I am trying to commission RPI from my MaaS rack+region controller, Lenovo T500 running Ubuntu 18.04LTS
The error seems similar to what is here, but the workaround solution doesn’t seem to apply to me.
I found this link as well but it doesn’t seem helpful enough to be related.
I have attached texts of the relevant logs. I would appreciate any insight the community may have in order to solve and commission my PIs.
LOGS HYPERLINKED HERE:
sudo tail -f /var/snap/maas/common/log/maas.log
sudo snap restart maas.supervisor
sudo maas status
sudo snap logs -f maas.supervisor
sudo cat /var/snap/maas/15003/bind/rndc.conf.maas
sudo cat /var/snap/maas/15003/bind/named.conf
This is what my MAAS-defined subnets looks like:
Thank you for your time and attention.
