This article explains:
This article also provides a storage layouts reference](#heading–storage-layouts-reference).
Most of the day-to-day work of managing machines is covered here. Utilising machines to do work – for example, commissioning, testing, and deploying them – is discussed in How to deploy machines.
How to create, delete, and configure machines
This section shows you:
How to add a machine manually
The fields on the “Add machine” screen include the following items:
Machine name: This field is used to identify the machine to the user. It can be set to anything, though it is often set to the MAC address of the machine in question. This field is optional, in that MAAS will assign a unique, nonsense name if you leave it blank. You can change this nonsense name later, if desired.
Domain: This field sets the domain name of the domain managed by MAAS. It can be set to anything; MAAS assigns the domain name “maas” by default.
Architecture: This field refers to the architecture of the machine being added.
Minimum Kernel: This field supplies a drop-down of possible kernels available for deployment on this machine.
Zone: This field allows you to set the availability zone, selected from AZs that you have already created (if any).
Resource pool: This field allows you to set the resource pool for this machine, selected from pools you have already created (if any).
MAC Address: You should fill in this field with the MAC address of the machine you are adding. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators.
Power type: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management reference for details on the available power types and the relevant parameters for each type.
You can use the chassis feature to add multiple machines at once. To do this, instead of selecting ‘Machine’ as above, choose ‘Chassis’ from the drop-down menu. In the following example, MAAS will add all available VMs from the given virsh address:
To create a new machine at the command line, enter the following information:
> architecture=$ARCH \
> power_type=$POWER_TYPE \
When you enter the command (substituting the $...
parameters for your own particulars), the screen will pause for a moment, and then return a stream of JSON relating to the added machine.
> architecture=amd64 \
> power_type=virsh \
The variable fields in the machines create
command (the $...
items) are as follows, in this example:
$ARCH
: This field refers to the architecture of the machine being added,amd64
in the local laptop example. -
$MAC_ADDRESS
: This is the MAC address of the boot-enabled NIC for the machine being added. Note that the MAC address entered here must use a colon (":") separator, although some MAC addresses are written with dash ("-") separators. -
$POWER_TYPE
: You must select the power type supported by the machine you are adding, and fill in additional required fields that appear. See Power management reference for details on the available power types and the relevant parameters for each type. In this example, we’ve used a “virsh” power type (a libvirt KVM), but your choice will depend on your hardware. -
$POWER_ID
: This is generally the UUID of the machine being added. -
$POWER_ADDRESS/$POWER_PASSWORD
: In the case of a KVM, these are the only parameters that need to be entered. See Power types in the API reference for details on the available power types and the relevant parameters for each type.
How to manage attached USB and PCI devices
To delete PCI/USB devices from the machine in any machine state, via the CLI only, using the following command:
maas $PROFILE node-device delete $SYSTEM_ID $DEVICE_ID
where:
- $PROFILE = your user profile (e.g., “admin”)
- $SYSTEM_ID = the ID of the machine in question (e.g., “ngx7ry”)
- $DEVICE_ID = the ID of the device you want to delete
If the device is still present in the system, it will be recognised again (and thus “recreated”) when the machine is commissioned again.
MAAS version 2.9 does not recognise PCI and USB devices. Please upgrade to MAAS version 3.0 or greater to obtain this capability.
How to clone machines
Assume you have two machines available, like this:
Select the machine to which you want to clone configuration, and select “Clone from…”
Under “1. Select the source machine” – choose a machine from the attached list:
Under “2. Select what to clone”, choose “Network”, “Storage”, or both (here, we’ve chosen “Storage”):
Click “Clone to machine”. MAAS will report the status of the attempt.
Cloning capability is available in MAAS from version 3.1 forward.
