How to manage machines (deb/3.0/UI)
This article explains:
This article also provides a storage layouts reference](#heading–storage-layouts-reference).
Most of the day-to-day work of managing machines is covered here. Utilising machines to do work – for example, commissioning, testing, and deploying them – is discussed in How to deploy machines.
How to create, delete, and configure machines
This section shows you:
How to add a machine manually
The fields on the “Add machine” screen include the following items:
  • Machine name: This field is used to identify the machine to the user. It can be set to anything, though it is often set to the MAC address of the machine in question. This field is optional, in that MAAS will assign a unique, nonsense name if you leave it blank. You can change this nonsense name later, if desired.
  • Domain: This field sets the domain name of the domain managed by MAAS. It can be set to anything; MAAS assigns the domain name “maas” by default.
  • Architecture: This field refers to the architecture of the machine being added.
  • Minimum Kernel: This field supplies a drop-down of possible kernels available for deployment on this machine.
  • Zone: This field allows you to set the availability zone, selected from AZs that you have already created (if any).
  • Resource pool: This field allows you to set the resource pool for this machine, selected from pools you have already created (if any).
  • MAC Address: You should fill in this field with the MAC address of the machine you are adding. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators.
  • Power type: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management reference for details on the available power types and the relevant parameters for each type.
You can use the chassis feature to add multiple machines at once. To do this, instead of selecting ‘Machine’ as above, choose ‘Chassis’ from the drop-down menu. In the following example, MAAS will add all available VMs from the given virsh address:
To create a new machine at the command line, enter the following information:
> architecture=$ARCH \
> power_type=$POWER_TYPE \
When you enter the command (substituting the $... parameters for your own particulars), the screen will pause for a moment, and then return a stream of JSON relating to the added machine.
> architecture=amd64 \
> power_type=virsh \
The variable fields in the machines create command (the $... items) are as follows, in this example:
  • $ARCH: This field refers to the architecture of the machine being added, amd64 in the local laptop example.
  • $MAC_ADDRESS: This is the MAC address of the boot-enabled NIC for the machine being added. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators.
  • $POWER_TYPE: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management reference for details on the available power types and the relevant parameters for each type. In this example, we’ve used a “virsh” power type (a libvirt KVM), but your choice will depend on your hardware.
  • $POWER_ID: This is generally the UUID of the machine being added.
  • $POWER_ADDRESS/$POWER_PASSWORD: In the case of a KVM, these are the only parameters that need to be entered. See Power types in the API reference for details on the available power types and the relevant parameters for each type.
How to manage attached USB and PCI devices
To delete PCI/USB devices from the machine in any machine state, via the CLI only, using the following command:
maas $PROFILE node-device delete $SYSTEM_ID $DEVICE_ID
where:
  • $PROFILE = your user profile (e.g., “admin”)
  • $SYSTEM_ID = the ID of the machine in question (e.g., “ngx7ry”)
  • $DEVICE_ID = the ID of the device you want to delete
If the device is still present in the system, it will be recognised again (and thus “recreated”) when the machine is commissioned again.
MAAS version 2.9 does not recognise PCI and USB devices. Please upgrade to MAAS version 3.0 or greater to obtain this capability.
