” section)
Preparing the DPU
Finding the BMC IP Address
Connect to the DPU via SSH and use the following command to find the BMC IP address:
sudo ipmitool lan print
For IPv6:
sudo ipmitool lan6 print
Configuring BMC Credentials
MAAS requires administrator-level BMC credentials to control the DPU’s power state. Add a user account to the BMC with administrator privileges using ipmitool. See the ipmitool documentation for detailed steps.
For the commands in this guide, the following environment variables are used:
  • $BMC_USER: Username of the BMC administrator account
  • $BMC_PASS: Password for the BMC account
  • $BMC_IP: IP address of the DPU’s BMC
Setting the DPU Operating Mode
BlueField 3 DPUs have three operating modes: DPU, Restricted, and NIC. For full MAAS control, the DPU must be in DPU mode.
Check the current mode:
curl -k -u $BMC_USER:$BMC_PASS -H 'Content-Type: application/json' \
  -X GET https://$BMC_IP/redfish/v1/Systems/Bluefield/Bios/ | jq '.Attributes'
Change to DPU mode if needed:
  1. Issue this Redfish call to set DPU mode:
curl -k -u $BMC_USER:$BMC_PASS -H 'content-type: application/json' \
  -d '{ "Attributes": { "NicMode": "DpuMode" } }' \
  -X PATCH https://$BMC_IP/redfish/v1/Systems/Bluefield/Bios/Settings
  1. Hard reset the DPU. This requires resetting the host machine.
More information about BlueField modes: NVIDIA BlueField Modes of Operation
Setting PXE Boot for Initial Commissioning
For initial commissioning and deployment, configure the DPU to PXE boot:
  -X PATCH https://$BMC_IP/redfish/v1/Systems/Bluefield \
  -d '{"Boot": {"BootSourceOverrideEnabled": "Once", "BootSourceOverrideTarget": "Pxe"}}'
Important: Configure PXE boot to use the OOB (out-of-band) management interface, not the high-speed P0/P1 interfaces, to avoid firmware compatibility issues during deployment.
Subsequent commissioning and deployments will automatically configure PXE boot.
Configuring Boot Order (Optional)
To set a persistent PXE boot order, update the boot device configuration from the BMC console. See NVIDIA’s boot order configuration guide.
If the boot device name for the desired NIC is unknown, enter the UEFI menu from the BMC console by running:
obmc-console-client
Note: The boot order resets to default when a BFB image from NVIDIA is installed.
Adding a DPU to MAAS
DPUs are added similarly to regular machines, with specific requirements to ensure proper registration.
Via the MAAS UI
  1. Navigate to Machines → Add Machine
  2. Enter the DPU details:
    • Architecture: arm64/generic
    • Minimum kernel: hwe-22.04 or newer
    • MAC address: The DPU’s primary MAC address
  3. Configure power settings:
    • Power type: Redfish
    • Power address: DPU BMC IP address
    • Power user: BMC username
    • Power password: BMC password
  4. Important: Check the “Register as DPU” checkbox
  5. Click Save
Via the MAAS CLI
maas $PROFILE machines create \
  architecture=arm64/generic \
  min_hwe_kernel="hwe-22.04" \
  mac_addresses=$MAC_ADDRESS \
  is_dpu=true \
  power_type=redfish \
  power_parameters_power_user=$BMC_USER \
  power_parameters_power_address=$BMC_IP \
  power_parameters_power_pass=$BMC_PASS
Critical: Always set is_dpu=true to avoid undefined behavior.
Post-Registration Configuration
Optional: Create a Tag for Boot Parameters
To add required kernel boot parameters for console access:
maas $PROFILE tags create \
  name=bf3 \
  kernel_opts="console=hvc0 console=ttyAMA0 earlycon=pl011,0x13010000 fixrtc net.ifnames=0 biosdevname=0 iommu.passthrough=1"
Then assign this tag to the DPU machine.
Commissioning the DPU
Commissioning discovers hardware details and prepares the DPU for deployment.