How to examine machines and machine details
This section describes the various ways you can evaluate the health and status of your MAAS machines, using the machine list. It will show you:
- How to view the machine list
- How to view machine details
- How to find network info for a machine
- How to find storage info for a machine
- How to find commissioning logs
- How to find machine hardware & test logs
- How to find raw log output for a machine
- How to find a machine’s event logs
- How to find machine configuration info
To view the machine list, enter a command similar to this one:
maas $PROFILE machines read | jq -r '(["HOSTNAME","SYSID",
"POWER","STATUS","OWNER", "TAGS", "POOL","VLAN","FABRIC",
"SUBNET"] | (., map(length*"-"))),(.[] | [.hostname, .system_id,
.power_state, .status_name, .owner // "-",.tag_names[0] // "-",
.pool.name,.boot_interface.vlan.name,.boot_interface.vlan.fabric,
This will return a relatively compact machine listing:
HOSTNAME SYSID POWER STATUS OWNER TAGS POOL VLAN FABRIC SUBNET
lxd-vm-1 r8d6yp off Deployed admin pod-console-logging default untagged fabric-1 10.124.141.0/24
lxd-vm-2 tfftrx off Allocated admin pod-console-logging default untagged fabric-1 10.124.141.0/24
lxd-vm-3 grwpwc off Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
lxd-vm-4 6s8dt4 off Deployed admin pod-console-logging default untagged fabric-1 10.124.141.0/24
lxd-vm-5 pyebgm off Allocated admin pod-console-logging default untagged fabric-1 10.124.141.0/24
lxd-vm-6 ebnww6 off New - pod-console-logging default untagged fabric-1
libvirt-vm-1 m7ffsg off Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
libvirt-vm-2 kpawad off Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
libvirt-vm-3 r44hr6 error Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
libvirt-vm-4 s3sdkw off Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
libvirt-vm-5 48dg8m off Ready - pod-console-logging default untagged fabric-1 10.124.141.0/24
libvirt-vm-6 bacx77 on Deployed admin pod-console-logging default untagged fabric-1 10.124.141.0/24
You can view various details for your machines, by changing the jq
command as desired:
This command, for example, will display machine power status, life-cycle status, and various networking parameters:
To view output similar to the MAAS UI machine details page, execute the following shell script:
#!/bin/nohighlight
maas admin machine read r3rd6h | jq '.' > /tmp/machine-json
cat /tmp/machine-json | jq -r '([.hostname,.status_name,"| Power:",.power_state,"| Kernel:",.hwe_kernel,"| Owner:",.owner]) | @tsv' | column -t -o " " > /tmp/machine-details
cat /tmp/machine-json | jq -r '(["CPU:",.architecture,"/",.cpu_count,"core(s) /",.cpu_speed,"Mhz","| Type:",.hardware_info.cpu_model]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Memory:",.memory,"MB | Storage:",.storage,"MB | Power type:",.power_type]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Zone:",.zone.name,"| Resource pool:",.pool.name,"| Domain:",.domain.name]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["Tags:",.tag_names[]]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["SYSTEM Vendor:",.hardware_info.system_vendor,"| Product:",.hardware_info.system_product]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".......Vsn:",.hardware_info.system_version,"| Serial:",.hardware_info.system_serial]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["MAINBOARD Vendor:",.hardware_info.mainboard_vendor,"| Product:",.hardware_info.mainboard_product]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["..........Firmware:",.hardware_info.mainboard_firmware_vendor]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["..........Firmware Vsn:",.hardware_info.mainboard_firmware_version,"| Date:",.hardware_info.mainboard_firmware_date]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '(["NETWORK: Vendor:",.boot_interface.vendor]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".........Name:",.boot_interface.name,"| MAC:",.boot_interface.mac_address,"| Link speed:",.boot_interface.link_speed,"Mbps"]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-json | jq -r '([".........Fabric:",.boot_interface.vlan.fabric,"| MAAS DHCP:",.boot_interface.vlan.dhcp_on,"| SR-IOV:",.boot_interface.sriov_max_vf]) | @tsv' | column -t -o " " >> /tmp/machine-details
cat /tmp/machine-details
This shell script should produce output similar to the following:
merry-cobra Deployed | Power: on | Kernel: ga-20.04 | Owner: admin
CPU: amd64/generic / 1 core(s) / 1600 Mhz | Type: Intel(R) Core(TM) i5-8265U CPU
Memory: 2048 MB | Storage: 8000.004096 MB | Power type: lxd
Zone: default | Resource pool: default | Domain: maas
Tags: pod-console-logging virtual
SYSTEM Vendor: QEMU | Product: Standard PC (Q35 + ICH9, 2009)
.......Vsn: pc-q35-5.2 | Serial: Unknown
MAINBOARD Vendor: Canonical Ltd. | Product: LXD
..........Firmware: EFI Development Kit II / OVMF
..........Firmware Vsn: 0.0.0 | Date: 02/06/2015
NETWORK: Vendor: Red Hat, Inc.
