Guys,
I was running MaaS just fine and “out of blue”, I’m facing the BUG LP:1683047.
Thing is that it wasn’t my intention to overlap anything!
But, somehow, MaaS duplicated entries on bind9 and it fails to start.
Errors:
maas.log:
2019-01-15T11:20:58.138832-05:00 wc maas.dns: message repeated 19 times: [ [error] Reloading BIND failed (is it running?): Command rndc -c /etc/bind/maas/rndc.conf.maas reload returned non-zero exit status 1:#012rndc: connect failed: 127.0.0.1#954: connection refused]
2019-01-15T11:20:59.670150-05:00 wc maas.service_monitor: [info] Service ‘bind9’ is not on, it will be started.
2019-01-15T11:20:59.673999-05:00 wc maas.dns: [error] Reloading BIND failed (is it running?): Command rndc -c /etc/bind/maas/rndc.conf.maas reload returned non-zero exit status 1:#012rndc: connect failed: 127.0.0.1#954: connection refused
2019-01-15T11:20:59.725717-05:00 wc maas.service_monitor: [error] Service ‘bind9’ failed to start. Its current state is ‘dead’ and ‘Result: exit-code’.
2019-01-15T11:21:01.134416-05:00 wc maas.dns: [error] Reloading BIND failed (is it running?): Command rndc -c /etc/bind/maas/rndc.conf.maas reload returned non-zero exit status 1:#012rndc: connect failed: 127.0.0.1#954: connection refused
systemctl status bind9:
Jan 15 11:20:29 maas-1 named[4646]: loading configuration from ‘/etc/bind/named.conf’
Jan 15 11:20:29 maas-1 named[4646]: /etc/bind/maas/named.conf.maas:112: zone ‘56.84.10.in-addr.arpa’: already exists previous definition: /etc/bind/maas/named.conf.maas:12
Jan 15 11:20:29 maas-1 named[4646]: loading configuration: failure
Jan 15 11:20:29 maas-1 named[4646]: exiting (due to fatal error)
Jan 15 11:20:29 maas-1 systemd[1]: bind9.service: Main process exited, code=exited, status=1/FAILURE
Jan 15 11:20:29 maas-1 systemd[1]: bind9.service: Failed with result ‘exit-code’.
What to do?
