Machines
This article will help you sort out the theoretical aspects of MAAS machines.
About the machine life-cycle
One of the most important things to understand about machines is their life-cycle. In this subsection, you will learn:
Introduction to the machine life-cycle
Everything that happens to a machine under MAAS control conforms to a specific life-cycle. All MAAS machines are in a named state, or in transition between states. Most of these transitions are user-controlled. Only the “failure” state is reached under the direction of MAAS, when a user’s request for certain state changes can’t be successfully completed.
In general, the various states and transitions can be summarised in a diagram:
The central state flow at the bottom of the diagram is the “standard” life-cycle. If all goes well, you won’t have to deviate much from this flow:
  • Machines start as servers in your environment, attached to a network or subnet that MAAS can reach and manage. If those machines are configured to netboot, MAAS can discover them and enlist them, assigning a status of “NEW”. By definition, NEW machines are: (2) enabled to network boot, and (2) on a subnet accessible to MAAS.
  • Once you’ve pared the list to machines that you want MAAS to control, you can choose to commission them. You can select any machine that is marked “NEW” and tell MAAS to commission it, or, if you add machine manually, MAAS will automatically commission it. Commissioning PXE boots the machine and loads an ephemeral version of the Ubuntu operating system into the machine’s RAM. MAAS then uses that OS to scan the machine to determine its hardware configuration: CPUs, RAM, storage layouts, PCI and USB devices, and so forth. Commissioning can be customised – more on that in a later section. If a machine fails to properly commission, either because of a commissioning error, or because the commissioning process timed out, that machine enters a “FAILED” state.
  • MAAS next tests the machine to make sure it’s working properly. These basic tests just assure that the discovered hardware works as expected. Testing can also be customised, if you wish. Machines that don’t pass these tests are moved to a “FAILED” state.
  • Having tested it, MAAS then places that machine in the “READY” state, meaning that MAAS should be able to deploy it, based on the gathered hardware information.
  • Before you deploy a machine, you should allocate it. This step essentially involves taking ownership of the machine, so that no other users can deploy it.
  • Having allocated a machine, you can deploy it. When deploying, MAAS again loads an ephemeral Ubuntu OS onto the machine, uses curtin to configure the hardware in the way you’ve specified, and then loads and boots the OS image you’ve requested. Deployment also runs some cloud-init steps to finish machine configuration, before leaving it up and ready for use.
Once deployed, there are a couple of minor state changes you can effect without releasing the machine:
  • You can lock a machine, if desired, to provide a little extra insurance that it won’t accidentally be changed by you – or anyone.
  • Depending upon the machine’s duty cycle, you can also power it on, power it off, or even power-cycle it (to effect a reboot, for example).
Note that these minor state changes are not shown in the diagram above. There are also some exceptional states you can command:
  • For any machine that is ready, allocated, or deployed, you can cycle it through a battery of tests at any time. Be aware, of course, that testing causes the machine to be unavailable for normal use for the duration of the text cycle.
  • Machines that are ready, allocated, or deployed can also be placed in “rescue mode”. Essentially, rescue mode is the same as walking to a malfunctioning or mis-configured machine, taking it off the network, and fixing whatever may be wrong with it – except that you’re doing so via SSH, or by running tests from MAAS, rather than standing in front of the machine. Machines in rescue mode can’t enter normal life cycle states until you remove them from rescue mode. You can, of course, delete them, modify their parameters (tags, zone, and so on), power them off, and mark them broken. Rescue mode is like a remote repair state that you can control from wherever you are.
  • Machines that are allocated or deployed can also be marked broken. A broken machine powers off by default. You can still power it on, delete it, or enter rescue mode, but you can’t log into it via SSH. This state is intended for machines that experience catastrophic hardware or software failures and need direct repairs.
There is one more state that a machine can get into: “failed”. This state is entered when commissioning, allocation, or deployment are not successful. Getting out of a failed state means figuring out what went wrong, correcting it, and retrying the failed operation. For example, when a machine fails, you can try and commission it again, hopefully after you’ve found the bug in your custom commissioning script that’s causing it to fail (for instance).
Now that we have a solid overview of the life-cycle, let’s break down some of these states and transitions in greater detail.
About enlistment
When you configure a machine to netboot – and turn it on while connected to the network – MAAS will enlist it, giving it a status of “New.” You can also add a machine manually. In either case, the next step is commissioning, which boots the machine into an ephemeral Ubuntu kernel so that resource information can be gathered. You can also run custom commissioning scripts to meet your specific needs.