How to examine machines and machine details
This section describes the various ways you can evaluate the health and status of your MAAS machines, using the machine list. It will show you:
How to view the machine list
To view the machine list, enter a command similar to this one:
maas $PROFILE machines read | jq -r '(["HOSTNAME","SYSID",
"POWER","STATUS","OWNER", "TAGS", "POOL","VLAN","FABRIC",
"SUBNET"] | (., map(length*"-"))),(.[] | [.hostname, .system_id,
.power_state, .status_name, .owner // "-",.tag_names[0] // "-",
.pool.name,.boot_interface.vlan.name,.boot_interface.vlan.fabric,
This will return a relatively compact machine listing:
HOSTNAME      SYSID   POWER  STATUS     OWNER  TAGS                 POOL     VLAN      FABRIC    SUBNET
 lxd-vm-1      r8d6yp  off    Deployed   admin  pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 lxd-vm-2      tfftrx  off    Allocated  admin  pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 lxd-vm-3      grwpwc  off    Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 lxd-vm-4      6s8dt4  off    Deployed   admin  pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 lxd-vm-5      pyebgm  off    Allocated  admin  pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 lxd-vm-6      ebnww6  off    New        -      pod-console-logging  default  untagged  fabric-1
 libvirt-vm-1  m7ffsg  off    Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 libvirt-vm-2  kpawad  off    Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 libvirt-vm-3  r44hr6  error  Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 libvirt-vm-4  s3sdkw  off    Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 libvirt-vm-5  48dg8m  off    Ready      -      pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
 libvirt-vm-6  bacx77  on     Deployed   admin  pod-console-logging  default  untagged  fabric-1  10.124.141.0/24
You can view various details for your machines, by changing the jq command as desired:
This command, for example, will display machine power status, life-cycle status, and various networking parameters:
How to view machine details
To view output similar to the MAAS UI machine details page, execute the following shell script:
#!/bin/nohighlight
maas admin machine read r3rd6h | jq '.' > /tmp/machine-json
cat /tmp/machine-json | jq -r '([.hostname,.status_name,"| Power:",.power_state,"| Kernel:",.hwe_kernel,"| Owner:",.owner]) | @tsv' | column -t -o " " > /tmp/machine-details
cat /tmp/machine-json | jq -r '(["CPU:",.architecture,"/",.cpu_count,"core(s) /",.cpu_speed,"Mhz","| Type:",.hardware_info.cpu_model]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Memory:",.memory,"MB | Storage:",.storage,"MB | Power type:",.power_type]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Zone:",.zone.name,"| Resource pool:",.pool.name,"| Domain:",.domain.name]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Tags:",.tag_names[]]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["SYSTEM Vendor:",.hardware_info.system_vendor,"| Product:",.hardware_info.system_product]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".......Vsn:",.hardware_info.system_version,"| Serial:",.hardware_info.system_serial]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["MAINBOARD Vendor:",.hardware_info.mainboard_vendor,"| Product:",.hardware_info.mainboard_product]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["..........Firmware:",.hardware_info.mainboard_firmware_vendor]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["..........Firmware Vsn:",.hardware_info.mainboard_firmware_version,"| Date:",.hardware_info.mainboard_firmware_date]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["NETWORK: Vendor:",.boot_interface.vendor]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".........Name:",.boot_interface.name,"| MAC:",.boot_interface.mac_address,"| Link speed:",.boot_interface.link_speed,"Mbps"]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".........Fabric:",.boot_interface.vlan.fabric,"| MAAS DHCP:",.boot_interface.vlan.dhcp_on,"| SR-IOV:",.boot_interface.sriov_max_vf]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-details
This shell script should produce output similar to the following:
merry-cobra Deployed | Power: on | Kernel: ga-20.04 | Owner: admin
CPU: amd64/generic / 1 core(s) / 1600 Mhz | Type: Intel(R) Core(TM) i5-8265U CPU
Memory: 2048 MB | Storage: 8000.004096 MB | Power type: lxd
Zone: default | Resource pool: default | Domain: maas
Tags: pod-console-logging virtual
SYSTEM Vendor: QEMU | Product: Standard PC (Q35 + ICH9, 2009)
.......Vsn: pc-q35-5.2 | Serial: Unknown
MAINBOARD Vendor: Canonical Ltd. | Product: LXD
..........Firmware: EFI Development Kit II / OVMF
..........Firmware Vsn: 0.0.0 | Date: 02/06/2015
NETWORK: Vendor: Red Hat, Inc.
.........Name: enp5s0 | MAC: 00:16:3e:cc:17:58 | Link speed: 0 Mbps
.........Fabric: fabric-5 | MAAS DHCP: true | SR-IOV: 0
To view the machine list, select “Machines” on the top menu of the MAAS web UI:
To quickly view more details, roll the cursor over status icons:
To open a detailed view of a machine’s status and configuration, click a machine’s FQDN or MAC address:
How to find network info for a machine
To find network info for a specific machine, open that machine’s “Network” tab in the machine summary:
How to find machine storage info
To view/edit machine storage info, click on the “Storage” tab in the machine summary:
See the section about storage for more information.
How to find commissioning logs
The “Commissioning” tab brings up a summary log of commissioning events:
Click on the dropdown at the end of the row you’re interested in, and click on “View details”:
This will bring up a detailed log view for that row:
These logs present an extremely detailed, timestamped record of completion and status items from the commissioning process. See the article on Logging for more details on how to read and interpret these logs.
