Welcome to MAAS 2.7, a major update to Canonical’s Metal as a Service - the smartest way to manage bare metal.
This latest release of MAAS offers the following:
- Network link disconnect detection
- MAAS will report disconnected network cables
- Administrators can change cable connection status through API/UI, after manually rectifying the situation
- Users will receive a warning when trying to configure a disconnected interface
- Machines will have to be recommissioned to gather this data
- Slow network link detection
- MAAS will automatically detect link and interface speed during commissioning and report them via the API/UI
- Administrators can change or update the link and interface speeds via the API/UI after manual changes to the connection
- Link speed reporting
- Users can filter hosts by their link speed in the UI
- Users can allocate hosts by their link speed in the API
- Users can list machines by their link speed in the API
- Network validation scripts and testing
- Users can test their network configuration to check for:
- Unreachable URLs
- Administrators can:
- Upload network tests and test scripts
- Create tests which accept an interface and URL parameter
- Create scripts which apply custom network configurations
- Users can:
- Specify (unique) parameters using API for all commissioning and test scripts of any type
- Specify URLs to be tested from the UI and API
- See the overall status of all interfaces via the API, the UI Machine list, and the UI Interfaces tab
- See the health status from all interface tests
- View interface test results by interface name and MAC
- Override machines which fail network testing (allowing their use)
- Suppress individual failed network tests
- Live IP address detection to prevent address conflicts
- MAAS will detect IPs in use on a subnet and avoid assigning that IP to a MAAS-managed machine
- MAAS will recognize when the subnet ARP cache is full and re-check the oldest IPs added to the cache to search for free IP addresses
- Introductory NUMA / SR-IOV support
- MAAS will guarantee that existing machines are assigned to a single NUMA node that contains all the machine’s resources; note that recommissioning is needed to gather NUMA / SR-IOV data.
- User can specify NUMA node index for interfaces and physical block devices from the API
- MAAS will display the NUMA node index and details
- Users can see the count of available NUMA nodes, along with CPU cores, memory, NICS, and node spans for bonds, block devices
- Users can filter machines by CPU cores, memory, subnet, VLAN, fabric, space, storage, RAID, and so forth
- CentOS 8 image support
- Users can now deploy CentOS 8 images in MAAS
- Note that users of previous versions may see CentOS 8 available as an option, but cannot download or deploy it
- Settings and user preferences re-designed
- This is part of our efforts to make the UI faster and more responsive
- Strictly-confined Snap support
- With 2.7, MAAS is fully confined within the container, which also takes advantage of the security features of confined snaps.
- No need for installation qualifiers (such as “–devmode”) to permit use of resources outside the Snap container
- Update to hardware information gathering methods
- MAAS has switched hardware information gathering from lshw/lsblk to lxd output during commissioning, because it more easily provides the information needed to complete resource discovery
- Note that this information may not be particularly reliable for your use, so you may need to create your own commissioning scripts if you need something more detailed or specific
A number of bug fixes (see the list in Launchpad).