About the enlistment process
Typically, the next step will be to commission the machine. As an alternative to enlistment, an administrator can add a machine manually. Typically this is done when enlistment doesn’t work for some reason. Note that when you manually add a machine, MAAS automatically commissions the machine as soon as you’ve added it.
After the commissioning process, MAAS places the machine in the ‘Ready’ state. ‘Ready’ is a holding state for machines that are commissioned, waiting to be deployed when needed.
About BMC enlistment
For IPMI machines, you only need to provide IPMI credentials. MAAS automatically discovers the machine and runs enlistment configuration by matching the BMC address. For non-IPMI machines, you must specify a non-PXE MAC address. MAAS automatically discovers the machine and runs enlistment configuration by matching the non-PXE MAC address.
About adding machines
  2. If you add a machine manually, MAAS will automatically commission it. There are also ways to turn off this automatic commissioning, should you desire to do so.
Configuring a computer to boot over PXE is done via its BIOS, often referred to as “netboot” or “network boot”. Normally, when you add a machine manually, MAAS will immediately attempt to commission the machine. Note that you will need to configure the underlying machine to netboot, or commissioning will fail. MAAS cannot handle this configuration for you. While the correct method for configuring network boot depends heavily on your server, there are two common elements:
  1. The network card on your server must be able to support PXE, i.e., your NIC – whether independent or integrated on a motherboard – must have a boot PROM that supports network booting. You’ll need to consult the documentation for the machine in question to determine this. Note that in MAAS versions before 2.5, you are required to provide the MAC address of the PXE interface when adding a new machine manually.
Regardless of how MAAS adds a machine, there are no special requirements for the underlying machine itself, other than being able to netboot. In particular, there is no need to install an operating system on it.
About cloning machines
MAAS 3.1 provides the ability to quickly clone or copy configuration from one machine to one or more machines, via the MAAS UI, providing convenient access to an existing API feature… This is a step towards machine profile templating work.
Creating a machine profile is a repetitive task. Based on the responses to our survey – and multiple forum posts, we have learned that most users create multiple machines of the same configuration in batches. Some users create a machine profile template and loop them through the API, while some create a script to interface with the CLI. However, there is no easy way to do this in the UI except by going through each machine and configuring them individually.
MAAS API already has the cloning functionality, but it was never exposed in the UI. Hence, users may not know that this API feature exists, nor is there any current documentation about how to use this feature. Although the current cloning API feature does not solve all machine profile templating problems, it is a great place for us to start moving in the direction of machine templates.
About copying machine configurations
As a MAAS user – API or UI – you may want to copy the configuration of a given machine and apply it to multiple existing machines. Assuming that at least one machine is already set to the desired configuration, you should be able to apply these same settings to a list of destination machines. This means that a user should be able to:
  • select the source machine to copy from.
  • validate that the source machine exists.
  • select at least 1 destination machine.
  • validate that the destination machine(s) exist.
  • edit the source machine or destination machines, if needed.
  • know at all times which machines are affected.
  • see the cloned machines when cloning is successful, or
  • get clear failure information, if cloning fails.
About choosing configuration items to copy
As a MAAS user, you will likely want to select whether storage, network, or both configurations should be cloned. The cloning API allows users to choose interfaces and storage separately. Thus, this new feature should allow the user to:
  • clone only the interface (network) configuration.
  • clone only the storage configuration.
  • clone both configurations.
About cloning restrictions
In order for cloning to succeed, a few restrictions must be met:
  • The destination interface names must be the same source.
  • The destination drive must be equal to or larger than the source drive.
  • For static IPs, a new IP will be allocated to the interface on the destination machine
Cloning machines is available starting with MAAS version 3.1.
About enlisting deployed machines
In general, when adding a machine to MAAS, it network boots the machine into an ephemeral environment to collect hardware information about the machine. While this is not a destructive action, it doesn’t work if you have machines that are already running a workload.
For one, you might not be able to disrupt the workload in order to network boot it. But also, the machine would be marked as Ready, which is incorrect.
When adding a machine, you may specify that the machine is already deployed. In that case, it won’t be going through the normal commissioning process and will be marked as being deployed.
Such machines lack hardware information. In order to update the information, a script is provided to run a subset of the commissioning scripts and send them back to MAAS.