How to find machine hardware & test logs
This tab presents a summary of tests run against this particular machine. You can view the summary report, or choose the “View details” dropdown to get details on any particular tests:
The format of these screens is very similar to the Configuration logs shown above.
How to find raw log output for a machine
By choosing “Installation output” on the “Logs” tab, you can see the “raw” log output:
How to find a machine’s event logs
To view the Event log for a machine, choose the “Event” tab under “Logs.” This displays a list of timestamped status updates for events and actions performed on the machine:
There is a dropdown on the upper right which allows you to choose how many events per page you wish to view. Detailed discussion of this event log can be found under the Logging section of this documentation.
How to find machine configuration info
There are two sections to this tab. The “Machine configuration” section, shown above, offers some general parameters, mostly related to how this machine is grouped and categorised. More information on these options are found in the relevant sections of the documentation (e.g., tags, resource pools, and so forth).
The “Power configuration” supplies the parameters necessary for MAAS to access the machine to PXE-boot it:
How to use resource pools
This section will explain:
How to add a resource pool
How to delete a resource pool
How to add a machine to a resource pool
How to remove a machine from a resource pool
How to add a VM host to a resource pool
How to remove a VM host from a resource pool
How to create a resource pool
How to list available resource pools
How to list a single resource pool
How to update a resource pool
How to use annotations
This section will show you:
How to use static annotations
How to identify your machines
maas $PROFILE machines read \
|@tsv' | column -t
For example:
maas admin machines read \
|@tsv' | column -t
hostname       system_id
divine-stork   8b3ypp
casual-prawn   4end6r
driven-teal    tgaat6
immune-beetle  43xand
good-osprey    napfxk
smart-hen      c4rwq7
boss-satyr     xn8taa
golden-martin  8fxery
crack-guinea   qk4b3g
finer-leech    cy3dtr
free-mouse     gxtbq4
humble-bunny   srqnnb
wanted-muskox  ekw7fh
one-boa        by477d
great-urchin   srnx4g
ace-frog       g6arwg
alive-marlin   gbwnfb
picked-parrot  am77wn
tough-kit      ke3wc7
legal-whale    8nq3mt
game-sponge    76pdc6
fun-ghoul      qxfm7k
aware-earwig   8m8hs7
chief-crane    7fapx7
select-tapir   4ascbr
on-slug        snfs8d
polite-llama   dbqd4m
frank-coyote   wcmk48
usable-condor  ed8hmy
still-imp      h6ra6d
How to set a static annotation for a machine
For example:
How to change or clear a static annotation for a machine
How to list static annotations for all machines
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  description
driven-teal    tgaat6     tango-golf
humble-bunny   srqnnb     sierra-romeo
tough-kit      ke3wc7     kilo-echo
How to view a static annotation for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
How to use dynamic (workload) annotations
How to identify machines that can receive dynamic annotations
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  status
divine-stork   8b3ypp     Deployed
casual-prawn   4end6r     Ready
driven-teal    tgaat6     Allocated
immune-beetle  43xand     Allocated
good-osprey    napfxk     Allocated
smart-hen      c4rwq7     Allocated
boss-satyr     xn8taa     Ready
golden-martin  8fxery     Allocated
crack-guinea   qk4b3g     Allocated
finer-leech    cy3dtr     Deployed
free-mouse     gxtbq4     Allocated
humble-bunny   srqnnb     Allocated
wanted-muskox  ekw7fh     Deployed
one-boa        by477d     Allocated
great-urchin   srnx4g     Allocated
ace-frog       g6arwg     Ready
alive-marlin   gbwnfb     Deployed
picked-parrot  am77wn     Allocated
tough-kit      ke3wc7     Deployed
legal-whale    8nq3mt     Allocated
game-sponge    76pdc6     Allocated
fun-ghoul      qxfm7k     Allocated
aware-earwig   8m8hs7     Deployed
chief-crane    7fapx7     Ready
select-tapir   4ascbr     Allocated
on-slug        snfs8d     Allocated
polite-llama   dbqd4m     Allocated
frank-coyote   wcmk48     Allocated
usable-condor  ed8hmy     Deployed
still-imp      h6ra6d     Allocated
How to set dynamic annotations for a machine
Dynamic annotations, otherwise known as “workload annotations” or “owner data,” can be used to keep track of the runtime status of machines that are acquired or deployed. These annotations are set using key=value pairs. You can set any key=value pair that you wish for any machine, although it’s probably more useful if you standardise your key names.