.........Name: enp5s0 | MAC: 00:16:3e:cc:17:58 | Link speed: 0 Mbps
.........Fabric: fabric-5 | MAAS DHCP: true | SR-IOV: 0
To view the machine list, select “Machines” on the top menu of the MAAS web UI:
To quickly view more details, roll the cursor over status icons:
To open a detailed view of a machine’s status and configuration, click a machine’s FQDN or MAC address:
To find network info for a specific machine, open that machine’s “Network” tab in the machine summary:
How to find machine storage info
To view/edit machine storage info, click on the “Storage” tab in the machine summary:
See the section about storage for more information.
The “Commissioning” tab brings up a summary log of commissioning events:
Click on the dropdown at the end of the row you’re interested in, and click on “View details”:
This will bring up a detailed log view for that row:
These logs present an extremely detailed, timestamped record of completion and status items from the commissioning process. See the article on Logging for more details on how to read and interpret these logs.
This tab presents a summary of tests run against this particular machine. You can view the summary report, or choose the “View details” dropdown to get details on any particular tests:
The format of these screens is very similar to the Configuration logs shown above.
By choosing “Installation output” on the “Logs” tab, you can see the “raw” log output:
To view the Event log for a machine, choose the “Event” tab under “Logs.” This displays a list of timestamped status updates for events and actions performed on the machine:
There is a dropdown on the upper right which allows you to choose how many events per page you wish to view. Detailed discussion of this event log can be found under the Logging section of this documentation.
There are two sections to this tab. The “Machine configuration” section, shown above, offers some general parameters, mostly related to how this machine is grouped and categorised. More information on these options are found in the relevant sections of the documentation (e.g., tags, resource pools, and so forth).
The “Power configuration” supplies the parameters necessary for MAAS to access the machine to PXE-boot it:
How to use resource pools
This section will explain:
- How to add a resource pool
- How to delete a resource pool
- How to add a node to a resource pool
- How to remove a node from a resource pool
- How to add a VM host to a resource pool
- How to remove a VM host from a resource pool
How to add a machine to a resource pool
How to remove a machine from a resource pool
- How to create a resource pool
- How to list available resource pools
- How to list a single resource pool
- How to update a resource pool
- How to add a machine to a resource pool
Here’s an example that demonstrates how to create a new resource pool named myresource
The description
field is optional.
The name
and description
fields are optional.
How to use annotations
This section will show you:
How to use static annotations
- How to identify your machines
- How to set a static annotation for a machine
- How to change or clear a static annotation for a machine
- How to list static annotations for all machines
- How to view a static annotation for one machine
maas $PROFILE machines read \
|@tsv' | column -t
For example:
maas admin machines read \
|@tsv' | column -t
hostname system_id
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6
immune-beetle 43xand
good-osprey napfxk
smart-hen c4rwq7
boss-satyr xn8taa
golden-martin 8fxery
crack-guinea qk4b3g
finer-leech cy3dtr
free-mouse gxtbq4
humble-bunny srqnnb
wanted-muskox ekw7fh
one-boa by477d
great-urchin srnx4g
ace-frog g6arwg
alive-marlin gbwnfb
picked-parrot am77wn
tough-kit ke3wc7
legal-whale 8nq3mt
game-sponge 76pdc6
fun-ghoul qxfm7k
aware-earwig 8m8hs7
chief-crane 7fapx7
select-tapir 4ascbr
on-slug snfs8d
polite-llama dbqd4m
frank-coyote wcmk48
usable-condor ed8hmy
still-imp h6ra6d
For example:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id description
driven-teal tgaat6 tango-golf
humble-bunny srqnnb sierra-romeo
tough-kit ke3wc7 kilo-echo
|@tsv' | column -t
