This tutorial will walk you through the basics of the MAAS CLI.
Log in
Fetch your API key: Generate your unique key with the following command.
maas apikey --username=$MAAS_USER > api-key
Login: Use your API key to authenticate.
maas login admin http://<maas.domain>:5240/MAAS/api/2.0/ < api-key
Configure MAAS
Set the DNS forwarder: If it’s your first time, set up DNS forwarding.
maas $MAAS_USER maas set-config name=upstream_dns value=8.8.8.8
Import Ubuntu images: Again, if new, pull in Ubuntu images.
maas $MAAS_USER boot-resources import
Manage nodes
Enlist a node: Add a new machine to MAAS.
maas $MAAS_USER machines create architecture=amd64 \ power_type=virsh mac_addresses=52:54:00:00:00:01
Review status: Confirm the node’s state.
maas $MAAS_USER machines read | jq '.[].status_name'
Commission a node: Prepare the node for deployment.
maas $MAAS_USER machine commission <node_id>
Acquire a node: Claim the commissioned node.
maas $MAAS_USER machines allocate system_id=<id>
Deploy a node: Execute the deployment.
maas $MAAS_USER machine deploy <id>
Connect nodes
Fetch a node’s IP: Retrieve the IP of a deployed node.
lxc list
Gain SSH access: Just log in as
ubuntu
File transfer: Use
scp
for transferring files, and apply your customisations.