Because already-deployed machines were not deployed by MAAS, most of the standard MAAS commands will not affect the machine and may, at times, return some odd results. This is not errant behaviour; the goal of enlisting deployed machines is to avoid disturbing their workload.
MAAS version 3.0 cannot enlist deployed machines. Please upgrade to MAAS version 3.1 or greater to gain this capability.
MAAS version 2.9 cannot enlist deployed machines. Please upgrade to MAAS version 3.1 or greater to gain this capability.
About commissioning machines
  1. DHCP server is contacted
  3. machine boots
  5. cloud-init runs built-in and custom commissioning scripts
  6. machine shuts down
Commissioning requires 60 seconds.
About commissioning NUMA and SR-IOV nodes
When using these nodes, you can specify a node index for interfaces and physical block devices. MAAS will display the NUMA node index and details, depending upon your configuration, to include the count of NUMA nodes, number of CPU cores, memory, NICs, and node spaces for bonds and block devices. You can also filter machines by CPU cores, memory, subnet, VLAN, fabric, space, storage, and RAID, among others.
About MAAS commissioning scripts
Scripts can be selected to run from web UI during commissioning, by testing hardware, or from the command line. Note that MAAS only runs built-in commissioning scripts during enlistment. Custom scripts can be run when you explicitly choose to commission a machine. A typical administrator workflow (with machine states), using customised commissioning scripts, can be represented as:
  • maas-support-info: MAAS gathers information that helps to identify and characterise the machine for debugging purposes, such as the kernel, versioning of various components, etc. Runs in parallel with other scripts.
  • maas-lshw: this script pulls system BIOS and vendor info, and generates user-defined tags for later use. Runs in parallel with other scripts.
  • 20-maas-01-install-lldpd: this script installs the link layer discovery protocol (LLDP) daemon, which will later capture networking information about the machine. This script provides some extensive logging.
  • maas-list-modaliases: this script figures out what hardware modules are loaded, providing a way to autorun certain scripts based on which modules are loaded. Runs in parallel with other scripts.
  • 20-maas-02-dhcp-unconfigured-ifaces: MAAS will want to know all the ways the machine is connected to the network. Only PXE comes online during boot; this script brings all the other networks online so they can be recognised. This script provides extensive logging.
  • maas-get-fruid-api-data: this script gathers information for the Facebook wedge power type. Runs in parallel with other scripts.
  • maas-serial-ports: this script lists what serial ports are available on the machine. Runs in parallel with other scripts.
As of MAAS version 3.0, 40-maas-01-network-interfaces is no longer used by MAAS.
  • 40-maas-01-network-interfaces: this script is just used to get the IP address, which can then be associated with a VLAN/subnet.
  • 50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, details about attached USB and PCI devices, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
  • 50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need. This script also checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
  • maas-capture-lldp: this script gathers LLDP network information to be presented on the logs page; this data is not used by MAAS at all. Runs in parallel with other scripts.
  • maas-kernel-cmdline: this script is used to update the boot devices; it double-checks that the right boot interface is selected.
Commissioning runs the same dozen or so scripts as enlistment, gathering all the same information, but with these caveats:
  • Commissioning also runs user-supplied commissioning scripts, if present. Be aware that these scripts run as root, so they can execute any system command.
  • Commissioning runs test scripts which are not run during enlistment.
  • Commissioning scripts can send BMC configuration data, and can be used to configure BMC data.
  • The environment variable BMC_CONFIG_PATH is passed to serially run commissioning scripts; these scripts may write BMC power credentials to BMC_CONFIG_PATH in YAML format, where each key is a power parameter. The first script to write BMC_CONFIG_PATH is the only script allowed to configure the BMC, allowing you to override MAAS’ built-in BMC detection. If the script returns 0, that value will be send to MAAS.
  • All built-in commissioning scripts have been migrated into the database.
  • maas-run-remote-scripts is capable of enlisting machines, so enlistment user-data scripts have been removed.
  • The metadata endpoints http://<MAAS>:5240/<latest or 2012-03-01>/ and http://<MAAS>:5240/<latest or 2012-03-01>/meta-data/ are now available anonymously for use during enlistment.
  • enable_ssh: Optional integer. Controls whether to enable SSH for the commissioning environment using the user’s SSH key(s). ‘1’ == True, ‘0’ == False. Roughly equivalent to the Allow SSH access and prevent machine powering off in the web UI.
