How to manage IP ranges
What is a reserved range?
A reserved range in MAAS refers to a block of IP addresses that are set aside and not allocated automatically by MAAS. This can be useful in scenarios where you want to manually manage IP addresses for specific purposes, such as for critical services, static IPs for certain servers, or integration with other systems like OpenStack.
Reserved ranges and OpenStack
In an OpenStack environment, you might need to reserve IP ranges for specific services such as the management network, storage network, or tenant networks. By reserving these IP ranges in MAAS, you can ensure that these critical addresses are not allocated to other devices, preventing IP conflicts and ensuring reliable network operation.
How to create a reserved range in MAAS (UI)
To set up a reserved range in MAAS (Metal as a Service), you can follow these steps. This guide will also help you understand what a reserved range is and how it is used, especially in the context of OpenStack.
  1. Log in to the MAAS Web UI: Open your web browser and navigate to your MAAS server. Log in with your MAAS credentials.
  2. Navigate to the subnets page:
    Click on the “Subnets” tab in the top navigation bar. This will show you a list of all subnets that MAAS is managing.
  3. Select the subnet:
    Find the subnet where you want to create the reserved range and click on it. This will open the subnet details page.
  4. Go to reserved ranges:
    In the subnet details page, look for the “Reserved Ranges” section. This is usually located below the list of IP addresses.
  5. Add a reserved range:
    Click on the “Add Reserved Range” button. This will open a form to define the new reserved range.
  6. Define the range:
    • Start IP: Enter the starting IP address of the range you want to reserve.
    • End IP: Enter the ending IP address of the range you want to reserve.
    • Purpose: Optionally, you can add a description or purpose for this reserved range to help identify its use.
    • Save the range:
    After filling in the details, click on the “Save” button to create the reserved range.
  7. Verify the reserved range:
    Once saved, you should see the new reserved range listed in the “Reserved Ranges” section. This range will now be excluded from automatic IP allocation by MAAS.
How to create a dynamic IP range in MAAS (CLI)
How to edit an existing IP range (UI)
How to edit an existing IP range (CLI)
To edit an IP range, first find the ID of the desired IP range with the command:
maas admin ipranges read
Examine the JSON output to find the ID corresponding to the IP range you want to edit, then enter:
maas admin iprange update $ID start_ip="<start ip>" end_ip="<end ip>" comment="freeform comment"
This command will update the IP range associated with $ID.
How to delete an existing IP range (UI only)
