Upgrading from MAAS 2.6 snap
If you are using the MAAS 2.6 snap, which had to be installed with --devmode, you can update to 2.7 with the following parameters:
snap refresh maas --devmode --channel=2.7
Be aware that you will still be in --devmode, which means the snap won’t automatically upgrade. You’ll have to check manually for updates (via snap refresh). Once you’re upgraded to MAAS 2.7 using this method, future snap updates won’t require the devmode parameter. So, for example, when a later version of 2.7 (or even 2.8) is released, you will be able to snap refresh to those channels and get out of devmode. Once refreshed out of devmode in this way, you’ll get updates for point releases automatically.
An alternative to avoid devmode would be to do a clean install of MAAS 2.7, that is, removing 2.6 with snap remove maas and reinstalling MAAS 2.7 with:
snap install --channel=2.7 maas
Note that you can check the devmode status of your snap with:
snap list maas
Upgrade 2.4 to 2.5
To upgrade MAAS from 2.4 to 2.5:
sudo apt upgrade
Upgrading from MAAS 2.3 to MAAS 2.4
MAAS 2.3 is the last supported version for Ubuntu 16.04 LTS. Changes in the base dependencies of Ubuntu 18.04 LTS mean that newer versions of MAAS will not be back-portable, and consequently, to upgrade to MAAS 2.4 and all future versions, you will also need to upgrade the base operating system.
MAAS 2.3 will continue to be supported on Ubuntu 16.04 LTS until the end of its support cycle. See Ubuntu Releases for release and EOL dates for all Ubuntu versions.
Upgrading from MAAS 2.3 to MAAS 2.4 involves two steps:
- Update Ubuntu 16.04 LTS to Ubuntu 18.04 LTS, automatically migrating both the MAAS database and the MAAS configuration for MAAS 2.4.
- Upgrade the PostgreSQL database used by MAAS from version 9.x to version 10.
Prior to the upgrade all packages should be updated. It is also strongly recommended that backups be made and that a test environment that mirrors your production environment be upgraded first, to pre-empt any issues.
Upgrade MAAS
To upgrade to MAAS 2.4, simply upgrade the operating system; the process that upgrades Ubuntu will also upgrade the software, including MAAS.
To upgrade Ubuntu, administrators need only type:
sudo do-release-upgrade
After the upgrade process completes and the machine is rebooted, MAAS will continue to use the PostgreSQL 9.x version that came with Ubuntu 16.04 LTS. However, because Ubuntu 18.04 LTS switches to PostgreSQL 10, it is imperative we upgrade the database as well.
Upgrade PostgreSQL
The PostgreSQL upgrade process is fairly simple.
First, use the following command to verify that both version 9.x and 10 PostgreSQL clusters are available:
pg_lsclusters
The output should look similar to the following:
Ver Cluster Port Status Owner Data directory Log file
9.5 main 5432 online postgres /var/lib/postgresql/9.5/main postgresql-9.5-main.log
10 main 5433 online postgres /var/lib/postgresql/10/main postgresql-10-main.log
With both clusters verified to be online, stop MAAS and PostgreSQL:
sudo service maas-rackd stop
sudo service maas-regiond stop
sudo service postgresql stop
Next, rename the main cluster created by the installation of PostgreSQL 10 so that it doesn’t conflict with the upgrade:
sudo pg_renamecluster 10 main main_pristine
The output from pg_lsclusters should now look like the following:
9.5 main 5432 down postgres /var/lib/postgresql/9.5/main postgresql-9.5-main.log
10 main_pristine 5433 down postgres /var/lib/postgresql/10/main_pristine postgresql-10-main_pristine.log
We can now safely upgrade the 9.x cluster:
sudo pg_upgradecluster 9.5 main
The final output from the previous command should show the new PostgreSQL version 10 main cluster is online:
10 main 5432 online postgres /var/lib/postgresql/10/main postgresql-10-main.log
With the version 10 cluster verified as running, we can now drop the other clusters:
sudo pg_dropcluster 9.5 main
sudo pg_dropcluster 10 main_pristine
PostgreSQL has now been upgraded and you can now either reboot your machine or restart the MAAS services we stopped earlier:
sudo service maas-rackd start
sudo service maas-regiond start
Upgrading from 2.0/1/2/3 of MAAS to 2.5
If you’re running MAAS 2.3 or older, please see the following for more information about an upgrade path that makes sense for your installation. MAAS 2.3 was the last version to support Ubuntu 16.04 LTS.
Upgrading from 1.9
If you’re running MAAS 1.9, please start with the following and then see the section above. MAAS 1.9 was the last version to support Ubuntu 14.04 LTS.
See the Releases section on the Ubuntu wiki for more information about the Ubuntu release schedule.