For example:
How to clear and change dynamic annotations for a machine
You can change dynamic annotations for a machine simply by executing a new set-owner-data command:
You can clear a dynamic annotation by entering the empty string ("") as the $VALUE:
How to list dynamic annotations for all machines
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname       system_id  owner_data
divine-stork   8b3ypp
casual-prawn   4end6r
driven-teal    tgaat6     farquar     foobar
good-osprey    napfxk
smart-hen      c4rwq7
How to list dynamic allocations for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
How to use machine storage
```nohighlight
How to erase disks
and not:
How to manage block devices
How to list block devices
Output:
        "id": 10,
        "serial": "",
        "block_size": 4096,
        "available_size": 0,
        "filesystem": null,
        "id_path": "/dev/vda",
        "size": 5368709120,
        "model": "",
        "type": "physical",
        "uuid": null,
        "used_size": 5365563392,
        "partitions": [
                "bootable": false,
                "id": 9,
                "size": 5360320512,
                "type": "partition",
                "filesystem": {
                    "mount_options": null,
                    "label": null,
                    "fstype": "lvm-pv",
                    "mount_point": null
        "tags": [
            "rotary"
        "name": "vda"
        "id": 11,
        "serial": null,
        "block_size": 4096,
        "filesystem": {
            "label": "root",
            "fstype": "ext4",
            "mount_point": "/"
        "id_path": null,
        "size": 3221225472,
        "partition_table_type": null,
        "model": null,
        "type": "virtual",
        "used_size": 3221225472,
        "partitions": [],
        "tags": [],
        "name": "vgroot-lvroot"
How to read a block device
    "name": "vgroot-lvroot",
    "type": "virtual",
    "filesystem": {
        "mount_point": "/",
        "fstype": "ext4",
        "label": "root"
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to create a block device
    "name": "vdb",
    "used_for": "Unused",
    "type": "physical",
    "used_size": 0,
    "filesystem": null,
    "id_path": "",
    "id": 12,
    "block_size": 4096,
    "tags": [],
    "uuid": null,
    "serial": "QM00001",
    "partitions": [],
    "size": 21474836480,
    "model": "QEMU"
How to update a block device
    "block_size": 4096,
    "filesystem": null,
    "model": "QEMU",
    "name": "newroot",
    "partitions": [],
    "tags": [],
    "used_size": 0,
    "id_path": "",
    "uuid": null,
    "id": 12,
    "type": "physical",
    "serial": "QM00001"
How to delete a block device
How to format a block device
    "block_size": 4096,
    "size": 3221225472,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
        "mount_point": null
    "model": null,
    "partitions": [],
    "tags": [],
    "id_path": null,
    "id": 11,
    "type": "virtual",
    "serial": null
    "available_size": 3221225472,
    "type": "virtual",
    "used_size": 0,
    "filesystem": null,
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to mount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": "/srv",
        "mount_options": "",
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to unmount a block device
    "type": "virtual",
    "filesystem": {
        "mount_point": null,
        "fstype": "ext4",
        "label": ""
    "id_path": null,
    "id": 11,
    "block_size": 4096,
    "tags": [],
    "serial": null,
    "partitions": [],
    "size": 3221225472,
    "model": null
How to manage partitions
How to list partitions
        "bootable": false,
        "id": 9,
        "resource_uri":
        "size": 5360320512,
        "filesystem": {
            "label": null,
            "fstype": "lvm-pv",
            "mount_point": null
How to create a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to delete a partition
How to format a partition
    "id": 9,
    "size": 5360320512,
    "bootable": false,
    "filesystem": {
        "fstype": "ext4",
        "label": ""
How to unformat a partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
How to mount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
How to unmount a partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": "",
        "fstype": "ext4",
        "mount_point": null
    "id": 3,
    "size": 2000003072
How to manage VMFS datastores
How to list VMFS datastores
        "human_size": "45.8 GB",
        "filesystem": {
            "fstype": "vmfs6",
        "name": "datastore1",
        "system_id": "4qxaga",