Prerequisites
  • DPU is powered on (via powered-on host)
  • DPU is set to PXE boot
  • Minimum kernel is hwe-22.04 or newer
Commissioning Process
Via the MAAS UI
  1. Select the DPU machine
  2. Click Take action → Commission
  3. Optionally select additional commissioning scripts
  4. Click Commission machine
Via the MAAS CLI
Verification
MAAS will:
  • Reset the DPU via the BMC
  • Boot into an ephemeral Noble environment
  • Detect hardware (CPU, memory, OOB interface, P0, P1)
  • Run commissioning scripts
  • Mark the DPU as Ready
Note: Only the OOB, P0, and P1 interfaces are detected during commissioning. Host representor interfaces (pf0hpf, pf1hpf) and tmfifo_net0 only appear after deploying an OS with DOCA runtime packages.
Deployment
Deploy the DPU with an operating system and configuration.
Deployment Options
You have two main deployment strategies:
  1. Standard Ubuntu images (Jammy HWE or Noble)
  2. Custom packer-maas images with DOCA packages pre-installed
For production deployments, consider using packer-maas to build custom Ubuntu images that include the BlueField kernel, DOCA runtime, and required NVIDIA packages. The repository includes example customization scripts for DOCA 2.9 LTS and DOCA 3.2.0 that handle package installation and configuration. Build on an ARM64 machine using
make custom-cloudimg.tar.gz SERIES=jammy ARCH=arm64 CUSTOMIZE=scripts/examples/bluefield-doca-2-9-lts.sh
Then upload the resulting image to MAAS. See the Ubuntu image build documentation for details.
Prerequisites
  • DPU must be in Ready state
  • Jammy HWE (hwe-22.04) or Noble kernel required
  • For custom images: Upload custom image with DOCA packages
Deploy via MAAS UI
  1. Select the commissioned DPU
  2. Click Take action → Deploy
  3. Configure deployment:
    • Operating system: Ubuntu
    • Release: Ubuntu 22.04 LTS (Jammy Jellyfish) or later
    • Kernel: hwe-22.04 or ga-24.04
  4. (Optional) Add cloud-init user-data for post-deployment configuration
  5. Click Start deployment
Deploy via MAAS CLI
Using a standard image:
maas $PROFILE machine deploy $SYSTEM_ID \
  distro_series=jammy \
  hwe_kernel=hwe-22.04
Using a custom image:
  osystem=custom \
  distro_series=ubuntu-bf-doca-2-9 \
  user_data=$(base64 -w0 cloud-init.yaml)
Deployment Process
MAAS will:
  1. Reset the DPU
  2. Configure PXE boot
  3. Boot into ephemeral environment
  4. Partition storage and install OS
  5. Reboot into installed OS
  6. Run cloud-init for final configuration
  7. Mark as Deployed
Cloud-Init Customization
Example cloud-init configuration for DOCA services:
#cloud-config
packages:
  - mlnx-ofed-kernel-modules
  - doca-runtime
runcmd:
  - systemctl enable openvswitch-switch
  - systemctl start openvswitch-switch
Verification
After deployment:
  1. Check status in MAAS UI (should show Deployed)
  2. SSH to the DPU:
ssh ubuntu@<dpu-ip-address>
  1. Verify services:
systemctl status openvswitch-switch
ip link show
Releasing a DPU
When finished with a DPU, release it back to the available pool.
