How MAAS works
The above comment about disk space bears repeating: MAAS will overwrite the disk space of all machines it enlists. All pool machines are under the control of MAAS; you should provision them using other methods.
MAAS users allocate machines for use when needed. The web UI also allows you to allocate machines manually, such as when you are reserving specific hardware for certain users. You can remotely access and customise the installed operating system via SSH.
When allocating machines from the API/CLI, you can specify requirements (“constraints”). Common constraints are memory, CPU cores, connected networks, and assigned physical zone.
An allocated MAAS machine is more flexible than a virtual instance in a cloud. You have complete control, including hardware drivers and root access. If you want to upgrade the BIOS, for example, you can allocate a machine to yourself and complete the upgrade. Once you have completed the upgrade, you can send the machine back to the pool.
Note that Juju↗ is designed to work with MAAS. MAAS becomes a back-end Juju resource pool with all functionality fully available. For instance, if Juju removes a machine, then MAAS will release that machine to the pool. With Juju, MAAS can become an integral part of your data centre strategy and operations.