        "devices": [
                "size": 35026632704,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 5,
                "id": 71,
                "size": 10729029632,
                "bootable": false,
                "tags": [],
                "filesystem": {
                    "fstype": "vmfs6",
                    "label": null,
                "device_id": 6,
                "id": 77,
        "id": 17,
        "size": 45755662336,
How to view a VMFS datastore
    "system_id": "b66fn6",
    "id": 18,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "2.8 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
    "size": 2814377984,
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "device_id": 1,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "id": 80,
    "name": "datastore42",
    "filesystem": {
        "fstype": "vmfs6",
    "id": 19,
    "size": 2814377984,
How to edit a VMFS datastore
    "id": 19,
    "filesystem": {
        "fstype": "vmfs6",
    "human_size": "13.5 GB",
    "devices": [
            "size": 2814377984,
            "bootable": false,
            "tags": [],
            "id": 80,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 1,
            "bootable": false,
            "tags": [],
            "id": 86,
            "filesystem": {
                "fstype": "vmfs6",
                "label": null,
            "device_id": 2,
    "size": 13543407616,
How to define custom storage layouts
MAAS 3.1 allows you to define a custom storage layout for a machine, via a custom commissioning script. You must upload a script which conforms to the following rules:
  • it must run after the 40-maas-01-machine-resources script and before the 50-maas-01-commissioning one, so it should have a name that starts with anything between 41- and 49-. This ensures the script can access the JSON file created by the former which provides info about the machine hardware and network resources. In addition, the custom script can directly inspect the machine it’s running on to determine how to configure storage.
  • it can read machine hardware/network information from the JSON file at the path specified by $MAAS_RESOURCES_FILE
  • it must output a JSON file at the path specified by $MAAS_STORAGE_CONFIG_FILE with the desired storage layout
  • names of disks provided in the custom layout must match the ones detected by MAAS and provided in the resources file.
Configuration format
The configuration contains two main sections:
  • layout, which lists the desired storage layout in terms of disks and volumes, along with their setup (partitions, volumes, …).
    This consists of a dictionary of device names and their configuration. Each device must have a type property (see below for supported types).
  • mounts, which lists the desired filesystem mount points.
    As an example:
"mounts": {
    "device": "sda2",
    "options": "noatime"
  "/boot/efi": {
    "device": "sda1"
  "/data": {
    "device": "raid0"
A complete $MAAS_STORAGE_CONFIG_FILE would look like this:
    "layouts": {
        "sda": {
        "raid0": {
    "mounts": {
The following device types are supported in the "layout" section:
Disk
"sda": {
  "type": "disk",
  "ptable": "gpt",
  "boot": true,
  "partitions": [
      "name": "sda1",
      "fs": "vfat",
      "size": "100M"
      "bootable": true,
A disk entry defines a physical disk.
The following details can be specified:
  • the partition table type (ptable), which can be gpt or mbr
  • whether it should be selected as boot disk
  • optionally, a list of partitions to create, with their size and filesystem type (fs)
LVM
"lvm0": {
  "type": "lvm",
  "members": [
    "sda1",
    "sdb1",
  "volumes": [
      "name": "data1",
      "size": "5G",
      "fs": "ext4"
      "name": "data2",
      "size": "7G",
      "fs": "btrfs"
An lvm entry defines a VG (volume group) composed by a set of disks or partitions (listed as members). Optionally it’s possible to specify the the LVs (logical volumes) to create.
Those are defined similarly to partitions, with a name and size (and optionally the filesystem).
Bcache
"bcache0": {
  "type": "bcache",
  "cache-device": "sda",
  "backing-device": "sdf3",
  "cache-mode": "writeback",
  "fs": "ext4"
A bcache entry must specify a device to use as cache and one to use as storage. Both can be either a partition or a disk.
Optionally the cache-mode for the Bcache can be specified.
RAID
"myraid": {
  "type": "raid",
  "level": 5,
  "members": [
    "sda",
    "sdb",
    "sdc",
  "spares": [
    "sdd",
    "sde"
  "fs": "btrfs"
A raid entry defines a RAID with a set of member devices.
Spare devices can also be specified.