For example:
|@tsv' | column -t
How to use dynamic (workload) annotations
- How to identify machines that can receive dynamic annotations
- How to set dynamic annotations for a machine
- How to clear and change dynamic annotations for a machine
- How to list dynamic annotations for all machines
- How to list dynamic allocations for one machine
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id status
divine-stork 8b3ypp Deployed
casual-prawn 4end6r Ready
driven-teal tgaat6 Allocated
immune-beetle 43xand Allocated
good-osprey napfxk Allocated
smart-hen c4rwq7 Allocated
boss-satyr xn8taa Ready
golden-martin 8fxery Allocated
crack-guinea qk4b3g Allocated
finer-leech cy3dtr Deployed
free-mouse gxtbq4 Allocated
humble-bunny srqnnb Allocated
wanted-muskox ekw7fh Deployed
one-boa by477d Allocated
great-urchin srnx4g Allocated
ace-frog g6arwg Ready
alive-marlin gbwnfb Deployed
picked-parrot am77wn Allocated
tough-kit ke3wc7 Deployed
legal-whale 8nq3mt Allocated
game-sponge 76pdc6 Allocated
fun-ghoul qxfm7k Allocated
aware-earwig 8m8hs7 Deployed
chief-crane 7fapx7 Ready
select-tapir 4ascbr Allocated
on-slug snfs8d Allocated
polite-llama dbqd4m Allocated
frank-coyote wcmk48 Allocated
usable-condor ed8hmy Deployed
still-imp h6ra6d Allocated
Dynamic annotations, otherwise known as “workload annotations” or “owner data,” can be used to keep track of the runtime status of machines that are acquired or deployed. These annotations are set using key=value
pairs. You can set any key=value
pair that you wish for any machine, although it’s probably more useful if you standardise your key names.
For example:
You can change dynamic annotations for a machine simply by executing a new set-owner-data
command:
You can clear a dynamic annotation by entering the empty string (""
) as the $VALUE:
|@tsv' | column -t
For example:
|@tsv' | column -t
hostname system_id owner_data
divine-stork 8b3ypp
casual-prawn 4end6r
driven-teal tgaat6 farquar foobar
good-osprey napfxk
smart-hen c4rwq7
|@tsv' | column -t
For example:
|@tsv' | column -t
How to use machine storage
```nohighlight
How to erase disks
and not:
Note the difference in singular and plural “machine/machines” in the commands. Releasing a machine requires that you have the system_id
of the machine to be released, which you can obtain with a command like this one:
Parameters secure_erase
and quick_erase
are both optional, although if you don’t specify either of them, the entire disk will be overwritten with null bytes. Note that this overwrite process is very slow.
How to manage block devices
- How to list block devices
- How to read a block device
- How to create a block device
- How to update a block device
- How to delete a block device
- How to format Block Device
- How to unformat a block device
- How to mount a block device
- How to unmount a block device
- How to set a block device as a boot disk
Output:
"id": 10,
"serial": "",
"block_size": 4096,
"available_size": 0,
"filesystem": null,
"id_path": "/dev/vda",
"size": 5368709120,
"model": "",
"type": "physical",
"uuid": null,
"used_size": 5365563392,
"partitions": [
"bootable": false,
"id": 9,
"size": 5360320512,
"type": "partition",
"filesystem": {
"mount_options": null,
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"tags": [
"rotary"
"name": "vda"
"id": 11,
"serial": null,
"block_size": 4096,
"filesystem": {
"label": "root",
"fstype": "ext4",
"mount_point": "/"
"id_path": null,
"size": 3221225472,
"partition_table_type": null,
"model": null,
"type": "virtual",
"used_size": 3221225472,
"partitions": [],
"tags": [],
"name": "vgroot-lvroot"
"name": "vgroot-lvroot",
"type": "virtual",
"filesystem": {
"mount_point": "/",
"fstype": "ext4",
"label": "root"
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"name": "vdb",
"used_for": "Unused",
"type": "physical",
"used_size": 0,
"filesystem": null,
"id_path": "",
"id": 12,
"block_size": 4096,
"tags": [],
"uuid": null,
"serial": "QM00001",
"partitions": [],
"size": 21474836480,
"model": "QEMU"
"block_size": 4096,
"filesystem": null,
"model": "QEMU",
"name": "newroot",
"partitions": [],
"tags": [],
"used_size": 0,
"id_path": "",
"uuid": null,
"id": 12,
