Is there a default set of credentials or a place I can find the credentials to perform a local login to begin troubleshooting on the deployed machine?
Is the only way to ensure this through a cloud-init script to create a user?
Recently I have been having some trouble deploying Ubuntu 22.04 to a couple of new servers. I have “local” access to the machines so I was hoping there was a way to log in and check the logs. I see when deploying there is an error with the hardware sync service. Other than that the system just fails due to time out but ubuntu is installed based on everything else I can see.
I have tried my Maas user creds, I have tried a ‘ubuntu’ user.
Thanks for the quick answer, seems like cloud-init would be the fastest method to implement. I will try using a snippet based on the example in the docs,