  • skip_bmc_config: Optional integer. Controls whether to skip re-configuration of the BMC for IPMI based machines. ‘1’ == True, ‘0’ == False.
  • skip_networking: Optional integer. Controls whether to skip re-configuring the networking on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain network configuration in the web UI.
  • skip_storage: Optional integer. Controls whether to skip re-configuring the storage on the machine after the commissioning has completed. ‘1’ == True, ‘0’ == False. Roughly equivalent to Retain storage configuration in the web UI.
  • commissioning_scripts: Optional string. A comma separated list of commissioning script names and tags to be run. By default all custom commissioning scripts are run. Built-in commissioning scripts always run. Selecting update_firmware or configure_hba will run firmware updates or configure HBA’s on matching machines.
  • testing_scripts: Optional string. A comma separated list of testing script names and tags to be run. By default all tests tagged commissioning will be run. Set to none to disable running tests.
  • parameters: Optional string. Scripts selected to run may define their own parameters. These parameters may be passed using the parameter name. Optionally a parameter may have the script name prepended to have that parameter only apply to that specific script.
About machine commissioning logs
MAAS keeps extensive logs of the commissioning process for each machine. These logs present an extremely detailed, timestamped record of completion and status items from the commissioning process.
About disabling individual boot methods
It is possible to disable individual boot methods. This must be done via the CLI. When a boot method is disabled MAAS will configure MAAS controlled isc-dhcpd to not respond to the associated boot architecture code. External DHCP servers must be configured manually.
To allow different boot methods to be in different states on separate physical networks using the same VLAN ID configuration is done on the subnet in the UI or API. When using the API boot methods to be disabled may be specified using the MAAS internal name or boot architecture code in octet or hex form.
For MAAS 3.0 and above, the following boot method changes have been implemented:
  • UEFI AMD64 HTTP(00:10) has been re-enabled.
  • UEFI ARM64 HTTP(00:13) has been enabled.
  • UEFI ARM64 TFTP(00:0B) and UEFI ARM64 HTTP(00:13) will now provide a shim and GRUB signed with the Microsoft boot loader keys.
  • grub.cfg for all UEFI platforms has been updated to replace the deprecated linuxefi and initrdefi commands with the standard linux and initrd commands.
  • GRUB debug may now be enabled by enabling rackd debug logging.
Disabling boot methods is available in MAAS version 3.0 or greater.
About automatic script selection by hardware type
When selecting multiple machines, scripts which declare the for_hardware field will only run on machines with matching hardware. To automatically run a script when ‘Update firmware’ or ‘Configure HBA’ is selected, you must tag the script with ‘update_firmware’ or ‘configure_hba’.
About script results
The YAML file must represent a dictionary with these two fields:
  1. result: The completion status of the script. This status can be passed, failed, degraded, or skipped. If no status is defined, an exit code of 0 indicates a pass while a non-zero value indicates a failure.
  2. results: A dictionary of results. The key may map to a results key defined as embedded YAML within the script. The value of each result must be a string or a list of strings.
Optionally, a script may define what results to return in the YAML file in the metadata fields… The results field should contain a dictionary of dictionaries. The key for each dictionary is a name which is returned by the results YAML. Each dictionary may contain the following two fields:
  1. title - The title for the result, used in the UI.
  2. description - The description of the field used as a tool-tip in the UI.
Here is an example of “degrade detection”:
#!/usr/bin/env python3
# name: example
# results:
#   memspeed:
#     title: Memory Speed
#     description: Bandwidth speed of memory while performing random read writes
import os
import yaml
memspeed = some_test()
results = {
   'results': {
       'memspeed': memspeed,
if memspeed < 100:
if result_path is not None:
About tags and scripts
About debugging script failures
You can individually access the output from both completed and failed scripts.
About testing hardware
About machine hardware & test logs
MAAS logs test results and allows you to view a summary of tests run against a particular machine. You can also example details on any particular tests:
You can also examine the “raw” log output:
About testing machine networking
About post-commission configuration
Once commissioned, you can configure the machine’s network interface(s). Specifically, when a machine’s status is either “Ready” or “Broken”, interfaces can be added/removed, attached to a fabric and linked to a subnet, and provided an IP assignment mode. Tags can also be assigned to specific network interfaces.
About allocation and deployment
Once a machine has been commissioned, the next logical step is to deploy it. Deploying a machine means, effectively, to install an operating system on it, along with any other application loads you wish to run on that machine.