Configuration examples
Here’s a few examples of custom storage layout configurations that a script could output to the $MAAS_STORAGE_CONFIG_FILE. The examples assumes that the machine has 5 disks (named sda to sde).
Note that there’s no need to add entries for those devices in the layout section if the disks are not explicitly partitioned, but just used by other devices (e.g. RAID or LVM).
Simple single-disk layout with GPT partitioning
  "layout": {
    "sda": {
      "type": "disk",
      "ptable": "gpt",
      "boot": true,
      "partitions": [
          "name": "sda1",
          "fs": "vfat",
          "size": "500M",
          "bootable": true
          "name": "sda2",
          "size": "5G",
          "fs": "ext4"
          "name": "sda3",
          "size": "2G",
          "fs": "swap"
          "name": "sda4",
          "size": "120G",
          "fS": "ext4"
  "mounts": {
      "device": "sda2",
    "/boot/efi": {
      "device": "sda1"
    "/data": {
      "device": "sda4"
    "none": {
      "device": "sda3"
In the mounts section, options for mountpoints can be specified. For swap, an entry must be present (with any unique name that doesn’t start with a /), otherwise the swap will be created but not activated.
RAID 5 setup (with spare devices)
  "layout": {
    "storage": {
      "type": "raid",
      "level": 5,
      "members": [
        "sda",
        "sdb",
        "sdc"
      "spares": [
        "sdd",
        "sde"
      "fs": "btrfs"
  "mounts": {
    "/data": {
      "device": "storage"
Both full disks and partitions can be used as RAID members.
LVM with pre-defined volumes
  "layout": {
    "storage": {
      "type": "lvm",
      "members": [
        "sda",
        "sdb",
        "sdc",
        "sdd"
      "volumes": [
          "name": "data1",
          "size": "1T",
          "fs": "ext4"
          "name": "data2",
          "size": "2.5T",
          "fs": "btrfs"
  "mounts": {
    "/data1": {
      "device": "data1"
    "/data2": {
      "device": "data2"
If no volumes are specified, the volume group is still created.
Bcache
  "layout": {
     "data1": {
      "type": "bcache",
      "backing-device": "sdb",
      "fs": "ext4"
    "data2": {
      "type": "bcache",
      "backing-device": "sdc",
      "fs": "btrfs"
  "mounts": {
    "/data1": {
      "device": "data1"
    "/data2": {
      "device": "data2"
The same cache set can be used by different bcaches by specifying the same backing-device for them.
LVM on top of RAID with Bcache
  "layout": {
    "bcache0": {
      "type": "bcache",
      "backing-device": "sda",
      "cache-device": "sdf"
    "bcache1": {
      "type": "bcache",
    "bcache2": {
      "type": "bcache",
    "bcache3": {
      "type": "bcache",
      "backing-device": "sdd",
    "bcache4": {
      "type": "bcache",
      "backing-device": "sde",
    "raid": {
      "type": "raid",
      "level": 5,
      "members": [
        "bcache0",
        "bcache1",
        "bcache2"
      "spares": [
        "bcache3",
        "bcache4"
    "lvm": {
      "type": "lvm",
      "members": [
        "raid"
      "volumes": [
          "name": "root",
          "size": "10G",
          "fs": "ext4"
          "name": "data",
          "size": "3T",
          "fs": "btrfs"
  "mounts": {
      "device": "root"
    "/data": {
      "device": "data"
The RAID is created by using 5 bcache devices, each one using a different disk and the same SSD cache device. LVM is created on top of the RAID device and volumes are then created in it, to provide partitions.
Custom storage layouts are available in MAAS version 3.1 and greater.
Storage layouts reference
There are three layout types:
  1. Flat layout
  2. LVM layout
  3. bcache layout
Flat layout storage reference
sda - disk
sda2 rest of sda part ext4 /
LVM storage layout reference
sda - disk
lvroot rest of sda lvm ext4 /
vgroot rest of sda lvm
sda - disk
sdb (ssd) - disk
bcache0 per sda2 disk ext4 /
vmfs6 storage layout reference
Name Size Type Use
sda - disk
sda1 3 MB part EFI
sda2 4 GB part Basic Data
sda4 - skipped
sda5 249 MB part Basic Data
sda6 249 MB part Basic Data
sda8 285 MB part Basic Data
