Hardware testing (snap/2.8/CLI)
Three questions you may have:
  1. How do I upload hardware test scripts?
  2. How do I use tags to help with hardware test scripts?
  3. How do I view test results?
Uploading hardware test scripts
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
Tags
Results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