A detailed picture of deployment looks something like this:
Before deploying a machine, MAAS must allocate it (status ‘Allocated’). Allocating a machine reserves the machine for the exclusive use of the allocation process. The machine is no longer available to any other process, including another MAAS instance, or a process such as Juju.
MAAS also supports machine customisation with a process called “preseeding.” For more information about customising machines, see How to customise machines.
To deploy, you must configure the underlying machine to netboot. Such a machine will undergo the following process, outlined in the above diagram:
  1. MAAS boots the machine via the machine’s BMC, using whatever power driver is necessary to properly communicate with the machine.
  2. The booted machine sends a DHCP Discover request.
  3. The MAAS-managed DHCP server (ideally) responds with an IP address and the location of a MAAS-managed HTTP or TFTP boot server.
  4. The machine uses the HTTP/TFTP location to request a usable Network Boot Program (NBP).
  5. The machine recieves the NBP and boots.
  6. The machine firmware requests a bootable image.
  7. MAAS sends an ephemeral OS image, including an initrd; this ephemeral (RAM-only) image is necessary for curtin to carry out any hardware-prep instructions (such as disk paritioning) before the deployed OS is booted.
  8. The initrd mounts a SquashFS image, also ephemerally, over HTTP.
  9. The machine boots the emphemeral image.
  10. The ephemeral image runs curtin, with passed pre-seed information, to configure the machine’s hardware.
  11. The desired deployment (target) image is retrieved by curtin, which installs and boots that deployment image. Note that the curtin installer uses an image-based method and is now the only installer used by MAAS. Although the older debian-installer method has been removed, curtin continues to support preseed files. For more information about customising machines see How to customise machines.
  12. The target image runs its embedded cloud-init script set, including any customisations and pre-seeds.
Once this is done, the target image is up and running on the machine, and the machine can be considered successfully deployed.
Also note that, before deploying, you should take two key actions:
  1. Review and possibly set the Ubuntu kernels and the Kernel boot options that will get used by deployed machines.
  2. Ensure any pertinent SSH keys are imported (see SSH keys) to MAAS so it can connect to deployed machines.
About the machine list
The machine list is the basic dashboard for many MAAS operations. In this subsection, you will learn:
In the illustration below, you see the machine list for a typical small hospital data centre, including servers ready and allocated for functions like Pharmacy, Orders, Charts, and so on:
Rolling the cursor over status icons often reveals more details. For example, a failed hardware test script will place a warning icon alongside the hardware type tested by the script. Rolling the cursor over this will reveal which test failed. Likewise, you can find some immediate options by rolling over the column data items in the machines table.
The ‘Add hardware’ drop-down menu is used to add either new machines or a new chassis. This menu changes context when one or more machines are selected from the table, using either the individual checkboxes in the first column or the column title checkbox to select all.
With one or more machines selected, the ‘Add hardware’ drop-down menu moves to the left, and is joined by the ‘Take action’ menu. This menu provides access to the various machine actions that can be applied to the selected machine(s):
The ‘Filter by’ section limits the machines listed in the table to selected keywords and machine attributes.
FQDN               POWER  STATUS     OWNER  TAGS     POOL       NOTE     ZONE
52-54-00-15-36-f2  off    Ready      -      Orders   Prescrbr   @md-all  Medications
52-54-00-17-64-c8  off    Ready      -      HRMgmt   StaffComp  @tmclck  Payroll
52-54-00-1d-47-95  off    Ready      -      MedSupp  SuppServ   @storag  Inventory
52-54-00-1e-06-41  off    Ready      -      PatPrtl  BusOfc     @bzstns  BizOffice
52-54-00-1e-a5-7e  off    Ready      -      Pharm    Prescrbr   @rxonly  Pharmacy
52-54-00-2e-b7-1e  off    Allocated  admin  NursOrd  NurServ    @nstns   Nursing
52-54-00-2e-c4-40  off    Allocated  admin  MedAdmn  NurServ    @rxonly  Nursing
52-54-00-2e-ee-17  off    Deployed   admin  Charts   ProServ    @md-all  Physician
These example machines would typically be duplicated in several different geographies, with a quick way to switch to a redundant node, should anything go wrong (e.g., high availability). We used the word node there because, In the network language of MAAS, machines are one of several different types of nodes. A node is simply a network-connected object or, more specifically, an object that can independently communicate on a network. MAAS nodes include controllers, network devices, and of course, machines.
