Hello guys. Thank you for helping us. ![]()
I am not able to deploy CEPH on MAAS hosts, nor isolated installation, nor together with OpenStack.
The problem is that CEPH in all installations does not accept the Storage MAAS deployment, which in my case is booting on a group of 4 hard drives in RAID6, adding up to 40T.
As I mentioned in another distress call, still waiting for some return from the community the RAID6 does not pass the SMART test. However, if I put the RAID to boot when commissioning, then I can make the Host of this machine (generated in the KVM) make this asset available, to be consumed by the deploy via Juju, or directly by MAAS.
But when I try to install CEPH, the return is always the same:
. No block devices detected using current configuration
. Monitor bootstrapped but waiting for number of OSDs to reach expected-osd-count
. Cannot use /dev/sda: device is partitioned
I tried in some ways in search in this environment and on google in general, but I haven’t found a solution yet.
The JUJU fully deployed OpenStack, failing only in CEPH.
Thank you if you can answer me.
Greetings to all
Super enlightening, and thank you for that.