"type": "physical",
"serial": "QM00001"
How to format a block device
"block_size": 4096,
"size": 3221225472,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"model": null,
"partitions": [],
"tags": [],
"id_path": null,
"id": 11,
"type": "virtual",
"serial": null
"available_size": 3221225472,
"type": "virtual",
"used_size": 0,
"filesystem": null,
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"type": "virtual",
"filesystem": {
"mount_point": "/srv",
"mount_options": "",
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
"type": "virtual",
"filesystem": {
"mount_point": null,
"fstype": "ext4",
"label": ""
"id_path": null,
"id": 11,
"block_size": 4096,
"tags": [],
"serial": null,
"partitions": [],
"size": 3221225472,
"model": null
How to manage partitions
- How to list partitions
- How to create a partition
- How to delete a partition
- How to format a partition
- How to unformat a partition
- How to mount a partition
- How to unmount a partition
"bootable": false,
"id": 9,
"resource_uri":
"size": 5360320512,
"filesystem": {
"label": null,
"fstype": "lvm-pv",
"mount_point": null
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
"id": 9,
"size": 5360320512,
"bootable": false,
"filesystem": {
"fstype": "ext4",
"label": ""
"bootable": false,
"filesystem": null,
"id": 10,
"size": 5360320512,
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
"bootable": false,
"id": 10,
"size": 5360320512,
"filesystem": {
"label": "",
"fstype": "ext4",
"mount_point": null
"id": 3,
"size": 2000003072
How to manage VMFS datastores
- How to list VMFS datastores
- How to view a VMFS datastore
- How to create a VMFS datastore
- How to edit a VMFS datastore
- How to delete a VMFS datastore
"human_size": "45.8 GB",
"filesystem": {
"fstype": "vmfs6",
"name": "datastore1",
"system_id": "4qxaga",
"devices": [
"size": 35026632704,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 5,
"id": 71,
"size": 10729029632,
"bootable": false,
"tags": [],
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 6,
"id": 77,
"id": 17,
"size": 45755662336,
"system_id": "b66fn6",
"id": 18,
"filesystem": {
"fstype": "vmfs6",
"human_size": "2.8 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"size": 2814377984,
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"device_id": 1,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"id": 80,
"name": "datastore42",
"filesystem": {
"fstype": "vmfs6",
"id": 19,
"size": 2814377984,
"id": 19,
"filesystem": {
"fstype": "vmfs6",
"human_size": "13.5 GB",
"devices": [
"size": 2814377984,
"bootable": false,
"tags": [],
"id": 80,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 1,
"bootable": false,
"tags": [],
"id": 86,
"filesystem": {
"fstype": "vmfs6",
"label": null,
"device_id": 2,
"size": 13543407616,
How to define custom storage layouts
MAAS 3.1 allows you to define a custom storage layout for a machine, via a custom commissioning script. You must upload a script which conforms to the following rules:
- it must run after the
40-maas-01-machine-resources
script and before the50-maas-01-commissioning
one, so it should have a name that starts with anything between41-
and49-
. This ensures the script can access the JSON file created by the former which provides info about the machine hardware and network resources. In addition, the custom script can directly inspect the machine it’s running on to determine how to configure storage. - it can read machine hardware/network information from the JSON file at the path specified by
$MAAS_RESOURCES_FILE
- it must output a JSON file at the path specified by
$MAAS_STORAGE_CONFIG_FILE
with the desired storage layout - names of disks provided in the custom layout must match the ones detected by MAAS and provided in the resources file.
Configuration format
The configuration contains two main sections:
layout
, which lists the desired storage layout in terms of disks and volumes, along with their setup (partitions, volumes, …).
This consists of a dictionary of device names and their configuration. Each device must have atype
property (see below for supported types). -
mounts
, which lists the desired filesystem mount points.
