We are happy to announce MAAS 2.6.0 RC, which only includes bug fixes and improvements.
Bug fixes
For other issues or bugs fixed in this release, please refer to:
https://launchpad.net/maas/+milestone/2.6.0rc1
| Bug # | Description |
| #1827149 | [2.5,2.6] Deploying an ‘allocated’ machine with install_kvm=True fails to create a bridge |
| #1828602 | [2.5.3] bug: deploy failed when more than 33 rack controller in dns resolver, cause argument list too long and dns resolution stop working |
| #1830133 | [UI] All results/logs are being shown as undefined |
| #1803594 | [2.5] Can create a bcache from a pre-existing bcache. |
| #1812402 | [2.5, RBAC, API, UI] Auditors are allowed to create devices |
| #1828310 | [2.6, events] duplicate events for the same action for START/FINISH |
| #1828444 | [2.6] Cannot filter machines by fabric/vlan, subnet or even status when executing ‘machines read’ |
| #1828493 | [2.6, events] The rebooting event on deployment is shown too early |
| #1828633 | [2.6, events] Test events don’t have details at all |
| #1829225 | [2.6b4] filtering is broken, count shows more than actually exist |
| #1829504 | [2.6, master] Machine action doesn’t reset back to no action, showing an error |
| #1830080 | [2.6] Unable to delete domain after adding A record with empty Data field. |
| #1830103 | [2.5] Node deployment fails with vague error |
| #1830785 | [UI] Unable to delete and recreate VMFS datastore |
| #1811380 | [2.5, RBAC, UI] Notice about not being able to modify storage isn’t shown for resource pool admins |
| #1811669 | [2.5, RBAC, UI] User that looses access to an allocated machine can still edit mount points |
| #1818556 | [2.5, UI] cannot set power parameters for rack controllers |
| #1820984 | [2.6a1] MAAS provides bogus log messages when a ‘device’ tries to PXE boot |
| #1828579 | The maas_id label for prometheus metrics should use the server uuid |
| #1828583 | [2.6] Expose prometheus stats for subnets |
| #1830251 | Add label for prometheus metrics for controller type (rack/region) for mem/cpu metrics |
| #1830267 | [UI] Blank line in log/result shows odd break |
| #1830303 | Datastores do not show the proper mount point |
| #1830786 | [UI] Add to existing datastore button should be disabled when there are no datastores |
| #1816940 | Machines REST API fails to parse postman OAuth token |
| #1827155 | [UI] Relevant error not shown when trying to release 2 machines |
| #1827293 | ESXi static routes are ignored |
https://launchpad.net/maas/+milestone/2.6.0rc2
| #1831147 | Deploying machine with install_rackd=True is not working |
| #1804563 | can’t update dns resource using cli |
| #1831257 | maas 2.6 no such constraint for domain during machines read |
Availability
MAAS 2.6.0~rc2 is available in the following PPA:
sudo apt install maas