Looking back at the example above, you can see that there are several columns in the machine list, depending on your view:
  • FQDN | MAC: The fully qualified domain name or the MAC address of the machine.
  • Power: ‘On’, ‘Off’ or ‘Error’ to highlight an error state.
  • Status: The current status of the machine, such as ‘Ready’, ‘Commissioning’ or ‘Failed testing’.
  • Owner: The MAAS account responsible for the machine.
  • Cores: The number of CPU cores detected on the machine.
  • RAM: The amount of RAM, in GiB, discovered on the machine.
  • Disks: The number of drives detected on the machine.
  • Storage: The amount of storage, in GB, identified on the machine.
About the machine summary
Click a machine’s FQDN or MAC address to open a detailed view of a machine’s status and configuration.
The default view is ‘Machine summary’, presented as a series of cards detailing the CPU, memory, storage and tag characteristics of the machine, as well as an overview of its current status. When relevant, ‘Edit’ links take you directly to the settings pane for the configuration referenced within the card. The machine menu bar within the web UI also includes links to logs, events, and configuration options:
The machine status card presents an overview of CPU, memory, storage, tags, and general settings:
The first card presents some basics of the machine resources and configuration:
Here are some details on what this card presents, with details on in-card links described in following sections:
  • OVERVIEW the machine status (in this case “Deployed”), and lists OS version information.
  • CPU shows the specifics of the CPU(s), including a link to test the processor(s).
  • MEMORY gives the total available RAM for this machine, along with a test link.
  • STORAGE presents the total amount of storage available and the number of disks that provide that storage. There are two links here: one gives the storage layout (with the opportunity to change it for devices that are in ‘Ready’ or ‘Allocated’ states.
  • Owner identifies the owner of the machine.
  • Domain indicates the domain in which the machine exists.
  • Zone shows the AZ in which this machine resides, along with a link to edit the machine configuration (to change the AZ, if desired).
  • Resource pool shows the pool to which this machine has been assigned, and an edit link.
  • Power type gives the current power type, which links to the relevant edit form.
  • Tags presents the list of tags associated with this machine, editable via the link.
Note that clicking any of the links in this card will either present a pop-up form or take you to another item in the machine menu – so using the browser “back” button will take you completely away from this machine’s page. For example, you can choose the “Test CPU” option, which brings up this overlay:
From this screen, you can choose test scripts and run the tests (in the background) as the interface returns to the Machine summary. A linked note in the CPU block lets you know that the tests are in progress:
And you can watch the results under the “Tests” option in the Machine menu:
The rest of the cards on the Machine summary are either self-explanatory, or they’re covered in the sections below. The main point is this: You can see that nearly everything about machines takes place within the main menu’s “Machines” option.
Handling attached USB and PCI devices
The machines in your MAAS may have devices attached to them via USB or PCI interface, such as keyboards, cameras, network cards, GPUs, etc. MAAS will recognise these devices and make them visible to you when a machine is commissioned.
For example, the machine details presents USB and PCI devices like this:
Note that this page now includes two new tabs: “PCI devices” and “USB.” For each USB/PCI device attached to your machine, these tabs will list:
  • device type
  • vendor ID
  • a product description
  • a product ID
  • the driver name
  • the containing NUMA node (if any)
  • the device address
A typical PCI device tab would look something like this:
The USB tab presents similar information in the same format.
If you are upgrading from a previous version of MAAS, PCI and USB devices aren’t modelled, so you will have to recommission the machine to capture these devices.
Once you’ve commissioned the machine, you have the option of deleting
PCI/USB devices from the machine in any machine state, via the CLI
only, using the following command:
maas $PROFILE node-device delete $SYSTEM_ID $DEVICE_ID
where:
  • $PROFILE = your user profile (e.g., “admin”)
  • $SYSTEM_ID = the ID of the machine in question (e.g., “ngx7ry”)
  • $DEVICE_ID = the ID of the device you want to delete
If the device is still present in the system, it will be recognised again (and thus “recreated”)
when the machine is commissioned again.
About machine network info
The Network “tab” provides you with a way to view/edit the network and interface configuration for a machine:
In the case of this deployed machine, there are not many editing options. If the machine is in a ‘Ready’ state, though, altering the network configuration is possible, as shown in the screenshot above.