As an example:
"mounts": {
"device": "sda2",
"options": "noatime"
"/boot/efi": {
"device": "sda1"
"/data": {
"device": "raid0"
A complete $MAAS_STORAGE_CONFIG_FILE
would look like this:
"layouts": {
"sda": {
"raid0": {
"mounts": {
The following device types are supported in the "layout"
section:
Disk
"sda": {
"type": "disk",
"ptable": "gpt",
"boot": true,
"partitions": [
"name": "sda1",
"fs": "vfat",
"size": "100M"
"bootable": true,
A disk
entry defines a physical disk.
The following details can be specified:
- the partition table type (
ptable
), which can begpt
ormbr
- whether it should be selected as
boot
disk - optionally, a list of partitions to create, with their
size
and filesystem type (fs
LVM
"lvm0": {
"type": "lvm",
"members": [
"sda1",
"sdb1",
"volumes": [
"name": "data1",
"size": "5G",
"fs": "ext4"
"name": "data2",
"size": "7G",
"fs": "btrfs"
An lvm
entry defines a VG (volume group) composed by a set of disks or partitions (listed as members
). Optionally it’s possible to specify the the LVs (logical volumes) to create.
Those are defined similarly to partitions, with a name and size (and optionally the filesystem).
Bcache
"bcache0": {
"type": "bcache",
"cache-device": "sda",
"backing-device": "sdf3",
"cache-mode": "writeback",
"fs": "ext4"
A bcache
entry must specify a device to use as cache and one to use as storage. Both can be either a partition or a disk.
Optionally the cache-mode
for the Bcache can be specified.
RAID
"myraid": {
"type": "raid",
"level": 5,
"members": [
"sda",
"sdb",
"sdc",
"spares": [
"sdd",
"sde"
"fs": "btrfs"
A raid
entry defines a RAID with a set of member devices.
Spare devices can also be specified.
Configuration examples
Here’s a few examples of custom storage layout configurations that a script could output to the $MAAS_STORAGE_CONFIG_FILE
. The examples assumes that the machine has 5 disks (named sda
to sde
Note that there’s no need to add entries for those devices in the layout
section if the disks are not explicitly partitioned, but just used by other devices (e.g. RAID or LVM).
Simple single-disk layout with GPT partitioning
"layout": {
"sda": {
"type": "disk",
"ptable": "gpt",
"boot": true,
"partitions": [
"name": "sda1",
"fs": "vfat",
"size": "500M",
"bootable": true
"name": "sda2",
"size": "5G",
"fs": "ext4"
"name": "sda3",
"size": "2G",
"fs": "swap"
"name": "sda4",
"size": "120G",
"fS": "ext4"
"mounts": {
"device": "sda2",
"/boot/efi": {
"device": "sda1"
"/data": {
"device": "sda4"
"none": {
"device": "sda3"
In the mounts
section, options for mountpoints can be specified. For swap, an entry must be present (with any unique name that doesn’t start with a /
), otherwise the swap will be created but not activated.
RAID 5 setup (with spare devices)
"layout": {
"storage": {
"type": "raid",
"level": 5,
"members": [
"sda",
"sdb",
"sdc"
"spares": [
"sdd",
"sde"
"fs": "btrfs"
"mounts": {
"/data": {
"device": "storage"
Both full disks and partitions can be used as RAID members.
LVM with pre-defined volumes
"layout": {
"storage": {
"type": "lvm",
"members": [
"sda",
"sdb",
"sdc",
"sdd"
"volumes": [
"name": "data1",
"size": "1T",
"fs": "ext4"
"name": "data2",
"size": "2.5T",
"fs": "btrfs"
"mounts": {
"/data1": {
"device": "data1"
"/data2": {
"device": "data2"
If no volumes are specified, the volume group is still created.
Bcache
"layout": {
"data1": {
"type": "bcache",
"backing-device": "sdb",
"fs": "ext4"
"data2": {
"type": "bcache",
"backing-device": "sdc",
"fs": "btrfs"
"mounts": {
"/data1": {
"device": "data1"
"/data2": {
"device": "data2"
The same cache set can be used by different bcaches by specifying the same backing-device
for them.
