I REALLY hate the auto-commissioning feature in MaaS.
If I add a VM on a KVM pod outside of MaaS (ie. virt-manager), and then refresh the pod, it automatically commissions the VM. If I add a machine manually, it also automatically commissions it.
I just want to be able to opt-out of it before MaaS decides to shutdown the machine and start commissioning.
A solution would be to add an option to skip commissioning and label the system something like “non-MaaS” where you could only really use the power management features unless fully commissioned.