About machine configuration info
There are two sections to this tab. The “Machine configuration” section, shown above, offers some general parameters, mostly related to how this machine is grouped and categorised. More information on these options are found in the relevant sections of the documentation (e.g., tags, resource pools, and so forth).
The “Power configuration” supplies the parameters necessary for MAAS to access the machine to PXE-boot it:
USB and PCI devices are supported in MAAS version 3.0 and greater.
About resource pools
About tags
  • VM hosts
  • network interfaces
  • devices
  • nodes (in the CLI only)
About annotations
About storage
MAAS doesn’t currently support deploying with ZFS for devices other than the root one. For this reason, ZFS is disrecommended.
Customising machines
Prior to deployment, MAAS machines can be customised in a number of ways, including:
  • machine storage.
  • commissioning and deployment configurations (known as “pre-seeding”).
  • custom Ubuntu kernels.
  • kernel boot options.
  • resource pools.
Machines can also be customised post-deployment, while running, either by changing out the physical hardware, or by altering the VM from the VM host side. This will allow you to:
  • add or remove disks
  • add or remove network interfaces
  • add or remove PCI devices
  • add or remove USB devices
You cannot update these parameters from within MAAS on a deployed machine.
While deploying a machine, you can configure that machine to periodically sync its hardware configuration. Deployed machines will passively update changes to the BMC and tags for that machine, on-the-fly, as these changes are made.
In short, this article will explain these possible customisations, and provide detailed instructions on how to customise your own machines as desired.
This article will help you learn about customising machines
About customising machines prior to deployment
In this section, you’ll learn:
About customising machine storage
About UEFI booting
UEFI must be enabled or disabled for the lifespan of the machine. For example, do not enlist a machine with UEFI enabled, and then disable it before commissioning. It won’t work!
About block devices
Physical
Virtual
About partitions
About storage restrictions
About VMFS datastores
About disk erasure
About disk erasure types
  1. Standard erasure - Overwrites all data with zeros.
  2. Secure erasure - Although effectively equivalent to Standard erase, Secure erase is much faster because the disk’s firmware performs the operation. Because of this, however, some disks may not be able to perform this erasure type (SCSI, SAS, and FC disks in particular).
  3. Quick erasure - Same as Standard erase but only targets the first 1 MB and the last 1 MB of each disk. This removes the partition tables and/or superblock from the disk, making data recovery difficult but not impossible.
If all three options are checked when the machine is released, the following order of preference is applied:
  2. If it does not, then use ‘quick erase’
It is very important to pay close attention to your selections when erasing disks.
About pre-seeding
During machine enlistment, deployment, commissioning and machine installation, MAAS sends Tempita-derived configuration files to the cloud-init process running on the target machine. MAAS refers to this process as preseeding. These preseed files are used to configure a machine’s ephemeral and installation environments and can be modified or augmented to a custom machine configuration.
Preseeding in MAAS can be achieved in two ways:
  1. Curtin, a preseeding system similar to Kickstart or d-i (Debian Installer), applies customisation during operating system (OS) image installation. MAAS performs these changes on deployment, during OS installation, but before the machine reboots into the installed OS. Curtin customisations are perfect for administrators who want their deployments to have identical setups all the time, every time. This blog post contains an excellent high-level overview of custom MAAS installs using Curtin.
  2. Cloud-init, a system for setting up machines immediately after instantiation. cloud-init applies customisations after the first boot, when MAAS changes a machine’s status to ‘Deployed.’ Customisations are per-instance, meaning that user-supplied scripts must be re-specified on redeployment. Cloud-init customisations are the best way for MAAS users to customise their deployments, similar to how the various cloud services prepare VMs when launching instances.
About templates
The Tempita template files are found in the /var/snap/maas/current/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
The Tempita template files are found in the /etc/maas/preseeds/ directory on the region controller. Each template uses a filename prefix that corresponds to a particular phase of MAAS machine deployment:
Phase Filename prefix
Enlistment enlist
Commissioning commissioning
Installation curtin (Curtin)
The enlist template, for example, contains only minimal variables, whereas enlist_userdata includes both user variables and initialisation logic.
Tempita’s inheritance mechanism is the reverse of what you might expect. Inherited files, such as enlist_userdata, become the new template which can then reference variables from the higher-level file, such as enlist.
About template naming
Some earlier versions of MAAS only support Ubuntu. If the machine operating system is Ubuntu, then filenames without {os} will also be tried, to maintain backward compatibility.
