Annotations in MAAS are potent tools for adding context and metadata to your machines. They act as supplementary data that allow you to identify, filter, and manage your machines more effectively. Essentially, annotations fall into two categories:
- Notes: These are always available, regardless of the machine’s state.
- Dynamic Annotations: These only exist when a machine is in an allocated or deployed state.
This page explains how to use notes and dynamic annotations.
Dynamic annotations aren’t supported in MAAS version 2.9 or earlier.
Notes
Notes are persistent descriptions that stay with a machine throughout its life-cycle unless manually altered. You can manage notes through both the MAAS UI and CLI.
Notes via UI
To add or modify notes via the MAAS UI:
Navigate to Machines > Machine name > Configuration > Edit.
Your existing notes appear in the Note section.
Add new or modify existing notes in the Note section.
Delete irrelevant notes from the same block.
Make sure to Save changes to confirm your actions.
Notes via CLI
Notes using the MAAS CLI are handled a little differently from the UI.
Identifying your machines
To determine machine identifiers, run the following command:
maas $PROFILE machines read \
|@tsv' | column -t
Managing notes in CLI
You can add or modify a note as follows:
maas $PROFILE machine update $SYSTEM_ID description="$NOTE"
To erase a note, just use an empty string:
maas $PROFILE machine update $SYSTEM_ID description=""
Dynamic annotations
Dynamic annotations are ephemeral data, tied to the operational states of allocated or deployed machines. These annotations are especially handy for tracking the live status of your workloads.
Identifying eligible machines for dynamic annotations
To list machines that can receive dynamic annotations, execute:
|@tsv' | column -t
Setting dynamic annotations
You can define dynamic annotations using key=value pairs. To set one, use:
Managing dynamic annotations
To change or remove a dynamic annotation, use the following commands:
- For changing:
- For removing:
Listing dynamic annotations
To view all current dynamic annotations, run:
|@tsv' | column -t
Summary
Annotations in MAAS offer an additional layer of intelligence to your machine management. While notes provide a stable form of annotations, dynamic annotations offer a more fluid form of tracking, directly linked to your machine’s operational status.