LVM on top of RAID with Bcache
"layout": {
"bcache0": {
"type": "bcache",
"backing-device": "sda",
"cache-device": "sdf"
"bcache1": {
"type": "bcache",
"bcache2": {
"type": "bcache",
"bcache3": {
"type": "bcache",
"backing-device": "sdd",
"bcache4": {
"type": "bcache",
"backing-device": "sde",
"raid": {
"type": "raid",
"level": 5,
"members": [
"bcache0",
"bcache1",
"bcache2"
"spares": [
"bcache3",
"bcache4"
"lvm": {
"type": "lvm",
"members": [
"raid"
"volumes": [
"name": "root",
"size": "10G",
"fs": "ext4"
"name": "data",
"size": "3T",
"fs": "btrfs"
"mounts": {
"device": "root"
"/data": {
"device": "data"
The RAID is created by using 5 bcache devices, each one using a different disk and the same SSD cache device. LVM is created on top of the RAID device and volumes are then created in it, to provide partitions.
Custom storage layouts are available in MAAS version 3.1 and greater.
Storage layouts reference
There are three layout types:
- Flat layout
- LVM layout
- bcache layout
The layout descriptions below will include the EFI partition. If your system is not using UEFI, regard sda2
as sda1
(with an additional 512 MB available to it).
Flat layout storage reference
With the Flat layout, a partition spans the entire boot disk. The partition is formatted with the ext4 filesystem and uses the /
mount point:
Name | Size | Type | Filesystem | Mount point |
sda | - | disk | ||
sda1 | 512 MB | part | FAT32 | /boot/efi |
sda2 | rest of sda | part | ext4 | / |
boot_size
: Size of the boot partition on the boot disk. Default is 0, meaning not to create the boot partition. The ‘/boot’ will be placed on the root filesystem. -
root_device
: The block device on which to place the root partition. The default is the boot disk. -
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device.
LVM storage layout reference
The LVM layout creates the volume group vgroot
on a partition that spans the entire boot disk. A logical volume lvroot
is created for the full size of the volume group; is formatted with the ext4 filesystem; and uses the /
mount point:
sda | - | disk | ||
sda2 | rest of sda | part | lvm-pv(vgroot) | |
lvroot | rest of sda | lvm | ext4 | / |
vgroot | rest of sda | lvm |
boot_size
root_device
root_size
: Size of the root partition. Default is 100%, meaning the entire size of the root device. -
vg_name
: Name of the created volume group. Default isvgroot
lv_name
: Name of the created logical volume. Default islvroot
lv_size
: Size of the created logical volume. Default is 100%, meaning the entire size of the volume group.
A bcache layout will create a partition that spans the entire boot disk as the backing device. It uses the smallest block device tagged with ‘ssd’ as the cache device. The bcache device is formatted with the ext4 filesystem and uses the /
mount point. If there are no ‘ssd’ tagged block devices on the machine, then the bcache device will not be created, and the Flat layout will be used instead:
sda | - | disk | ||
sda2 | rest of sda | part | bc-backing | |
sdb (ssd) | - | disk | ||
sdb1 | 100% of sdb | part | bc-cache | |
bcache0 | per sda2 | disk | ext4 | / |
boot_size
root_device
: The block device upon which to place the root partition. The default is the boot disk. -
root_size
cache_device
: The block device to use as the cache device. Default is the smallest block device tagged ssd. -
cache_mode
: The cache mode to which MAAS should set the created bcache device. The default iswritethrough
cache_size
: The size of the partition on the cache device. Default is 100%, meaning the entire size of the cache device. -
cache_no_part
: Whether or not to create a partition on the cache device. Default is false, meaning to create a partition using the givencache_size
. If set to true, no partition will be created, and the raw cache device will be used as the cache.
vmfs6 storage layout reference
Name | Size | Type | Use |
sda | - | disk | |
sda1 | 3 MB | part | EFI |
sda2 | 4 GB | part | Basic Data |
sda3 | Remaining | part | VMFS Datastore 1 |
sda4 | - | skipped | |
sda5 | 249 MB | part | Basic Data |
sda6 | 249 MB | part | Basic Data |
sda7 | 109 MB | part | VMware Diagnostic |
sda8 | 285 MB | part | Basic Data |
sda9 | 2.5 GB | part | VMware Diagnostic |
root_device
: The block device upon which to place the root partition. Default is the boot disk. -
root_size
: Size of the default VMFS Datastore. Default is 100%, meaning the remaining size of the root disk.