  1. {prefix}_{os}_{node_arch}_{node_subarch}_{release}_{node_name} or {prefix}_{node_arch}_{node_subarch}_{release}_{node_name}
  2. {prefix}_{os}_{node_arch}_{node_subarch}_{release} or {prefix}_{node_arch}_{node_subarch}_{release}
  3. {prefix}_{os}_{node_arch}_{node_subarch} or {prefix}_{node_arch}_{node_subarch}
  4. {prefix}_{os}_{node_arch} or {prefix}_{node_arch}
  5. {prefix}_{os}
  6. {prefix}
  7. generic
The prefix can be either enlist, enlist_userdata, commissioning, curtin, curtin_userdata or preseed_master. Alternatively, you can omit the prefix and the following underscore.
For example, to create a generic configuration template for Ubuntu 16.04 Xenial running on an x64 architecture, the file would need to be called ubuntu_amd64_generic_xenial_node.
To create the equivalent template for curtin_userdata, the file would be called curtin_userdata_ubuntu_amd64_generic_xenial_node.
About Ubuntu kernels
  • General availability kernels
  • Hardware enablement kernels
  • Hardware enablement kernels (pre-release)
  • Low latency kernels
About low latency kernels
About choosing a kernel
About kernel boot options
MAAS can specify kernel boot options to machines on both a global basis (UI and CLI) and a per-machine basis (CLI-only). A full catalogue of available options can be found in the Linux kernel parameters list at kernel.org.
Administrators can manage resource pools on the Machines page in the web UI, under the Resource pools tab, or with the MAAS CLI. Also note that all MAAS installations have a resource pool named “default.” MAAS automatically adds new machines to the default resource pool.
About customising deployed machines
MAAS 3.2 provides the capability to customise deployed machines, in that you can update hardware for a running machine on-the-fly. Specifically, MAAS will update a deployed machine’s data when you do any of the following things:
You can find the procedure here.
While deploying a machine, you can configure that machine to periodically sync its hardware configuration. Deployed machines will also passively update changes to the BMC and tags for that machine, as these changes are made.
About updating hardware
Updating hardware on a deployed machine works by installing a special binary on the deployed machine. This binary is configured at a given interval and push hardware info to the MAAS metadata endpoint. By setting “enable_hw_sync” to true on a machine prior to deployment, MAAS will add configuration to install a systemd service and timer that will download the hardware sync binary. This binary then authenticates the machine, reads the hardware info from the machine and pushes it to MAAS. The interval is set globally in the MAAS settings.
Any changes in hardware are written to the machine’s configuration. Physical hardware changes will be preserved upon release, while virtual changes, such as a SR-IOV interface, will be dropped.
When deploying a machine from the UI, there is a new “enable_hw_sync” flag available for each machine. This flag marks a machine to be configured with live hardware updates.
When deploying from the CLI, there is an additional enable_hw_sync flag on maas $PROFILE machine deploy. This flag also marks a machine to be configured with live hardware updates.
When using the API, there are two additional fields in the request:
  • enable_hw_sync: (Boolean) - indicating whether hardware sync should be enabled on the machine,
  • sync_interval: (Int) - indicating the interval, in seconds, that should be set at time of deployment
With respect to machine.read, both the RESTful API and Websocket API add the following fields to a response:
  • enable_hw_sync: Bool indicating whether hardware sync is enabled on the machine,
  • last_sync: Timestamp of the last time MAAS received hardware sync data for the machine,
  • next_sync: Timestamp of the computed estimation of when the next sync should happen,
  • sync_interval: Int the interval, in seconds, that was set at time of deployment
  • is_sync_healthy: Bool indicating the sync is working normally when true, false when a sync is late or missing,
With respect to config.list, there is a new WebSocket Response result (new “hardware_sync_interval” option):
   value: String in systemd time span format  e.g. “15m”
	        (only hours, minutes and seconds are recognised)
 -  hardware_sync_interval is set to `15m` by default
config.update
WebSocket Request params - new “hardware_sync_interval” param
params: {
  value: String in systemd time span format, e.g. “15m”
The API does not throw errors when an invalid string is provided for these parameters.
About hardware sync
Hardware sync updates the machine’s blockdevice, interface and device sets. BMC configuration and tags can also be updated on the machine itself. The timestamps of the last sync and the next scheduled sync can be seen in the machine’s data.
The capability to customise deployed machines is available starting with MAAS version 3.2.
