This article will show you:
- How to create and assign network interface tags
- How to remove and delete network interface tags
- How to view network interface tags
- Go to the machine list and select the machine where that interface resides, by clicking on that machine’s name:
- Click on the “Network” tab:
- Choose the interface you’d like to tag, by selecting the checkbox next to its name:
- Select the drop-down under “ACTIONS” at the end of the row, and select “Edit Physical” to edit the parameters of the physical interface:
Edit the “Tags” field as desired.
Be sure to select the “Tag machine” button to apply your changes to the interface for that machine.
- Choose the interface you’d like to un-tag, by selecting the checkbox next to its name:
- Choose the interface you’d like to see, by selecting the checkbox next to its name:
- Be sure to cancel the operation when you’re done.
- How to discover the ID of your network interface
- How to assign tags to a network interface
- How to remove tags from a network interface
- How to list tags for all network interfaces
- How to view tags for one network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
mac_address type id tags
00:16:3e:18:7f:ee physical 9 andrpko plinko cochise
For example:
For example:
|@tsv'| column -t
For example:
|@tsv'| column -t
00:16:3e:18:7f:ee physical 9 andrpko plinko cochise farquar
|@tsv'| column -t
For example:
|@tsv'| column -t