Important Notes
  • Releasing a DPU marks it as Ready but does not:
    • Reset the DPU configuration
    • Erase disks
    • Run post-release scripts
  • To ensure the DPU is brought into a clean slate, redeploy it
Release via MAAS UI
  1. Select the deployed DPU
  2. Click Take action → Release
  3. Click Release machine
Release via MAAS CLI
maas $PROFILE machine release $SYSTEM_ID
DPU-Host Relationship
  • The DPU’s power state is tied to the host machine
  • Host must remain powered on during DPU commissioning/deployment
  • A host power cycle is required to apply firmware configuration changes
Network Interface Detection
  • During commissioning: Only OOB, P0, and P1 interfaces are detected
  • After DOCA deployment: Additional interfaces appear (tmfifo_net0, pf0hpf, pf1hpf)
  • MAAS cannot currently manage OVS bridges or these additional interfaces via UI
  • Use cloud-init or manual configuration for advanced networking
Firmware Compatibility
  • Firmware version must match the DOCA version in the deployed image
    • With customized images or when installing the firmware updater in the deployed machine, you can trigger firmware installation from cloud-init by using: /opt/mellanox/mlnx-fw-updater/mlnx_fw_updater.pl -v --fw-dir /opt/mellanox/mlnx-fw-updater/firmware --force-fw-update
  • Firmware mismatch can cause high-speed interface initialization failures
  • Always use OOB interface for PXE boot to avoid connectivity loss
  • Firmware updates may require a host power cycle to apply changes
Limitations
  • HW sync during deployment detects some interfaces but causes issues on re-deployment
  • OVS bridge creation triggered by MAAS marking openvswitch as required, conflicts with NVIDIA DOCA OVS (when using customized packer images that include this version of OVS instead of upstream)
  • No automatic post-release cleanup
Troubleshooting
DPU Fails to Commission
  • Verify host machine is powered on
  • Check BMC connectivity and credentials
  • Ensure PXE boot is configured on OOB interface
  • Confirm Noble ARM64 images are synced
  • Review logs: /var/log/maas/rackd.log and /var/log/maas/regiond.log
Deployment Hangs or Fails
  • Verify minimum kernel is hwe-22.04 or newer
  • Check network configuration (DHCP, TFTP, HTTP)
  • Review deployment logs in MAAS UI or via CLI:
maas $PROFILE events query machine=$SYSTEM_ID
  • Check cloud-init logs on DPU: /var/log/cloud-init.log
BMC Power Control Issues
  • Test BMC access manually:
curl -k -u $BMC_USER:$BMC_PASS https://$BMC_IP/redfish/v1/Systems/Bluefield
  • Verify BMC credentials and network accessibility
  • Check for firmware compatibility issues
Network Interfaces Not Detected
  • Ensure DOCA runtime packages are installed
  • Verify firmware version matches DOCA version
  • Check that DPU is in DPU mode (not NIC or Restricted)
  • Review kernel logs: dmesg | grep mlx
Firmware Version Mismatch
  • Update firmware from host or BMC before deployment
  • Use cloud-init to trigger firmware update on first boot
  • Perform host power cycle to apply firmware changes
Additional Resources
Thanks for the great guide! I’ve been working through this with DOCA 3.3.0 on Noble and wanted to share a few additions.
DOCA 3.3.0 customization script
A new example script for DOCA 3.3.0 is now available in packer-maas:
make custom-cloudimg.tar.gz SERIES=noble ARCH=arm64 \
CUSTOMIZE=scripts/examples/bluefield-doca-3-3-0.sh
PR: https://github.com/canonical/packer-maas/pull/381
OOB network setup note
The OOB and BMC share one physical RJ-45 port but present as two different MACs. The switch needs to allow both. If it doesn’t, you can use DHCP Option 60 (Vendor Class Identifier)
to differentiate — DPU PXE boot sends PXE in Option 60, while the BMC sends its own identifier.
In our lab, the DHCP requests are relayed: 1G OOB port → top-of-rack 100G switch → MAAS. We set a static reservation for the BMC MAC in MAAS (needed for Redfish power management)
and left the OOB on the dynamic pool.
Tips from build experience
  • Packer-maas’s cleanup.sh runs apt-get autoremove --purge which strips BlueField kernel modules unless you explicitly apt-mark hold them. The DOCA 3.3.0 script includes holds for
    both the meta packages and the specific kernel image/modules/headers.
  • If you hit build errors, run make clean before retrying — stale state
    from previous builds can cause non-obvious failures.
  • If you get KVM permission errors, add yourself to the kvm group:
    sudo usermod -aG kvm $USER && newgrp kvm
